Commander C200 AC Drives
Enhance throughput with machine safety, communications, and built-in PLC
The Commander C200 delivers benchmark functionality at no added cost to the base
drive itself. Plug-in options, dynamic performance, PLC functionality and other advanced
features such as fieldbus, Ethernet, and Modbus RTU communications ensure that in
more complex applications Commander C200 can deliver more than the average general
purpose drive - giving you lower cost solutions and better productivity in your motor
control applications.
Enhance up-time and system flexibility
• Flexible system integration and remote diagnostics through optional industrial
Ethernet and fieldbus communication
• Flexible I/O expandable with SI-I/O option module
• Enhanced functionality and onboard PLC programming provides a low-cost system
solution, minimizing the need for additional equipment such as PLCs
High performance open-loop motor control
• RFC-A (Rotor Flux Control) algorithm for exceptional induction motor control of
demanding applications
• Closed loop current control without a position feedback device
• Speed control for conveyors, fans, pumps, and mixers, where their function is
controlled remotely with fieldbus or Ethernet communications
Key data
Heavy Duty Ratings:
Normal Duty Ratings:
Supply phases:
Commander C200 Frame Size 3
Voltage ratings
100 / 120 VAC ± 10%
ü
200 / 240 VAC ± 10%
ü
380 / 480 VAC ± 10%
ü
Control mode
Open loop vector or V/Hz induction
motor control
Open loop Rotor Flux Control for
induction motors (RFC-A)
0.33 hp to 150 hp (0.25 kW to 110 kW)
0.33 hp to 200 hp (0.25 kW to 132 kW)
Frame size 1 and 2: 110 V drives 1Ø,
230 V drives 1Ø or 3Ø; Frame size 7 and larger 3Ø;
460 V drives 3Ø
Control connections:
2x Analog inputs, 4x Digital inputs, 1x Analog output,
1x Digital I/O, 1x Relay
Drive rating:
IP21 / UL open class as standard
Keypad:
Fixed LED
Option slots:
1 (frame size 2 and above)
Parameter cloning via: PC tools, SD card
ü
ü
How to select a drive (Consult online catalog for complete drive information)
1. Electrical Considerations
• What is the supply voltage?
• Single or 3Ø input power?
• What is the motor rating?
• Continuous current – FLA (Full Load Amps)
• Select the drive based on motor Amps rather than horsepower
2. Load Type (choose one)
• Normal Duty: Peak current is 110% of drive rating (fans, pumps, etc.)
• Heavy Duty: Peak current is 180% (mixers, conveyors, etc.)
3. Drive Mechanical Mounting
• Panel mounting – as standard
• Wall mounting – UL conduit kits are available
• Through panel mounting – frames 5 and up
900
SO 1
SIL3
I
V
Safety Integrity Level
O
9002
E171230
L
P RO
IS
AP
AL
Visit www.Drive-Setup.com
for step by step guides, videos,
software, product support
documentation & 5 year
warranty registration.
COMMANDER C200
AC Drives for Industrial Applications
Order Information & Ratings
115 VAC, Single Phase 50/60 Hz Input, 230 VAC 3-Phase Output
Commander C200
Order Code*
Input
Phase
C200-01100017A
C200-01100024A
C200-02100042A
C200-02100056A
1
1
1
1
Normal Duty
HP
Amps
0.33
1.7
0.5
2.4
1
4.2
1.5
5.6
Heavy Duty
HP
Amps
0.33
1.7
0.5
2.4
1
4.2
1.5
5.6
230 VAC, Single & 3-Phase Input, 3-Phase Output, 50/60 Hz Input
C200-01200017A
C200-01200024A
C200-01200033A
C200-01200042A
C200-02200024A
C200-02200033A
C200-02200042A
C200-02200056A
C200-02200075A
C200-03200100A
C200-04200133A
C200-04200176A
C200-05200250A
C200-06200330A
C200-06200440A
C200-07200610A
C200-07200750A
C200-07200830A
C200-08201160A
C200-08201320A
C200-09201760x**
C200-09202190x**
