EMVH350ARA101MHA0G
EMVH350ARA101MHA0G
    NCC(贵弥功)
    SMD,D8xL10mm
    贴片铝电解电容 AEC_D8X10MM_SM
EMVH350ARA101MHA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip MVH - High heat resistance, 125℃ Series MVH ・Lower ESR, Higher ripple current ・Endurance : 1,000 to 5,000 hours at 125℃ ・Suitable to fit for automotive equipment ・Solvent resistant type except 63 to 450Vdc (see PRECAUTIONS AND GUIDELINES) ・Vibration resistant structure ・RoHS Compliant 125℃ MVE P70 ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life -40 to +125℃ 10 to 450Vdc ±20% (M) (at 20℃, 120Hz) 10 to 100Vdc Rated voltage (Vdc) 160 to 450Vdc F60 to JA0 I=0.01CV or 3µA, whichever is greater. I=0.04CV+100 KE0 to MN0 I=0.03CV or 4µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 80V 100V 160 to 250V 400 & 450V 0.24 0.20 0.16 0.14 0.14 0.12 0.12 0.10 F60 to JA0 tanδ (Max.) 0.22 0.18 0.16 0.14 0.12 0.14 0.10 0.20 0.24 KE0 to MN0 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 80V 100V 160 to 250V 400 & 450V Z(-25℃)/Z(+20℃) 3 2 2 2 2 2 2 2 F60 to JA0 Z(-40℃)/Z(+20℃) 6 3 3 3 4 4 3 3 Z(-25℃)/Z(+20℃) 4 2 2 2 2 3 2 3 6 KE0 to MN0 Z(-40℃)/Z(+20℃) 8 3 3 3 4 6 3 (at 120Hz) 6 10 The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for the specified time at 125℃. F60 to H63 (10 to 100Vdc) : 1,000hours HA0 to JA0 (10 to 100Vdc) : 2,000hours Time KE0 to MN0 (10 to 100Vdc) : 5,000hours KE0 to MN0 (160 to 450Vdc) : 2,000hours Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours (500 hours for 400 to 450Vdc) at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage(Vdc) 10 to 50Vdc 63 to 450Vdc Capacitance change ≦±30% of the initial value ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value ≦300% of the initial specified value Leakage current ≦The initial specified value ≦500% of the initial specified value ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size Vent (Except HA0) 0.3max. L±0.5 (Note) φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. A±0.2 L±0.5 A±0.2 W B±0.2 Vent (Except F60 to HA0) Code : G(Vibration resistant structure) code : HA0 to MN0 Size code P C±0.2 Code : A code : F60 to MN0 Note : L±0.3 for F60 and F80 : Dummy terminals F60 F80 H63 HA0 JA0 KE0 KG5 LH0 LN0 MH0 MN0 D 6.3 6.3 8 8 10 12.5 12.5 16 16 18 18 L 5.7 7.7 6.3 10.0 10.0 13.5 16.0 16.5 21.5 16.5 21.5 A 6.6 6.6 8.3 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 B 6.6 6.6 8.3 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 C 7.2 7.2 9.0 9.0 11.0 13.7 13.7 18.0 18.0 20.0 20.