EKMG401ELL121MMN3S
EKMG401ELL121MMN3S
    NCC(贵弥功)
EKMG401ELL121MMN3S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KMG Series Standard, 105℃ KMQ Downsized ・Endurance with ripple current : 1,000 to 2,000 hours at 105℃ ・Solvent resistant type except 350 to 450Vdc (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant KMG ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃(6.3 to 100Vdc) -40 to +105℃(160 to 400Vdc) -25 to +105℃(450Vdc) 6.3 to 450Vdc ±20% (M) 6.3 to 100Vdc I=0.03CV or 4µA, whichever is greater. (at 20℃, 120Hz) 160 to 450Vdc Time After 1minute After 5minutes CV CV≦1,000 I=0.1CV+40 max. I=0.03CV+15 max. (after 1 minute) CV>1,000 I=0.04CV+100 max. I=0.02CV+25 max. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V tanδ (Max.) 0.34 0.24 0.20 0.16 0.14 0.12 0.10 0.08 0.20 0.24 0.24 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V Z(-25℃)/Z(+20℃) 5 4 3 2 2 2 2 2 3 6 6 Z(-40℃)/Z(+20℃) 12 10 8 5 4 3 3 3 4 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 1,000 hours (2,000 hours to meet the following two conditions 1): 160Vdc and larger, 2) :φ12.5 and larger) at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3 to 100Vcd 160 to 450Vdc Capacitance change ≦±20% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] F±0.5 Code : E φD' φd Sleeve (PET : Brown) F±0.5 ●Terminal L' 15min. 4min. (φ5 toφ10) Vent (exceptφ5) (φ12.5 to φ18) φD φd F φD' L' 5 0.5 2.0 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max L+1.5max 16 0.8 7.5 18 0.8 7.5 Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KMG A A A E A A A A A M A A A N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3,35V:350,100V:101) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Standard, 105℃ KMGSeries ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 50 Cap (µF) 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 22,000 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 100 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 47 100 220 330 470 1,000 2,200 3,300 4,700 6,800 47 100 220 330 470 1,000 2,200 3,300 4,700 1.0 2.2 3.3 4.7 10 22 33 47 100 220 330 470 1,000 2,200 3,300 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 5 ×11 6.3×11 6.3×11 8 ×11.5 10 ×20 10 ×20 12.5× 20 12.5× 25 16 ×25 16 ×35.5 18 ×40 6.3×11 6.3×11 8 ×11.5 10 ×12.5 10 ×20 12.5× 20 12.5× 25 16 ×25 16 ×35.5 18 ×35.5 5 ×11 6.3×11 8 ×11.5 8 ×11.5 10 ×16 12.5× 20 12.5× 25 16 ×25 16 ×31.5 18 ×35.5 5 ×11 6.3×11 8 ×11.5 8 ×11.5 10 ×12.5 10 ×20 12.5× 25 16 ×25 16 ×31.5 18 ×35.5 5 ×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 12.5× 20 16 ×25 16 ×35.5 18 ×35.5 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 