ATE1D-6M3-10-Z
ATE1D-6M3-10-Z
    NIDEC(尼得科)
    插件
    钮子开关 双刀双掷 5万次 插件 50mA 60V -20℃~+85℃
ATE1D-6M3-10-Z 数据手册
ATE Washable Subminiature Toggle Switch RoHS Compliant UL ■Features ■ Specifications 1. Twin-contact clip mechanism for high reliability. 2. Process sealed structure 3. Gold-plated contacts. 4. Terminal pin pitch: 2.54 mm. 5. Independent detent mechanism ensures light operational feel. 6. UL recognized (Excluding ATE-J series with plastic cap/rocker) Rating Max. Min. 50mA 60VAC/DC 0.4VA AC/DC 1μA 20mVAC/DC UL 48VAC/DC 50mA Initial contact resistance 50mΩ Max. Insulation resistance 500MΩ min. Dielectric strength 250VAC 1 minute (1.5mA 200μVAC) (500VDC) 10,000 cycles at 0.4VA rating. 50,000 cycles at 0.4VA rating.(D.E type) 30,000 cycles at 0.4VA rating.(F.G.H type) Electrical life D.E type 50,000 cycles F.G.H type 30,000 cycles Mechanical life Operating temperature range Storage temperature range −20℃∼+85℃ −40℃∼+85℃ ■Part Numbering A TE 2  D -  2  M  3 - 10 - Z Series code Actuator shape Number of poles Switching function Code Switching function Code Type Fig. Number of poles TE Toggle type 1 1 pole D 2 2 poles F Terminal style Actuator shape Bracket style Code Actuator shape Fig. Terminal style 2 PC Straight M Standard ー (ON) 5 Right angle (0.2 inch pitch) F Flat toggle G (ON)ーOFFー(ON) 6 Right angle (0.3 inch pitch) E H ON ー ON ONーOFF ーON ON Clip mechanism Fig. Bracket 3 Without bracket ONーOFFー(ON) Compact type Space between terminal rows (Double pole): 2.54 mm (ON) :Momentary. ATE ■Right Angle Terminals (0.2-inch pich) (0.3-inch pich) ●The space between the terminal rows are available in two dimensions: 0.2 inches (5.08 mm) and 0.3 inches (7.62 mm). 1-pole [Example] 0.2-inch pitch: ATE1D-5M3-10-Z 0.3-inch pitch: ATE1D-6M3-10-Z 2-poles 0.2 R/A Type ATE−2M・5M・6M Part name Color Cap 0.3 R/A ■Optional Accessories Gloss finish  Refer to P.371 for PC Hole Layouts. Bracket Part name Poles Single pole Box size 5 mm Double poles Dimensions 7.5 mm 5 mm ATE-2M・2F Type Vinyl chloride 4.12 4.12 4.12 Dimensions 140000640314 Part number SPDT 140000640315 0.6 2.54 2.54 26゚ 9.5 6 8 4 (2) 140000470173 Gray 140000470179 Viewed from part No. marking side (1) 3.3 0.3  ATE1D-2M3-10-Z  ATE1E-2M3-10-Z  ATE1F-2M3-10-Z  ATE1G-2M3-10-Z ☆ATE1H-2M3-10-Z ON ON ON (ON) ON − OFF − OFF OFF ON ON (ON) (ON) (ON) Connecting terminals 2−3 − 2−1 Distance between two terminal rows : 2.54mm 5 φ4 Switching function 2.54 2.54 0.6 Part number marking side 26゚ 9.5 Black Part No. Terminal numbers are not shown on the switch. φ2.5 140000470175 Part number marking side φ2.5 PC Straight Red Switching function 5 φ4 (3) DPDT 140000470174 140000640318 Standard Toggle PC Straight White 6 4 8 3.3 (6) (3) (5) (2) (4) (1) Part No.  ATE2D-2M3-10-Z ☆ATE2E-2M3-10-Z ☆ATE2G-2M3-10-Z Connecting terminals 0.3 2.54 Viewed from part No. marking side ON ON (ON) 2−3 5−6 Terminal numbers are not shown on the switch. ★:Made to order products. ☆:Semi-standard products. (ON) :Momentary. :Optional Accessories. − OFF OFF − ON ON (ON) 2−1 5−4 ATE (Mounting height : 3.1mm) 6 4 (0.7) 8 5.6 (3) (2) (1) 26゚ 9.5 Part No. 0.7 3.1 φ2.5 Part number marking side Terminal numbers are not shown on the switch.  