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.9 1.9 2.3 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ◆MARKING 18 E MV H AAA A AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 4.7µF:4R7,10µF:100) Taping·Tray code Terminal code (A, G) Voltage code (ex. 10V:100,50V:500, 100V: 101) Series code Category F60 to JA0 EX) 35V47µF 74H 47 35V KE0 to MN0 EX) 16V1,000µF 0V MVH 1000 16V Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 94 CAT. No. E1001N SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip High heat resistance, 125℃ MVHSeries - ◆STANDARD RATINGS WV Cap (Vdc) (µF) Size code 100 100 220 220 220 330 330 470 1,000 2,200 2,200 3,300 4,700 47 100 220 220 330 470 680 680 1,000 2,200 33 47 47 100 100 100 220 220 330 330 470 470 680 680 1,000 10 22 33 33 47 47 47 100 100 220 330 330 470 470 680 10 10 22 22 F80 H63 F80 H63 HA0 HA0 JA0 JA0 KE0 LH0 MH0 MH0 MN0 F60 HA0 HA0 JA0 JA0 KE0 KE0 LH0 MH0 MH0 F60 F80 H63 F80 H63 HA0 HA0 JA0 JA0 KE0 KE0 LH0 LH0 MH0 MN0 F60 F60 F80 H63 F80 H63 HA0 HA0 JA0 JA0 KE0 LH0 KG5 LH0 MH0 F60 H63 F80 H63 10 16 25 35 50 ESR (Ωmax/ 100kHz) is not solvent resistant (63 to 450Vdc). Rated ripple current (mArms/125℃) 20℃ -40℃ 100kHz 120Hz 0.90 0.90 0.90 0.90 0.40 0.40 0.30 0.30 0.14 0.10 0.10 0.10 0.058 1.6 0.40 0.40 0.30 0.30 0.14 0.14 0.10 0.10 0.10 1.6 0.90 0.90 0.90 0.90 0.40 0.40 0.30 0.30 0.14 0.14 0.10 0.10 0.10 0.058 1.6 1.6 0.90 0.90 0.90 0.90 0.40 0.40 0.30 0.30 0.14 0.10 0.11 0.10 0.10 2.8 1.6 2.0 1.6 14.0 14.0 14.0 14.0 6.0 6.0 4.5 4.5 2.1 1.5 1.5 1.5 0.87 24.0 6.0 6.0 4.5 4.5 2.1 2.1 1.5 1.5 1.5 24.0 14.0 14.0 14.0 14.0 6.0 6.0 4.5 4.5 2.1 2.1 1.5 1.5 1.5 0.87 24.0 24.0 14.0 14.0 14.0 14.0 6.0 6.0 4.5 4.5 2.1 1.5 1.5 1.5 1.5 42.0 30.0 30.0 30.0 110 110 110 110 220 220 296 296 750 1,000 1,200 1,200 1,550 69 220 220 296 296 750 750 1,000 1,200 1,200 69 110 110 110 110 220 220 296 296 750 750 1,000 1,000 1,200 1,550 69 69 110 110 110 110 220 220 296 296 750 1,000 900 1,000 1,200 51 83 83 83 - Part No. EMVH100ADA101MF80G EMVH100ADA101MH63G EMVH100ADA221MF80G EMVH100ADA221MH63G EMVH100ADA221MHA0G EMVH100ADA331MHA0G EMVH100ADA331MJA0G EMVH100ADA471MJA0G EMVH100ARA102MKE0S EMVH100□DA222MLH0S EMVH100□DA222MMH0S EMVH100□DA332MMH0S EMVH100□DA472MMN0S EMVH160ADA470MF60G EMVH160ADA101MHA0G EMVH160ADA221MHA0G EMVH160ADA221MJA0G EMVH160ADA331MJA0G EMVH160ARA471MKE0S EMVH160ARA681MKE0S EMVH160□DA681MLH0S EMVH160□DA102MMH0S EMVH160□DA222MMH0S EMVH250ADA330MF60G EMVH250ADA470MF80G EMVH250ADA470MH63G EMVH250ADA101MF80G EMVH250ADA101MH63G EMVH250ADA101MHA0G EMVH250ADA221MHA0G EMVH250ADA221MJA0G EMVH250ADA331MJA0G EMVH250ARA331MKE0S EMVH250ARA471MKE0S EMVH250□DA471MLH0S EMVH250□DA681MLH0S EMVH250□DA681MMH0S EMVH250□DA102MMN0S EMVH350ADA100MF60G EMVH350ADA220MF60G EMVH350ADA330MF80G EMVH350ADA330MH63G EMVH350ADA470MF80G EMVH350ADA470MH63G EMVH350ADA470MHA0G EMVH350ADA101MHA0G EMVH350ADA101MJA0G EMVH350ADA221MJA0G EMVH350ARA331MKE0S EMVH350□DA331MLH0S EMVH350ARA471MKG5S EMVH350□DA471MLH0S EMVH350□DA681MMH0S EMVH500ADA100MF60G EMVH500ADA100MH63G EMVH500ADA220MF80G EMVH500ADA220MH63G WV Cap (Vdc) (µF) 50 63 80 100 160 200 250 400 450 33 33 33 47 47 100 100 220 220 330 330 470 10 10 22 33 33 47 47 100 220 330 470 10 22 22 33 33 47 10 22 22 33 47 68 100 220 10 22 33 68 10 22 33 33 47 10 22 22 33 4.7 6.8 10 10 3.3 4.7 10 Size code F80 