10 ×20 12.5× 25 16 ×35.5 18 ×35.5 0.34 0.34 0.34 0.34 0.36 0.38 0.40 0.44 0.52 0.62 0.76 0.24 0.24 0.24 0.24 0.26 0.28 0.30 0.34 0.42 0.52 0.20 0.20 0.20 0.20 0.20 0.22 0.24 0.26 0.30 0.38 0.16 0.16 0.16 0.16 0.16 0.16 0.18 0.20 0.22 0.26 0.14 0.14 0.14 0.14 0.14 0.14 0.16 0.18 0.20 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.16 140 190 230 380 710 840 1,090 1,350 1,650 2,010 2,350 170 200 250 460 760 1,000 1,260 1,570 1,890 2,180 110 180 260 310 560 920 1,170 1,480 1,780 2,060 80 130 230 310 380 680 1,090 1,400 1,710 2,040 90 150 270 350 460 810 1,260 1,610 1,910 13 20 25 30 40 65 90 110 180 300 410 530 950 1,470 1,770 Part No. EKMG6R3E□□221ME11D EKMG6R3E□□331MF11D EKMG6R3E□□471MF11D EKMG6R3E□□102MHB5D EKMG6R3E□□222MJ20S EKMG6R3E□□332MJ20S EKMG6R3E□□472MK20S EKMG6R3E□□682MK25S EKMG6R3E□□103ML25S EKMG6R3E□□153MLP1S EKMG6R3E□□223MM40S EKMG100E□□221MF11D EKMG100E□□331MF11D EKMG100E□□471MHB5D EKMG100E□□102MJC5S EKMG100E□□222MJ20S EKMG100E□□332MK20S EKMG100E□□472MK25S EKMG100E□□682ML25S EKMG100E□□103MLP1S EKMG100E□□153MMP1S EKMG160E□□101ME11D EKMG160E□□221MF11D EKMG160E□□331MHB5D EKMG160E□□471MHB5D EKMG160E□□102MJ16S EKMG160E□□222MK20S EKMG160E□□332MK25S EKMG160E□□472ML25S EKMG160E□□682MLN3S EKMG160E□□103MMP1S EKMG250E□□470ME11D EKMG250E□□101MF11D EKMG250E□□221MHB5D EKMG250E□□331MHB5D EKMG250E□□471MJC5S EKMG250E□□102MJ20S EKMG250E□□222MK25S EKMG250E□□332ML25S EKMG250E□□472MLN3S EKMG250E□□682MMP1S EKMG350E□□470ME11D EKMG350E□□101MF11D EKMG350E□□221MHB5D EKMG350E□□331MJC5S EKMG350E□□471MJ16S EKMG350E□□102MK20S EKMG350E□□222ML25S EKMG350E□□332MLP1S EKMG350E□□472MMP1S EKMG500E□□1R0ME11D EKMG500E□□2R2ME11D EKMG500E□□3R3ME11D EKMG500E□□4R7ME11D EKMG500E□□100ME11D EKMG500E□□220ME11D EKMG500E□□330ME11D EKMG500E□□470MF11D EKMG500E□□101MHB5D EKMG500E□□221MJC5S EKMG500E□□331MJ16S EKMG500E□□471MJ20S EKMG500E□□102MK25S EKMG500E□□222MLP1S EKMG500E□□332MMP1S □□ : Enter the appropriate lead forming or taping code. WV (Vdc) 63 100 160 200 250 350 400 Cap (µF) 10 22 33 47 100 220 330 470 1,000 1.0 2.2 3.3 4.7 10 22 33 47 100 220 330 470 1,000 3.3 4.7 10 22 33 47 100 220 330 3.3 4.7 10 22 33 47 100 220 2.2 3.3 4.7 10 22 33 47 100 220 1.0 2.2 3.3 4.7 10 22 33 47 100 1.0 2.2 3.3 4.7 10 22 33 47 100 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 5× 11 5× 11 6.3 × 11 6.3 × 11 10 × 12.5 10 × 16 10 × 20 12.5 × 20 16 × 25 5 × 11 5 × 11 5× 11 5× 11 6.3 × 11 8 × 11.5 8 × 11.5 10 × 12.5 10 × 20 12.5 × 25 16 × 25 16 × 31.5 18 × 40 6.3 × 11 6.3 × 11 10 × 12.5 10 × 20 10 × 20 12.5 × 20 16 × 25 16 × 31.5 18 × 35.5 6.3 × 11 8× 11.5 10 × 16 10 × 20 12.5 × 20 12.5 × 20 16 × 25 18 × 35.5 6.3 × 11 8 × 