1
1
1
1
1, 3
1, 3
1, 3
1, 3
1, 3
1, 3
1, 3
3
3
3
3
3
3
3
3
3
3
3
0.33
0.5
0.75
1
0.5
0.75
1
1.5
2
3
3
5
10
15
30
40
50
60
75
100
1.7
2.4
3.3
4.2
2.4
3.3
4.2
5.6
7.5
10
13.3
17.6
30
50
58
75
94
117
149
180
216
266
0.33
0.5
0.75
1
0.5
0.75
1
1.5
2
3
3
5
7.5
10
15
30
40
50
60
75
1.7
2.4
3.3
4.2
2.4
3.3
4.2
5.6
7.5
10
13.3
17.6
25
33
44
61
75
83
116
132
176
219
460 VAC, Three Phase Input, 3-Phase Output, 50/60 Hz Input
C200-02400013A
C200-02400018A
C200-02400023A
C200-02400032A
C200-02400041A
C200-03400056A
C200-03400073A
C200-03400094A
C200-04400135A
C200-04400170A
C200-05400270A
C200-05400300A
C200-06400350A
C200-06400420A
C200-06400470A
C200-07400660A
C200-07400770A
C200-07401000A
C200-08401340A
C200-08401570A
C200-09402000x**
C200-09402240x**
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
0.5
0.75
1
1.5
2
3
3
5
7.5
10
30
50
60
75
75
125
150
150
200
1.3
1.8
2.3
3.2
4.1
5.6
7.3
9.4
13.5
17
30
30
38
48
63
79
94
112
155
184
221
255
0.5
0.75
1
1.5
2
3
3
5
7.5
10
30
30
50
60
75
100
125
150
150
1.3
1.8
2.3
3.2
4.1
5.6
7.3
9.4
13.5
17
27
30
35
42
47
66
77
100
134
157
180
211
*Add 10101AB100 to the base order code when ordering standard US (60Hz) default products
**x= A or E (9E frame requires an external AC Line Reactor)
Order String - Frame Size Key
Example: C200-XX_ _ _ _ _ _ _
XX = Frame Size (01-09 above)
W
Dimensions & Weights
Frame Size
01
02
03
04
05
06
07
08
09E
09A
Dimensions
H x W x D (in)
6.3 x 3.0 x5.1
8.1 x 3.1 x 5.9
8.9 x 3.5 x 6.3
10.9 x 4.5 x 6.9
15.4 x 5.6 x 7.9
15.4 x 8.3 x 9.0
21.9 x 10.6 x 11.0
31.7 x 12.2 x 11.4
39.8 x 12.2 x 11.4
43.6 x 12.2 x 11.4
Weight
(lbs)
1.7
2.2
3.3
6.9
16.3
30.9
61.7
114.6
101.4
146.6
H
Additional distance should be added to the height
dimension (H) when the AI options are fitted.
D
OPTIONS AT-A-GLANCE
Option
Description
Order Code
Configuration software
CONNECT
Drive to PC USB cable
CT-USB-CABLE
(requires a 485 adaptor)
Parameter cloning 4 GB
Drive Configuration
AI-SMART-ADAPTOR
(includes 4 GB SD card)
& Programming
Parameter cloning
AI-BACKUP-ADAPTOR
(requires an SD card)
8 GB SD card
CTSD8GB
Remote LCD display
REMOTE-KEYPAD
Remote LCD display
Operator Interfaces
REMOTE-KEYPAD-RTC
with real-time clock
Remote display cable
UM-LCD-485-XXX****
Input / Output***
Extended I/O
SI-I/O
Modbus RTU
AI-485-ADAPTOR
Modbus RTU with 24 V
AI-485-24V-ADAPTOR
PROFIBUS DP
SI-PROFIBUS
DeviceNet
SI-DEVICENET
Communications***
CANopen
SI-CANOPEN
PROFINET RT
SI-PROFINET-V2
EtherCAT
SI-ETHERCAT
EtherNet/IP, Modbus TCP
SI-ETHERNET
Application Programming
PLC programming
MACHINE-CONTROL-STUDIO
Software & Diagnostics
Digital oscilloscope
CTSCOPE
External EMC filter
See the General Purpose
Power Accessories
Line & load reactors
AC Drives brochure
Dynamic braking resistors
UL Type 1 conduit kits
Environmental Protection
Retrofit for
& Cable Management
Commander SK
AC Drives brochure
Fan replacement kits
***frame sizes 2 and up accept 1 SI option
****Shielded RS485 patch cable, CAT5e, conductive metal RJ45 connectors, XXX=cable length in
5 foot increments (max 330 ft), standard lengths are (005, 010, 015, 025 and 050)
Diagnostic Software
Our Drive Diagnostics APP allows
users to quickly diagnose faults. In
the unlikely event that you get a drive
error, download our complimentary
Diagnostics Tool app. Just input the
error code on your device and you’ll
be given a solution.
P/N SEL-C200 09/19
Download our Diagnostics Tool App at:
www.ctdrives.com/diagnotics
SOFTWARE
INCLUDED
5-year warranty
Terms & Conditions apply
Call us at: +1 800 893-2321
