EKMM161VSN222MA45S
EKMM161VSN222MA45S
    NCC(贵弥功)
    AEC-2P_D35X45MM_TM
    2200UF ±20% 160V
EKMM161VSN222MA45S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS KMM LXS Series LXQ Longer life Longer life ・Longer life from KMQ series ・Endurance with ripple current : 2,000 to 3,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Long life snap-ins, 105℃ KMM KMS Downsized Longer life KMQ ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +105℃ 160 to 450Vdc ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 160 to 400V 420 & 450V tanδ(Max.) 0.15 0.20 Rated voltage (Vdc) 160 to 400V 420 & 450V Z(-25℃)/Z(+20℃) 4 8 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage)for 3,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] ●Terminal Sleeve (PET : Brown) Negative mark PC board pin-out (View from Solder side) φD+1max. 10 Vent 2-φ2 * 4.0±0.5 L±2 Code : LI (φ35) Sleeve (PET : Brown) Negative mark PC board pin-out (View from Solder side) 2-1.2×6 4.2±0.5 Code : VS (φ22 toφ35) : Standard φD+1max. ●Terminal Vent 5±0.5 L±2 4.5±1 14.2±1 *φD=35mm : 3.5±0.5mm The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 E K MM 5 6 7 8 9 10 VS N 11 12 13 14 M 15 16 17 18 S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 120µF:121, 1,000µF:102) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 160V:161, 250V:251, 315V:3B1) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ KMMSeries ◆STANDARD RATINGS WV (Vdc) 160 180 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 220 270 330 330 390 390 390 470 470 470 560 560 560 560 680 680 680 680 820 820 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,700 3,300 180 220 270 270 330 330 330 390 390 390 470 470 470 470 560 560 560 560 680 680 680 680 820 820 820 820 1,000 1,000 1,000 22 ×20 25.4×20 22 ×25 25.4 ×20 22 ×25 25.4 ×25 30× 20 22× 30 25.4× 25 30 × 20 22 × 35 25.4× 30 30 ×25 35 ×20 22 ×40 25.4×30 30 ×25 35 ×20 22× 45 25.4× 35 30 × 30 35 × 25 22 × 50 25.4× 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 25.4 × 60 30 × 40 35 × 30 30 × 45 35 × 35 30 × 60 35 × 45 35 × 50 35 × 60 22 × 20 25.4 × 20 22 × 25 25.4 × 20 22 × 25 25.4 × 25 30 × 20 22 × 30 25.4 × 25 30 × 20 22 × 35 25.4 × 30 30 × 25 35 × 20 22 × 40 25.4 × 30 30 × 25 35 ×20 22 ×45 25.4 ×35 30× 30 35 × 25 22 ×50 25.4×40 30 ×30 35 ×25 25.4 ×45 30× 35 35 × 30 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.81 0.98 1.20 1.02 1.30 1.26 1.25 1.55 1.55 1.30 1.67 1.67 1.67 1.46 1.82 1.82 1.82 1.51 2.04 2.04 2.04 2.04 2.25 2.25 2.25 2.25 2.49 2.49 2.49 2.97 2.84 2.84 3.32 3.00 3.86 3.50 4.00 4.63 0.80 0.90 1.00 0.95 1.20 1.16 1.15 1.35 1.35 1.20 1.50 1.50 1.50 1.36 1.67 1.67 1.67 1.43 1.78 1.78 1.78 1.83 