ERWE451LGC472MED0M
ERWE451LGC472MED0M
    NCC(贵弥功)
    螺栓,D76.2xL130mm
    容值:4700uF;精度:±20%;额定电压:450V;电容体直径:76.2mm;电容体长度:130mm;螺栓类型:-;脚间距:31.5mm;纹波电流:13.3A@120Hz;等效串联电阻:-;工作寿...
ERWE451LGC472MED0M 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminal, 85℃ RWE RWF P7-12 Series Longer life ・Rated voltage range : 350 to 550Vdc ・Endurance with ripple current : 85℃ 2,000 hours ・RoHS2 Compliant RWE ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +85℃ 350 to 550Vdc ±20% (M) I=0.02CV or 5mA, whichever is smaller. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Dissipation Factor (tanδ) Low Temperature Characteristics (at 20℃, 120Hz) (at 20℃ after 5 minutes) 0.25 max. (at 20℃, 120Hz) Rated Voltage (Vdc) 350 to 450V 500 & 550V C(-25℃)/C(+20℃) (at 120Hz) ≧0.7 ≧0.6 When measured between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case by using an insulation resistance meter of 500Vdc, the insulation resistance shall not be less than 100MΩ. When a voltage of 2,000Vac is applied for 1 minute between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case, there shall not be electrical damage. The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 85℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 85℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Capacitance change Insulation Resistance Insulation Withstanding Voltage Endurance Shelf Life ◆DIMENSIONS (Screw-Mount) [mm] ● Mounting Clamp Code : B ● Mounting 450±50 H B±1 F ±1 φD+1.8max. Sleeve (Pb-free PVC : Black) Vent 6 300±50 8 J G±1 L+4max. Plastic disk φD 35 50 63.5 76.2 φ35 to φ63.5 : G=6 φ76.2 & φ89 : G=5 A 58.0 78.0 90.0 104.5 B 44.0 64.0 76.0 90.0 Clamp Code : C 3600 3 A±1 W±1 W 48.0 68.0 80.0 93.5 H 3.5 4.5 4.5 4.5 F 12.7 22.4 28.0 31.5 φD 50 63.5 76.2 89 4.5 Code : LG K±1 E±1 ● Terminal E 32.5 38.1 44.5 50.8 K 37.0 43.5 50.0 56.5 F 22.4 28.0 31.5 31.5 J 14.0 14.0 14.0 16.0 Plus hexagon-headed screw :M5×0.8×10 Maximum screw tightening torque :3.23Nm * The screw and the mounting clamp are separately supplied and not attached to the product. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E RWE A A A L G N A A A M A A A M Supplement code Size code Capacitance tolerance code Capacitance code (ex. 680µF:681, 6,800µF:682) Mounting clamp code (N, B, C) Terminal code Voltage code (ex. 350V:351, 500V:501) Series code Category Please refer to "Product code guide (screw-mount terminal type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 7-18 CAT. No. E1001R LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminal, 85℃ RWESeries ◆STANDARD RATINGS WV (Vdc) 350 400 450 Cap (µF) 390 680 1,000 1,200 1,500 2,200 3,300 3,300 3,900 4,700 4,700 5,600 6,800 8,200 12,000 330 560 820 1,000 1,200 1,800 2,200 2,700 3,300 3,900 3,900 4,700 5,600 6,800 10,000 270 470 680 820 1,000 1,200 1,500 1,800 2,200 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 130 63.5 × 96 63.5 × 115 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 130 63.5 × 96 63.5 × 115 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 115 50 × 130 63.5 × 96 