ATE1D-5M3-10-Z ☆ATE1E-5M3-10-Z ☆ATE1G-5M3-10-Z ★ATE1H-5M3-10-Z ON ON (ON) ON − OFF OFF OFF ON ON (ON) (ON) Connecting terminals 2−3 − 2−1 0.3 (Mounting height : 3.1mm) Switching function 4 6 8 5.6 (2.9) (3) (1) (2) (5) (6) (4) 26゚ 9.5 Part No. 0.7 3.1 ☆ATE2D-5M3-10-Z ☆ATE2G-5M3-10-Z Connecting terminals φ2.5 Part number marking side Terminal numbers are not shown on the switch. Switching function (Mounting height : 3.1mm) 4 8 (0.7) (2) (1) 9.5 Part No. 0.7 3.1 φ2.5 Partnumbermarkingside Terminal numbers are not shown on the switch. − OFF − ON (ON) 2−1 5−4 0.4 7.62 Viewed from part No. marking side 3.3 (3) 5.6 0.6 6 2.54 2.54 5 φ4 1.5 Right angle(0.3 inch pitch) ON (ON) 2−3 5−6 0.3 0.3 5.08 2.54 26゚ SPDT 0.4 Viewed from part No. marking side 3.3 0.6 5 φ4 1.8 Right angle(0.2 inch pitch) 2.54 2.54 DPDT 0.4 5.08 Viewed from part No. marking side 3.3 0.6 5 φ4 1.8 Right angle(0.2 inch pitch) Switching function 2.54 2.54 SPDT 0.3 (ON) :Momentary.  ATE1D-6M3-10-Z  ATE1E-6M3-10-Z  ATE1F-6M3-10-Z ☆ATE1G-6M3-10-Z ☆ATE1H-6M3-10-Z ON ON ON (ON) ON − OFF − OFF OFF ON ON (ON) (ON) (ON) Connecting terminals 2−3 − 2−1 ☆:Semi-standard products. ★:Made to order products. ATE DPDT (Mounting height : 3.1mm) (2.9) 8 (3) (2) (6) (4) (1) (5) 26゚ 9.5 Switching function 3.3 5.6 0.6 4 1.5 6 2.54 2.54 Right angle(0.3 inch pitch) 5 φ4 Part No.  ATE2D-6M3-10-Z 0.7 Connecting terminals ON 2−3 5−6 − − ON 2−1 5−4 φ2.5 Part number marking side Viewed from part No. marking side 0.4 Terminal numbers are not shown on the switch. SPDT 0.3 7.62 0.3 2.54 Switching function Flat Toggle PC Straight 5 φ4 φ2.7 (3) 2.54 2.54 26゚ 9.5 0.6 Part number marking side 4 10 4 8 3.3 (2) (1) 0.3 Terminal numbers are not shown on the switch. ★:Made to order products. ☆:Semi-standard products. (ON) :Momentary. Part No. Viewed from part No. marking side  ATE1D-2F3-10-Z  ATE1E-2F3-10-Z ON ON − OFF ON ON Connecting terminals 2−3 − 2−1 ATE DPDT (Space between terminal rows (Double pole): 2.54 mm) PC Straight 5 φ4 Switching function 2.54 2.54 4 26゚ 9.5 0.6 Part number marking side 4 10 φ2.7 8 (6) (3) (5) (2) (4) (1) 0.3 3.3 Part No. ☆ATE2D-2F3-10-Z ☆ATE2G-2F3-10-Z Connecting terminals Viewed from part No. marking side ON (ON) 2−3 5−6 − OFF − ON (ON) 2−1 5−4 2.54 Terminal numbers are not shown on the switch. SPDT (Mounting height : 3.1mm) 5 φ4 Switching function 4 8 (0.7) 5.6 2.54 2.54 (2) (1) 9.5 26゚ Part No. 0.7 4 3.1 Viewed from part No. marking side 3.3 (3) 1.8 10 0.6 Right angle(0.2 inch pitch) (ON) ON OFF OFF (ON) (ON) Connecting terminals 2−3 − 2−1 φ2.7 Part number marking side ★ATE1G-5F3-10-Z ★ATE1H-5F3-10-Z Terminal numbers are not shown on the switch. DPDT 0.4 5.08 0.3 (Mounting height : 3.1mm) 4 8 5.6 (2.9) (3) (2) (6) (4) (1) (5) 26゚ 9.5 0.7 4 Viewed from part No. marking side 3.3 Part No. 2.54 2.54 10 Switching function 0.6 5 φ4 1.8 Right angle(0.2 inch pitch) 3.1 ★ATE2D-5F3-10-Z Connecting terminals ON 2−3 5−6 − − ON 2−1 5−4 φ2.7 Part number marking side Terminal numbers are not shown on the switch. 0.4 0.3 0.3 5.08 2.54 (ON) :Momentary. ☆:Semi-standard products. ★:Made to order products. ATE SPDT (Mounting height : 3.1mm) 4 8 (0.7) 5.6 (3) (2) (1) 26゚ 9.5 Part No. 0.7 4 3.1 Viewed from part No. marking side 3.3 1.5 10 Switching function 0.6 5 φ4 2.54 2.54 Right angle(0.3 inch pitch) ☆ATE1G-6F3-10-Z (ON) OFF (ON) Connecting terminals 2−3 − 2−1 φ2.7 Part number marking side Terminal numbers are not shown on the switch. DPDT 0.4 7.62 0.3 (Mounting height : 3.1mm) 8 5.6 (2.9) (4) (5) (6) 26゚ 9.5 0.7 4 3.1 φ2.7 Part number marking side Terminal numbers are not shown on the switch. 0.4 ☆:Semi-standard products. (ON) :Momentary. 