2.04 2.04 2.04 2.04 2.30 2.30 2.30 Part No. EKMM161VSN221MP20S EKMM161VSN271MQ20S EKMM161VSN331MP25S EKMM161VSN331MQ20S EKMM161VSN391MP25S EKMM161VSN391MQ25S EKMM161VSN391MR20S EKMM161VSN471MP30S EKMM161VSN471MQ25S EKMM161VSN471MR20S EKMM161VSN561MP35S EKMM161VSN561MQ30S EKMM161VSN561MR25S EKMM161VSN561MA20S EKMM161VSN681MP40S EKMM161VSN681MQ30S EKMM161VSN681MR25S EKMM161VSN681MA20S EKMM161VSN821MP45S EKMM161VSN821MQ35S EKMM161VSN821MR30S EKMM161VSN821MA25S EKMM161VSN102MP50S EKMM161VSN102MQ40S EKMM161VSN102MR30S EKMM161VSN102MA25S EKMM161VSN122MQ45S EKMM161VSN122MR35S EKMM161VSN122MA30S EKMM161VSN152MQ60S EKMM161VSN152MR40S EKMM161VSN152MA30S EKMM161VSN182MR45S EKMM161VSN182MA35S EKMM161VSN222MR60S EKMM161VSN222MA45S EKMM161VSN272MA50S EKMM161VSN332MA60S EKMM181VSN181MP20S EKMM181VSN221MQ20S EKMM181VSN271MP25S EKMM181VSN271MQ20S EKMM181VSN331MP25S EKMM181VSN331MQ25S EKMM181VSN331MR20S EKMM181VSN391MP30S EKMM181VSN391MQ25S EKMM181VSN391MR20S EKMM181VSN471MP35S EKMM181VSN471MQ30S EKMM181VSN471MR25S EKMM181VSN471MA20S EKMM181VSN561MP40S EKMM181VSN561MQ30S EKMM181VSN561MR25S EKMM181VSN561MA20S EKMM181VSN681MP45S EKMM181VSN681MQ35S EKMM181VSN681MR30S EKMM181VSN681MA25S EKMM181VSN821MP50S EKMM181VSN821MQ40S EKMM181VSN821MR30S EKMM181VSN821MA25S EKMM181VSN102MQ45S EKMM181VSN102MR35S EKMM181VSN102MA30S WV (Vdc) 180 200 220 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 1,200 1,200 1,200 1,500 1,500 1,800 1,800 2,200 2,700 150 180 220 270 270 330 330 330 390 390 390 470 470 470 470 560 560 560 680 680 680 680 820 820 820 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,800 1,800 2,200 150 180 220 220 270 270 270 330 330 330 390 390 390 390 470 470 470 560 560 560 560 680 25.4× 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 60 35 × 40 35 × 50 35 × 60 22 × 20 22 × 20 25.4 × 20 22 × 25 30 × 20 22 × 30 25.4 × 25 30 × 20 22 × 30 25.4 × 25 35 × 20 22 × 35 25.4 × 30 30 × 25 35 × 20 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 30 35 × 25 25.4 × 45 30 × 30 35 × 25 25.4 × 50 30 × 35 35 × 30 25.4 × 60 30 × 40 35 × 35 30 × 50 35 × 40 30 × 60 35 × 45 35 × 50 22 × 20 25.4 × 20 22 × 25 25.4 × 20 22 × 30 25.4 × 25 30 × 20 22 × 35 25.4 × 25 35 × 20 22 × 35 25.4 × 30 30 × 25 35 × 20 22 × 40 25.4 × 35 30 × 25 22 × 45 25.4 × 40 30 × 30 35 × 25 25.4 × 45 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 2.55 2.55 2.55 2.90 2.90 3.49 3.30 3.65 4.19 0.73 0.80 0.85 1.10 1.05 1.25 1.25 1.10 1.35 1.35 1.30 1.50 1.50 1.50 1.41 1.67 1.67 1.67 1.78 1.78 1.78 1.78 2.04 2.04 2.04 2.30 2.30 2.30 2.66 2.65 2.65 3.08 3.08 3.49 3.48 3.78 0.67 0.76 1.00 0.84 1.15 1.08 0.98 1.25 1.25 1.13 1.40 1.40 1.36 1.23 1.51 1.54 1.50 1.70 1.72 1.70 