C300-02200056
C300-02200056
    NIDEC(尼得科)
    CONTROL TECHNIQUES - C300-02200056 - AC MOTOR DRIVE, 1 & 3-PH, 1.5HP, 240VAC
C300-02200056 数据手册
Commander C300 AC Drives Enhance throughput with machine safety, communications, and built-in PLC Commander C300 provides flexible integration with safety and communications. Commander C300 is ideal for applications that require cost-effective integration into safety systems. With two Safe Torque Off (STO) inputs, onboard PLC and an SI interface for industry standard fieldbuses, Ethernet or extended I/O options, this feature set ensures Commander C300’s flexible integration with any system. Enhance up-time and system flexibility • Flexible system integration and remote diagnostics through optional industrial Ethernet and fieldbus communication • Flexible I/O that is expandable with SI-I/O option module • Enhanced functionality and onboard PLC programming provides a low-cost system solution, minimizing the need for additional equipment such as PLCs High performance open loop motor control • RFC-A (Rotor Flux Control) algorithm for exceptional induction motor control of demanding applications • Closed loop current control without a position feedback device • Speed control for conveyors, fans, pumps, and mixers, where their function is controlled remotely with fieldbus or Ethernet communications Key data Heavy Duty Ratings: Normal Duty Ratings: Supply phases: Commander C300 Frame Size 3 Voltage ratings 100 / 120 VAC ± 10% ü 200 / 240 VAC ± 10% ü 380 / 480 VAC ± 10% ü How to select a drive (Consult online catalog for complete drive information) Control mode Open loop vector or V/Hz induction motor control Open loop Rotor Flux Control for induction motors (RFC-A) 0.33 HP to 150 HP (0.25 kW to 110 kW) 0.33 HP to 200 HP (0.25 kW to 132 kW) Frame size 1 and 2: 110 V drives 1Ø, 230 V drives 1Ø or 3Ø; Frame size 7 and larger 3Ø; 460 V drives 3Ø Control connections: 3x Analog I/O, 5x Digital I/O, 2x STO, 1x Relay Drive rating: IP21 / UL open class as standard Keypad: Fixed LED Option slots: 1 (frame size 2 and above) Parameter cloning via: PC tools, SD card ü ü 1. Electrical Considerations • What is the supply voltage? • Single or 3Ø input power? • What is the motor rating? • Continuous current – FLA (Full Load Amps) • Select the drive based on motor Amps rather than horsepower 2. Load Type (choose one) • Normal Duty: Peak current is 110% of drive rating (fans, pumps, etc.) • Heavy Duty: Peak current is 180% (mixers, conveyors, etc.) 3. Drive Mechanical Mounting 900 SO 1 SIL3 I V Safety Integrity Level O 9002 E171230 L P RO IS AP AL Visit www.Drive-Setup.com for step by step guides, videos, software, product support documentation & 5 year warranty registration. • Panel mounting – as standard • Wall mounting – UL conduit kits are available • Through panel mounting – frames 5 and up COMMANDER C300 AC Drives for Industrial Applications Order Information & Ratings 115 VAC, Single Phase 50/60 Hz Input, 230 VAC 3-Phase Output Commander C300 Order Code* Input Phase C300-01100017A C300-01100024A C300-02100042A C300-02100056A 1 1 1 1 Normal Duty HP Amps 0.33 1.7 0.5 2.4 1 4.2 1.5 5.6 Heavy Duty HP Amps 0.33 1.7 0.5 2.4 1 4.2 1.5 5.6 230 VAC, Single & 3-Phase Input, 3-Phase Output, 50/60 Hz Input C300-01200017A C300-01200024A C300-01200033A C300-01200042A C300-02200024A C300-02200033A C300-02200042A C300-02200056A C300-02200075A C300-03200100A C300-04200133A C300-04200176A C300-05200250A C300-06200330A C300-06200440A C300-07200610A C300-07200750A C300-07200830A C300-08201160A C300-08201320A C300-09201760x** C300-09202190x** 1 1 1 1 1, 3 1, 