0.3 0.3 7.62 2.54 Viewed from part No. marking side 3.3 Part No. 0.6 4 1.5 10 Switching function 2.54 2.54 5 φ4 (1) (2)  (3) Right angle(0.3 inch pitch) ☆ATE2D-6F3-10-Z Connecting terminals ON 2−3 5−6 − − ON 2−1 5−4 ATE-J(Plastic type) ■Part Numbering (Plastic cap・Rocker type) A TE 1  D -  2  J   3 - 10 - Z Series code Actuator shape Number of poles Code Type Fig. Number of poles TE Toggle type 1 1 pole 2 2 poles Switching function Code Switching function D E ON ー ON ONーOFF ーON Terminal style Actuator shape Fig. Terminal style 2 P/C terminal 7 Vertical mounting SPDT Bracket style Code Actuator shape J Plastic Knob type Switching function PC Straight Clip mechanism Fig. Bracket 3 Without bracket Viewed from part No. marking side Part No. ☆ATE1D-2J3-10-Z ★ATE1E-2J3-10-Z ON ON − OFF ON ON Connecting terminals 2−3 − 2−1 Mount with CAP ●Color cap and Rocker accessories are sold separately. Terminal numbers are not shown on the switch. (ON) :Momentary. ★:Made to order products. ☆:Semi-standard products. ATE−J SPDT Switching function Vertical mounting Viewed from part No. marking side Part No. Mount with CAP ★ATE1D-7J3-10-Z ON − ON Connecting terminals 2−3 − 2−1 Terminal numbers are not shown on the switch. ■Optional Accessories 《Sold separately》 Type ATE−2J・7J ATE−2J・7J Part name Color Cap Rocker Matte finish Matte finish Dimensions ABS resin ABS resin White 140000050884 140000481541 Red 140000050886 140000481543 Black 140000050885 140000481542 ★:Made to order products. (ON) :Momentary. :Optional Accessories. ■Color Cap and Rocker  Installation Procedure for ATE−J type ATE ■PC Hole Layouts  PC terminal (Top voew) Series code ATE−2M・2F・2J Installation Whithout bracket ATE−2M・2F When optional bracket is used 140000640314 140000640315 140000640318 1−pole 2−poles 2.54mm Tow terminal rows  Right Angle terminal・Vertical Mount terminal (Top view) Series code ATE−5M・5F ATE−6M・6F ATE−7J Terminal R/A 0.2−inch pich R/A 0.3−inch pich Vertical mount 1−pole 2−poles ■Bracket Mounted Dimensions. Type Dimensions ATE−2M ATE−2F Standard Flat ATE ■Soldering Specifications ■Flux Cleaning ⑴Manual Soldering ⑴Solvent : Fluorine or Alcohol type. Device : Soldering iron ⑵Cleaning after soldering should be done after the terminal 380℃, Max.; 3 seconds, Max. temperature falls to 90℃ or below, or after leaving the switch ⑵Auto Soldering for five minutes or longer at room temperature. Device : Jet wave type or dip type 275℃, Max.; 6 seconds, Max. [℃] 275 120 80 120 Pre-heating S 6 Soldering ●Pre-heating should be done at temperatures ranging from 80℃ to 120℃ and within 120 seconds ⑶Install the cap/rocker accessory after soldering and cleaning. ■Packaging Specifications ■Mounting of Switch Plastick Pack PC terminals : 100 pcs./pack KU 15 SO Plastick Pack SO JI 231 JI ●Do not bend the terminal pins before mounting the switch on the PC board. FU FU ●Use PC boards with hole diameter of 1mm. KU 196 Right angle terminals : 50 pcs./pack Vertical mounting terminals 100 pcs./pack ●After mounting the switch, do not place the device in such a way that the device weight will be applied on to the actuator of the switch. ●Do not apply load exceeding 12.7 N to the actuator.
ATE1D-6M3-10-Z 价格&库存
很抱歉,暂时无法提供与“ATE1D-6M3-10-Z”相匹配的价格&库存,您可以联系我们找货
ATE1D-6M3-10-Z
  • 2+36.338842+4.71842
  • 10+30.7513710+3.99292
  • 25+28.9791525+3.76280
  • 100+20.05068100+2.60348
  • 500+19.47799500+2.52912
  • 1000+18.723171000+2.43111
库存:80
ATE1D-6M3-10-Z
  • 2+36.400652+4.72645
  • 10+30.8041810+3.99977
  • 25+29.0286025+3.76922
  • 100+20.08541100+2.60799
  • 500+19.51188500+2.53352
  • 1000+18.755361000+2.43529
库存:80