H63 HA0 HA0 JA0 JA0 KE0 KE0 LH0 KG5 LH0 MH0 F80 H63 HA0 HA0 JA0 HA0 JA0 KE0 KG5 LH0 LN0 HA0 HA0 JA0 HA0 JA0 JA0 HA0 HA0 JA0 JA0 KE0 KG5 LH0 MN0 KE0 LH0 MH0 MN0 KE0 LH0 LN0 MH0 MN0 KG5 LN0 MH0 MN0 KE0 LH0 LN0 MH0 KG5 LH0 MN0 ESR (Ωmax/ 100kHz) Rated ripple current (mArms/125℃) 20℃ -40℃ 100kHz 120Hz 2.0 1.6 0.70 0.70 0.50 0.50 0.23 0.23 0.15 0.18 0.15 0.15 2.0 2.0 0.70 0.70 0.50 0.70 0.50 0.25 0.20 0.18 0.11 0.75 0.75 0.55 0.75 0.55 0.55 0.75 0.75 0.55 0.55 0.33 0.26 0.24 0.16 - 30.0 83 30.0 83 11.0 160 11.0 160 7.5 247 7.5 247 3.5 550 3.5 550 2.3 850 2.7 700 2.3 850 2.3 920 100 60 110 60 35.0 100 35.0 100 25.0 170 35.0 100 25.0 170 12.5 500 10.0 600 9.0 820 5.5 1,100 50.0 70 50.0 70 35.0 115 50.0 70 35.0 115 35.0 115 50.0 70 50.0 70 35.0 115 35.0 115 16.5 450 13.0 550 12.0 650 8.0 950 - 100 180 245 380 100 180 250 245 315 110 200 205 260 70 100 140 135 65 85 145 Part No. EMVH500ADA330MF80G EMVH500ADA330MH63G EMVH500ADA330MHA0G EMVH500ADA470MHA0G EMVH500ADA470MJA0G EMVH500ADA101MJA0G EMVH500ARA101MKE0S EMVH500ARA221MKE0S EMVH500□DA221MLH0S EMVH500ARA331MKG5S EMVH500□DA331MLH0S EMVH500□DA471MMH0S EMVH630ADA100MF80G EMVH630ADA100MH63G EMVH630ADA220MHA0G EMVH630ADA330MHA0G EMVH630ADA330MJA0G EMVH630ADA470MHA0G EMVH630ADA470MJA0G EMVH630ARA101MKE0S EMVH630ARA221MKG5S EMVH630□DA331MLH0S EMVH630□DA471MLN0S EMVH800ADA100MHA0G EMVH800ADA220MHA0G EMVH800ADA220MJA0G EMVH800ADA330MHA0G EMVH800ADA330MJA0G EMVH800ADA470MJA0G EMVH101ADA100MHA0G EMVH101ADA220MHA0G EMVH101ADA220MJA0G EMVH101ADA330MJA0G EMVH101ARA470MKE0S EMVH101ARA680MKG5S EMVH101□DA101MLH0S EMVH101□DA221MMN0S EMVH161ARA100MKE0S EMVH161□DA220MLH0S EMVH161□DA330MMH0S EMVH161□DA680MMN0S EMVH201ARA100MKE0S EMVH201□DA220MLH0S EMVH201□DA330MLN0S EMVH201□DA330MMH0S EMVH201□DA470MMN0S EMVH251ARA100MKG5S EMVH251□DA220MLN0S EMVH251□DA220MMH0S EMVH251□DA330MMN0S EMVH401ARA4R7MKE0S EMVH401□DA6R8MLH0S EMVH401□DA100MLN0S EMVH401□DA100MMH0S EMVH451ARA3R3MKG5S EMVH451□DA4R7MLH0S EMVH451□DA100MMN0S □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Rated voltage (Vdc) Size code F60 to JA0 10 to 100 160 to 450 KE0 to MN0 KE0 to MN0 Frequency(Hz) Capacitance(μF) 10 22 to 470 47 to 100 220 to 470 680 to 1,000 2,200 to 3,300 4,700 3.3 to 33 47 to 68 120 1k 10k 100k 0.66 0.93 0.40 0.50 0.60 0.75 0.85 1.00 1.00 0.86 0.97 0.75 0.85 0.87 0.90 0.95 1.50 1.30 0.93 1.00 0.90 0.94 0.95 0.95 0.98 1.75 1.40 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.80 1.50 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 95 CAT. No. E1001N
EMVH350ARA101MHA0G 价格&库存
很抱歉,暂时无法提供与“EMVH350ARA101MHA0G”相匹配的价格&库存,您可以联系我们找货
EMVH350ARA101MHA0G
  • 1+10.489971+1.35856
  • 10+6.6916210+0.86664
  • 50+5.0972350+0.66015
  • 100+4.59480100+0.59508
库存:456
EMVH350ARA101MHA0G
  • 500+3.72716500+0.48271
  • 1000+3.453951000+0.44733
  • 1500+3.315991500+0.42946
  • 2500+3.162242500+0.40955
  • 3500+3.071843500+0.39784
  • 5000+2.984535000+0.38653
库存:456