1.71 1.94 Part No. EKMM181VSN122MQ50S EKMM181VSN122MR40S EKMM181VSN122MA30S EKMM181VSN152MR45S EKMM181VSN152MA35S EKMM181VSN182MR60S EKMM181VSN182MA40S EKMM181VSN222MA50S EKMM181VSN272MA60S EKMM201VSN151MP20S EKMM201VSN181MP20S EKMM201VSN221MQ20S EKMM201VSN271MP25S EKMM201VSN271MR20S EKMM201VSN331MP30S EKMM201VSN331MQ25S EKMM201VSN331MR20S EKMM201VSN391MP30S EKMM201VSN391MQ25S EKMM201VSN391MA20S EKMM201VSN471MP35S EKMM201VSN471MQ30S EKMM201VSN471MR25S EKMM201VSN471MA20S EKMM201VSN561MP40S EKMM201VSN561MQ30S EKMM201VSN561MR25S EKMM201VSN681MP45S EKMM201VSN681MQ35S EKMM201VSN681MR30S EKMM201VSN681MA25S EKMM201VSN821MQ45S EKMM201VSN821MR30S EKMM201VSN821MA25S EKMM201VSN102MQ50S EKMM201VSN102MR35S EKMM201VSN102MA30S EKMM201VSN122MQ60S EKMM201VSN122MR40S EKMM201VSN122MA35S EKMM201VSN152MR50S EKMM201VSN152MA40S EKMM201VSN182MR60S EKMM201VSN182MA45S EKMM201VSN222MA50S EKMM221VSN151MP20S EKMM221VSN181MQ20S EKMM221VSN221MP25S EKMM221VSN221MQ20S EKMM221VSN271MP30S EKMM221VSN271MQ25S EKMM221VSN271MR20S EKMM221VSN331MP35S EKMM221VSN331MQ25S EKMM221VSN331MA20S EKMM221VSN391MP35S EKMM221VSN391MQ30S EKMM221VSN391MR25S EKMM221VSN391MA20S EKMM221VSN471MP40S EKMM221VSN471MQ35S EKMM221VSN471MR25S EKMM221VSN561MP45S EKMM221VSN561MQ40S EKMM221VSN561MR30S EKMM221VSN561MA25S EKMM221VSN681MQ45S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ KMMSeries ◆STANDARD RATINGS WV (Vdc) 220 250 315 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 680 680 820 820 820 1,000 1,000 1,000 1,200 1,200 1,500 1,500 1,800 2,200 120 150 180 180 220 220 220 270 270 270 330 330 330 330 390 390 390 470 470 470 470 560 560 560 560 680 680 680 820 820 820 1,000 1,000 1,200 1,200 1,500 1,800 68 82 100 100 120 120 120 150 150 150 150 180 180 180 180 220 30 ×35 35 ×25 25.4 ×50 30 ×40 35× 30 25.4× 60 30× 45 35× 35 30× 50 35× 40 30× 60 35× 45 35× 50 35× 60 22× 20 25.4× 20 22 × 25 25.4× 20 22 × 25 25.4× 25 30 ×20 22 ×30 25.4×25 30 ×20 22 ×35 25.4× 30 30 ×25 35 ×20 22 ×40 25.4×35 30 ×25 22 ×45 25.4×35 30 ×30 35 ×25 22 ×50 25.4×40 30 ×30 35 ×25 25.4×50 30 ×35 35 ×30 25.4×60 30 ×40 35 ×35 30 ×50 35 ×40 30 ×60 35 ×45 35 ×50 35 ×60 22×20 22×20 22 ×25 25.4× 20 22 ×25 25.4×20 30 ×20 22× 30 25.4× 25 30 × 20 35 ×20 22 ×35 25.4 ×25 30 × 25 35 × 20 22 ×40 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.93 1.89 2.18 2.19 2.16 2.54 2.50 2.44 2.81 2.79 3.30 3.22 3.63 4.23 0.60 0.74 0.78 0.75 1.00 0.95 0.95 1.18 1.18 1.00 1.30 1.30 1.30 1.16 1.49 1.49 1.49 1.65 1.65 1.65 1.65 1.67 1.80 1.80 1.80 2.00 2.00 2.00 2.20 2.30 2.30 2.47 2.47 2.85 2.60 3.00 3.42 0.45 0.47 0.61 0.56 0.75 0.62 0.65 0.82 0.82 0.70 0.76 0.92 0.92 0.90 0.85 1.04 Part No. EKMM221VSN681MR35S EKMM221VSN681MA25S