3 1, 3 1, 3 1, 3 1, 3 1, 3 3 3 3 3 3 3 3 3 3 3 3 0.33 0.5 0.75 1 0.5 0.75 1 1.5 2 3 3 5 10 15 20 25 30 40 50 60 75 100 1.7 2.4 3.3 4.2 2.4 3.3 4.2 5.6 7.5 10 13.3 17.6 30 50 58 75 94 117 149 180 216 266 0.33 0.5 0.75 1 0.5 0.75 1 1.5 2 3 3 5 7.5 10 15 20 25 30 40 50 60 75 1.7 2.4 3.3 4.2 2.4 3.3 4.2 5.6 7.5 10 13.3 17.6 25 33 44 61 75 83 116 132 176 219 460 VAC, Three Phase Input, 3-Phase Output, 50/60 Hz Input C300-02400013A C300-02400018A C300-02400023A C300-02400032A C300-02400041A C300-03400056A C300-03400073A C300-03400094A C300-04400135A C300-04400170A C300-05400270A C300-05400300A C300-06400350A C300-06400420A C300-06400470A C300-07400660A C300-07400770A C300-07401000A C300-08401340A C300-08401570A C300-09402000x** C300-09402240x** 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 0.5 0.75 1 1.5 2 3 3 5 7.5 10 20 20 25 30 50 60 75 75 125 150 150 200 1.3 1.8 2.3 3.2 4.1 5.6 7.3 9.4 13.5 17 30 30 38 48 63 79 94 112 155 184 221 255 0.5 0.75 1 1.5 2 3 3 5 7.5 10 20 20 25 30 30 50 60 75 100 125 150 150 1.3 1.8 2.3 3.2 4.1 5.6 7.3 9.4 13.5 17 27 30 35 42 47 66 77 100 134 157 180 211 *Add 10101AB100 to the base order code when ordering standard US (60Hz) default products **x= A or E (9E frame requires an external AC Line Reactor) Order String - Frame Size Key Example: C300-XX_ _ _ _ _ _ _ XX = Frame Size (01-09 above) W Dimensions & Weights Frame Size 01 02 03 04 05 06 07 08 09E 09A Dimensions H x W x D (in) 6.3 x 3.0 x5.1 8.1 x 3.1 x 5.9 8.9 x 3.5 x 6.3 10.9 x 4.5 x 6.9 15.4 x 5.6 x 7.9 15.4 x 8.3 x 9.0 21.9 x 10.6 x 11.0 31.7 x 12.2 x 11.4 39.8 x 12.2 x 11.4 43.6 x 12.2 x 11.4 Weight (lbs) 1.7 2.2 3.3 6.9 16.3 30.9 61.7 114.6 101.4 146.6 H D Additional distance should be added to the height dimension (H) when the AI options are fitted. OPTIONS AT-A-GLANCE Option Drive Configuration & Programming Operator Interfaces Input / Output*** Communications*** Application Programming Software & Diagnostics Power Accessories Environmental Protection & Cable Management Description Order Code Configuration software Drive to PC USB cable (requires a 485 adaptor) Parameter cloning 4 GB (includes 4 GB SD card) Parameter cloning (requires an SD card) 8 GB SD card Remote LCD display Remote LCD display with real-time clock Remote display cable Extended I/O Modbus RTU Modbus RTU with 24 V PROFIBUS DP DeviceNet CANopen PROFINET RT EtherCAT EtherNet/IP, Modbus TCP PLC programming Digital oscilloscope External EMC filter Line & load reactors Dynamic braking resistors UL Type 1 conduit kits Retrofit for Commander SK Fan replacement kits CONNECT CT-USB-CABLE AI-SMART-ADAPTOR AI-BACKUP-ADAPTOR CTSD8GB REMOTE-KEYPAD REMOTE-KEYPAD-RTC UM-LCD-485-XXX**** SI-I/O AI-485-ADAPTOR AI-485-24V-ADAPTOR SI-PROFIBUS SI-DEVICENET SI-CANOPEN SI-PROFINET-V2 SI-ETHERCAT SI-ETHERNET MACHINE-CONTROL-STUDIO CTSCOPE See the General Purpose AC Drives brochure See the General Purpose AC Drives brochure ***frame sizes 2 and up accept 1 SI option ****Shielded RS485 patch cable, CAT5e, conductive metal RJ45 connectors, XXX=cable length in 5 foot increments (max 330 ft), standard lengths are (005, 010, 015, 025 and 050) Diagnostic Software Our Drive Diagnostics APP allows users to quickly diagnose faults. In the unlikely event that you get a drive error, download our complimentary Diagnostics Tool app. Just input the error code on your device and you’ll be given a solution. P/N SEL-C300 09/19 Download our Diagnostics Tool App at: www.ctdrives.com/diagnotics SOFTWARE INCLUDED 5-year warranty Terms & Conditions apply Call us at: +1 800 893-2321
C300-02200056 价格&库存
很抱歉,暂时无法提供与“C300-02200056”相匹配的价格&库存,您可以联系我们找货