11.5 8× 11.5 10 × 16 12.5× 20 12.5 × 20 12.5 × 25 16 × 31.5 18 × 40 6.3 × 11 8 × 11.5 10 × 12.5 10 × 16 10 × 20 12.5× 20 16 × 25 16 × 25 18 × 31.5 6.3 × 11 8× 11.5 10 × 12.5 10 × 16 10 × 20 12.5 × 25 16 × 25 16 × 31.5 16 × 40 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 46 71 100 120 215 335 510 640 930 15 21 29 32 54 93 130 165 265 440 540 715 985 28 34 67 120 145 195 335 540 705 28 39 74 120 160 195 335 575 23 32 39 74 130 160 210 365 585 15 26 38 50 80 130 195 230 375 15 26 38 50 80 145 195 250 350 Part No. EKMG630E□□100ME11D EKMG630E□□220ME11D EKMG630E□□330MF11D EKMG630E□□470MF11D EKMG630E□□101MJC5S EKMG630E□□221MJ16S EKMG630E□□331MJ20S EKMG630E□□471MK20S EKMG630E□□102ML25S EKMG101E□□1R0ME11D EKMG101E□□2R2ME11D EKMG101E□□3R3ME11D EKMG101E□□4R7ME11D EKMG101E□□100MF11D EKMG101E□□220MHB5D EKMG101E□□330MHB5D EKMG101E□□470MJC5S EKMG101E□□101MJ20S EKMG101E□□221MK25S EKMG101E□□331ML25S EKMG101E□□471MLN3S EKMG101E□□102MM40S EKMG161E□□3R3MF11D EKMG161E□□4R7MF11D EKMG161E□□100MJC5S EKMG161E□□220MJ20S EKMG161E□□330MJ20S EKMG161E□□470MK20S EKMG161E□□101ML25S EKMG161E□□221MLN3S EKMG161E□□331MMP1S EKMG201E□□3R3MF11D EKMG201E□□4R7MHB5D EKMG201E□□100MJ16S EKMG201E□□220MJ20S EKMG201E□□330MK20S EKMG201E□□470MK20S EKMG201E□□101ML25S EKMG201E□□221MMP1S EKMG251E□□2R2MF11D EKMG251E□□3R3MHB5D EKMG251E□□4R7MHB5D EKMG251E□□100MJ16S EKMG251E□□220MK20S EKMG251E□□330MK20S EKMG251E□□470MK25S EKMG251E□□101MLN3S EKMG251E□□221MM40S EKMG351E□□1R0MF11D EKMG351E□□2R2MHB5D EKMG351E□□3R3MJC5S EKMG351E□□4R7MJ16S EKMG351E□□100MJ20S EKMG351E□□220MK20S EKMG351E□□330ML25S EKMG351E□□470ML25S EKMG351E□□101MMN3S EKMG401E□□1R0MF11D EKMG401E□□2R2MHB5D EKMG401E□□3R3MJC5S EKMG401E□□4R7MJ16S EKMG401E□□100MJ20S EKMG401E□□220MK25S EKMG401E□□330ML25S EKMG401E□□470MLN3S EKMG401E□□101ML40S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Standard, 105℃ KMGSeries ◆STANDARD RATINGS is not solvent resistant. WV (Vdc) Cap (µF) Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 450 2.2 3.3 4.7 10 22 33 47 10×12.5 10 ×16 10 ×20 12.5 ×20 16 ×25 16 ×31.5 16 ×35.5 0.24 0.24 0.24 0.24 0.24 0.24 0.24 23 31 40 65 115 155 185 Part No. EKMG451E□□2R2MJC5S EKMG451E□□3R3MJ16S EKMG451E□□4R7MJ20S EKMG451E□□100MK20S EKMG451E□□220ML25S EKMG451E□□330MLN3S EKMG451E□□470MLP1S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) 1.0 10 100 2,200 Frequency(Hz) to 4.7 to 47 to 1,000 to 50 0.65 0.75 0.80 0.85 120 1.00 1.00 1.00 1.00 300 1.35 1.25 1.15 1.03 1k 1.75 1.50 1.30 1.05 10k 2.30 1.75 1.40 1.08 100k 2.50 1.80 1.50 1.08 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKMG401ELL121MMN3S 价格&库存
很抱歉,暂时无法提供与“EKMG401ELL121MMN3S”相匹配的价格&库存,您可以联系我们找货