EKMM221VSN821MQ50S EKMM221VSN821MR40S EKMM221VSN821MA30S EKMM221VSN102MQ60S EKMM221VSN102MR45S EKMM221VSN102MA35S EKMM221VSN122MR50S EKMM221VSN122MA40S EKMM221VSN152MR60S EKMM221VSN152MA45S EKMM221VSN182MA50S EKMM221VSN222MA60S EKMM251VSN121MP20S EKMM251VSN151MQ20S EKMM251VSN181MP25S EKMM251VSN181MQ20S EKMM251VSN221MP25S EKMM251VSN221MQ25S EKMM251VSN221MR20S EKMM251VSN271MP30S EKMM251VSN271MQ25S EKMM251VSN271MR20S EKMM251VSN331MP35S EKMM251VSN331MQ30S EKMM251VSN331MR25S EKMM251VSN331MA20S EKMM251VSN391MP40S EKMM251VSN391MQ35S EKMM251VSN391MR25S EKMM251VSN471MP45S EKMM251VSN471MQ35S EKMM251VSN471MR30S EKMM251VSN471MA25S EKMM251VSN561MP50S EKMM251VSN561MQ40S EKMM251VSN561MR30S EKMM251VSN561MA25S EKMM251VSN681MQ50S EKMM251VSN681MR35S EKMM251VSN681MA30S EKMM251VSN821MQ60S EKMM251VSN821MR40S EKMM251VSN821MA35S EKMM251VSN102MR50S EKMM251VSN102MA40S EKMM251VSN122MR60S EKMM251VSN122MA45S EKMM251VSN152MA50S EKMM251VSN182MA60S EKMM3B1VSN680MP20S EKMM3B1VSN820MP20S EKMM3B1VSN101MP25S EKMM3B1VSN101MQ20S EKMM3B1VSN121MP25S EKMM3B1VSN121MQ20S EKMM3B1VSN121MR20S EKMM3B1VSN151MP30S EKMM3B1VSN151MQ25S EKMM3B1VSN151MR20S EKMM3B1VSN151MA20S EKMM3B1VSN181MP35S EKMM3B1VSN181MQ25S EKMM3B1VSN181MR25S EKMM3B1VSN181MA20S EKMM3B1VSN221MP40S WV (Vdc) 315 350 400 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 220 220 220 270 270 270 270 330 330 330 330 390 390 390 470 470 470 560 560 680 680 820 1,000 56 68 82 82 100 100 120 120 120 150 150 150 150 180 180 180 220 220 220 220 270 270 270 270 330 330 330 390 390 390 470 470 470 560 560 680 680 820 47 56 68 68 82 82 25.4× 30 30 × 25 35 × 20 22 × 45 25.4 × 35 30 × 25 35 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 60 22 × 20 25.4 × 20 22 × 25 25.4 × 20 22 × 25 30 × 20 22 × 30 25.4 × 25 30 × 20 22 × 35 25.4 × 30 30 × 25 35 × 20 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 30 35 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 25.4 × 50 30 × 40 35 × 35 25.4 × 60 30 × 45 35 × 35 30 × 50 35 × 40 30 × 60 35 × 50 35 × 60 22 × 20 25.4 × 20 22 × 25 25.4 × 20 22 × 25 30 × 20 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.04 1.04 0.90 1.16 1.16 1.16 1.15 1.33 1.33 1.33 1.33 1.47 1.47 1.47 1.70 1.70 1.70 2.05 2.05 2.17 2.17 2.20 2.55 0.41 0.46 0.55 0.51 0.69 0.60 0.75 0.75 0.65 0.82 0.83 0.82 0.76 0.92 0.92 0.90 1.05 1.04 1.02 1.04 1.16 1.18 1.17 1.20 1.29 1.34 1.22 1.51 1.51 1.47 1.66 1.65 1.69 1.85 1.90 2.15 1.99 2.31 0.37 0.42 0.50 0.46 0.64 0.55 Part No. EKMM3B1VSN221MQ30S EKMM3B1VSN221MR25S EKMM3B1VSN221MA20S EKMM3B1VSN271MP45S EKMM3B1VSN271MQ35S EKMM3B1VSN271MR25S EKMM3B1VSN271MA25S EKMM3B1VSN331MP50S EKMM3B1VSN331MQ40S EKMM3B1VSN331MR30S EKMM3B1VSN331MA25S EKMM3B1VSN391MQ45S