SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
2000-hours-life, 105℃
MVJ
MVL
Series
longer life
MVJ
・Endurance : 2,000 hours at 105℃
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
longer life
MVE
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 50Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.01CV or 3μA, whichever is greater.
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V
tanδ (Max.)
0.30 0.24 0.20 0.16 0.14 0.12
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
Z(-40℃)/Z(+20℃)
12
8
6
4
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours
at 105℃.
Rated voltage
6.3Vdc
10 & 16Vdc
25 to 50Vdc
Capacitance change
≦±30% of the initial value
≦±25% of the initial value
≦±20% of the initial value
D.F. (tanδ)
≦300% of the initial specified value ≦300% of the initial specified value ≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Rated voltage
6.3Vdc
10 & 16Vdc
25 to 50Vdc
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
●Terminal
◆PART NUMBERING SYSTEM
Code : A
1
2
3
4
5
6
7
8
9
10
L
5.7
5.7
5.7
A±0.2
A
4.3
5.3
6.6
14
15 16
◆MARKING
17
EX) 6.3V100µF
18
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,10µF:100)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
P
C±0.2
B±0.2
φD±0.5
0.3max.
L±0.3
D
4
5
6.3
13
E MV J AAA A RA AAA M AAA G
W
Size code
D60
E60
F60
11 12
B
4.3
5.3
6.6
C
5.1
5.9
7.2
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
P
1.0
1.4
1.9
7hJ
100
6.3V
Please refer to "Product code guide (surface mount type)"
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
Cap
(µF)
Size code tanδ
22
47
100
33
10
22
47
33
D60
E60
F60
E60
D60
E60
F60
F60
0.30
0.30
0.30
0.24
0.20
0.20
0.20
0.16
Rated ripple
current
(mArms/
105℃,120Hz)
Part No.
21
36
56
34
16
30
48
45
EMVJ6R3ARA220MD60G
EMVJ6R3ARA470ME60G
EMVJ6R3ARA101MF60G
EMVJ100ARA330ME60G
EMVJ160ARA100MD60G
EMVJ160ARA220ME60G
EMVJ160ARA470MF60G
EMVJ250ARA330MF60G
WV
(Vdc)
35
50
Cap
(µF)
4.7
10
22
1.0
2.2
3.3
4.7
10
Size code tanδ
D60
E60
F60
D60
D60
D60
E60
F60
0.14
0.14
0.14
0.12
0.12
0.12
0.12
0.12
Rated ripple
current
(mArms/
105℃,120Hz)
15
25
40
5.6
10
14
19
29
Part No.
EMVJ350ARA4R7MD60G
EMVJ350ARA100ME60G
EMVJ350ARA220MF60G
EMVJ500ARA1R0MD60G
EMVJ500ARA2R2MD60G
EMVJ500ARA3R3MD60G
EMVJ500ARA4R7ME60G
EMVJ500ARA100MF60G
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
1.0
2.2 to 10
22 to 100
120
1.00
1.00
1.00
1k
1.50
1.30
1.05
10k
1.75
1.40
1.08
100k
1.80
1.50
1.08
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
很抱歉,暂时无法提供与“EMVJ500ADA100MF60G”相匹配的价格&库存,您可以联系我们找货