EKMM3B1VSN391MR35S EKMM3B1VSN391MA30S EKMM3B1VSN471MQ50S EKMM3B1VSN471MR40S EKMM3B1VSN471MA30S EKMM3B1VSN561MR45S EKMM3B1VSN561MA35S EKMM3B1VSN681MR50S EKMM3B1VSN681MA40S EKMM3B1VSN821MA45S EKMM3B1VSN102MA60S EKMM351VSN560MP20S EKMM351VSN680MQ20S EKMM351VSN820MP25S EKMM351VSN820MQ20S EKMM351VSN101MP25S EKMM351VSN101MR20S EKMM351VSN121MP30S EKMM351VSN121MQ25S EKMM351VSN121MR20S EKMM351VSN151MP35S EKMM351VSN151MQ30S EKMM351VSN151MR25S EKMM351VSN151MA20S EKMM351VSN181MP40S EKMM351VSN181MQ30S EKMM351VSN181MR25S EKMM351VSN221MP45S EKMM351VSN221MQ35S EKMM351VSN221MR30S EKMM351VSN221MA25S EKMM351VSN271MP50S EKMM351VSN271MQ40S EKMM351VSN271MR30S EKMM351VSN271MA25S EKMM351VSN331MQ45S EKMM351VSN331MR35S EKMM351VSN331MA30S EKMM351VSN391MQ50S EKMM351VSN391MR40S EKMM351VSN391MA35S EKMM351VSN471MQ60S EKMM351VSN471MR45S EKMM351VSN471MA35S EKMM351VSN561MR50S EKMM351VSN561MA40S EKMM351VSN681MR60S EKMM351VSN681MA50S EKMM351VSN821MA60S EKMM401VSN470MP20S EKMM401VSN560MQ20S EKMM401VSN680MP25S EKMM401VSN680MQ20S EKMM401VSN820MP25S EKMM401VSN820MR20S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ KMMSeries ◆STANDARD RATINGS WV (Vdc) 400 420 Cap (µF) 100 100 100 120 120 120 120 150 150 150 150 180 180 180 180 220 220 220 220 270 270 270 330 330 330 390 390 390 470 470 560 560 680 47 56 68 68 82 82 82 100 100 100 120 120 120 120 150 150 150 180 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 22 ×30 25.4×25 30 ×20 22 ×35 25.4 ×25 30× 25 35× 20 22 × 40 25.4× 30 30 × 25 35 ×20 22 ×45 25.4×35 30 ×30 35 ×25 22 ×50 25.4 ×40 30× 30 35 × 25 25.4× 45 30 × 35 35 ×30 25.4 ×50 30 ×40 35 × 30 25.4× 60 30 × 45 35 × 35 30 × 50 35 × 40 30 × 60 35 × 45 35 × 60 22 × 20 25.4× 20 22× 25 25.4 × 20 22 × 25 25.4× 25 30× 20 22× 30 25.4× 25 30× 20 22× 35 25.4× 30 30× 25 35× 20 22× 40 25.4× 35 30× 25 22× 45 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.70 0.70 0.60 0.75 0.75 0.73 0.75 0.88 0.88 0.88 0.80 0.98 0.98 0.98 0.98 1.10 1.10 1.10 1.10 1.22 1.22 1.22 1.44 1.44 1.44 1.51 1.60 1.60 1.90 1.90 2.10 2.12 2.27 0.37 0.42 0.50 0.46 0.64 0.58 0.53 0.70 0.70 0.59 0.75 0.75 0.73 0.67 0.88 0.88 0.88 0.95 Part No. EKMM401VSN101MP30S EKMM401VSN101MQ25S EKMM401VSN101MR20S EKMM401VSN121MP35S EKMM401VSN121MQ25S EKMM401VSN121MR25S EKMM401VSN121MA20S EKMM401VSN151MP40S EKMM401VSN151MQ30S EKMM401VSN151MR25S EKMM401VSN151MA20S EKMM401VSN181MP45S EKMM401VSN181MQ35S EKMM401VSN181MR30S EKMM401VSN181MA25S EKMM401VSN221MP50S EKMM401VSN221MQ40S EKMM401VSN221MR30S EKMM401VSN221MA25S EKMM401VSN271MQ45S EKMM401VSN271MR35S EKMM401VSN271MA30S EKMM401VSN331MQ50S EKMM401VSN331MR40S EKMM401VSN331MA30S EKMM401VSN391MQ60S EKMM401VSN391MR45S EKMM401VSN391MA35S EKMM401VSN471MR50S EKMM401VSN471MA40S EKMM401VSN561MR60S EKMM401VSN561MA45S EKMM401VSN681MA60S EKMM421VSN470MP20S EKMM421VSN560MQ20S EKMM421VSN680MP25S EKMM421VSN680MQ20S EKMM421VSN820MP25S EKMM421VSN820MQ25S EKMM421VSN820MR20S EKMM421VSN101MP30S EKMM421VSN101MQ25S EKMM421VSN101MR20S EKMM421VSN121MP35S EKMM421VSN121MQ30S EKMM421VSN121MR25S EKMM421VSN121MA20S EKMM421VSN151MP40S EKMM421VSN151MQ35S EKMM421VSN151MR25S EKMM421VSN181MP45S WV (Vdc) 420 450 Cap (µF) 180 180 180 220 220 220 220 270 270 270 330 330 330 390 390 470 470 560 680 56 68 68 82 82 100 100 100 120 120 120 120 150 150 150 150 180 180 180 220 220 220 270 270 270 330 330 390 390 470 560 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 25.4× 35 30 × 30 35 × 25 22 × 50 25.4 × 45 30 × 35 35 × 25 25.4 × 50 30 × 40 35 × 30 25.4 × 60 30 × 45 35 × 35 30 × 50 35 × 40 30 × 60 35 × 45 35 × 50 35 × 60 22 × 25 22 × 30 25.4 × 25 22 × 30 25.4 × 25 22 × 35 25.4 × 30 30 × 25 22 × 40 25.4 × 30 30 × 25 35 × 25 22 × 45 25.4 × 35 30 × 30 35 × 25 22 × 50 25.4 × 40 30 × 30 25.4 × 45 30 × 35 35 × 30 25.4 × 60 30 × 40 35 × 35 30 × 50 35 × 40 30 × 60 35 × 40 35 × 50 35 × 60 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.95 0.95 0.94 1.10 1.10 1.10 1.10 1.22 1.22 1.22 1.41 1.45 1.45 1.55 1.55 1.79 1.90 2.15 2.27 0.40 0.53 0.50 0.64 0.64 0.69 0.69 0.64 0.80 0.80 0.80 0.73 0.88 0.88 0.88 0.75 1.00 1.00 1.00 1.12 1.12 1.12 1.18 1.28 1.28 1.45 1.45 1.51 1.55 1.85 1.91 Part No. EKMM421VSN181MQ35S EKMM421VSN181MR30S EKMM421VSN181MA25S EKMM421VSN221MP50S EKMM421VSN221MQ45S EKMM421VSN221MR35S EKMM421VSN221MA25S EKMM421VSN271MQ50S EKMM421VSN271MR40S EKMM421VSN271MA30S EKMM421VSN331MQ60S EKMM421VSN331MR45S EKMM421VSN331MA35S EKMM421VSN391MR50S EKMM421VSN391MA40S EKMM421VSN471MR60S EKMM421VSN471MA45S EKMM421VSN561MA50S EKMM421VSN681MA60S EKMM451VSN560MP25S EKMM451VSN680MP30S EKMM451VSN680MQ25S EKMM451VSN820MP30S EKMM451VSN820MQ25S EKMM451VSN101MP35S EKMM451VSN101MQ30S EKMM451VSN101MR25S EKMM451VSN121MP40S EKMM451VSN121MQ30S EKMM451VSN121MR25S EKMM451VSN121MA25S EKMM451VSN151MP45S EKMM451VSN151MQ35S EKMM451VSN151MR30S EKMM451VSN151MA25S EKMM451VSN181MP50S EKMM451VSN181MQ40S EKMM451VSN181MR30S EKMM451VSN221MQ45S EKMM451VSN221MR35S EKMM451VSN221MA30S EKMM451VSN271MQ60S EKMM451VSN271MR40S EKMM451VSN271MA35S EKMM451VSN331MR50S EKMM451VSN331MA40S EKMM451VSN391MR60S EKMM451VSN391MA40S EKMM451VSN471MA50S EKMM451VSN561MA60S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 160 to 250Vdc 315 to 450Vdc 50 0.81 0.77 120 1.00 1.00 300 1.17 1.16 1k 1.32 1.30 10k 1.45 1.41 50k 1.50 1.43 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKMM161VSN222MA45S 价格&库存
很抱歉,暂时无法提供与“EKMM161VSN222MA45S”相匹配的价格&库存,您可以联系我们找货