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 1.90 2.90 3.80 4.20 4.70 6.30 8.80 8.80 10.3 12.0 11.7 12.6 15.9 19.0 22.5 1.70 2.70 3.40 3.90 4.20 5.70 7.20 7.90 9.50 10.9 10.6 12.6 14.5 17.3 20.5 1.60 2.40 3.10 3.50 3.90 4.70 5.60 6.50 7.20 WV (Vdc) Part No. ERWE351LGB391MA50M ERWE351LGB681MA80M ERWE351LGB102MAA0M ERWE351LGB122MAC0M ERWE351LGC152MC75M ERWE351LGC222MC96M ERWE351LGC332MCD0M ERWE351LGC332MD96M ERWE351LGC392MDB5M ERWE351LGC472MDD0M ERWE351LGC472ME96M ERWE351LGC562MEB5M ERWE351LGC682MED0M ERWE351LGC822MEF5M ERWE351LGC123MFF5M ERWE401LGB331MA50M ERWE401LGB561MA80M ERWE401LGB821MAA0M ERWE401LGB102MAC0M ERWE401LGC122MC75M ERWE401LGC182MC96M ERWE401LGC222MCD0M ERWE401LGC272MD96M ERWE401LGC332MDB5M ERWE401LGC392MDD0M ERWE401LGC392ME96M ERWE401LGC472MEB5M ERWE401LGC562MED0M ERWE401LGC682MEF5M ERWE401LGC103MFF5M ERWE451LGB271MA50M ERWE451LGB471MA80M ERWE451LGB681MAA0M ERWE451LGB821MAC0M ERWE451LGC102MC75M ERWE451LGC122MC96M ERWE451LGC152MCB5M ERWE451LGC182MCD0M ERWE451LGC222MD96M 450 500 550 Cap (µF) Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 2,700 3,300 3,300 3,900 4,700 5,600 8,200 120 270 330 390 470 680 820 1,000 1,000 1,500 1,500 1,800 2,200 2,700 3,900 100 180 270 330 390 560 560 680 680 820 820 1,200 1,500 1,800 2,200 3,300 63.5 × 115 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 50 × 115 50 × 130 63.5 × 96 63.5 × 115 76.2 × 96 63.5 × 130 76.2 × 115 76.2 × 155 89 × 155 35 × 50 35 × 80 35 × 100 35 × 120 50 × 75 50 × 96 63.5 × 96 50 × 115 63.5 × 115 50 × 130 63.5 × 130 76.2 × 96 76.2 × 115 76.2 × 130 76.2 × 155 89 × 155 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 8.60 10.0 9.80 11.5 13.3 15.7 18.6 0.70 1.20 1.40 1.70 1.80 2.50 2.90 3.40 3.40 4.50 4.60 5.20 6.10 7.70 10.1 0.60 1.00 1.30 1.60 1.70 2.10 2.50 2.70 3.00 3.10 3.50 4.20 5.00 5.80 7.00 9.30 Part No. ERWE451LGC272MDB5M ERWE451LGC332MDD0M ERWE451LGC332ME96M ERWE451LGC392MEB5M ERWE451LGC472MED0M ERWE451LGC562MEF5M ERWE451LGC822MFF5M ERWE501LGB121MA50M ERWE501LGB271MA80M ERWE501LGB331MAA0M ERWE501LGB391MAC0M ERWE501LGC471MC75M ERWE501LGC681MC96M ERWE501LGC821MCB5M ERWE501LGC102MCD0M ERWE501LGC102MD96M ERWE501LGC152MDB5M ERWE501LGC152ME96M ERWE501LGC182MDD0M ERWE501LGC222MEB5M ERWE501LGC272MEF5M ERWE501LGC392MFF5M ERWE551LGB101MA50M ERWE551LGB181MA80M ERWE551LGB271MAA0M ERWE551LGB331MAC0M ERWE551LGC391MC75M ERWE551LGC561MC96M ERWE551LGC561MD96M ERWE551LGC681MCB5M ERWE551LGC681MDB5M ERWE551LGC821MCD0M ERWE551LGC821MDD0M ERWE551LGC122ME96M ERWE551LGC152MEB5M ERWE551LGC182MED0M ERWE551LGC222MEF5M ERWE551LGC332MFF5M ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency (Hz) Coefficient 50 0.8 120 1.0 300 1.1 1k 1.3 3k 1.4 Note : The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5 to 10℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Also, for the RWE series capacitors, using them at operating voltage less than their rated voltage can extend their lifetime. For details, please contact a representative of Nippon Chemi-Con. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 7-19 CAT. No. E1001R
ERWE451LGC472MED0M 价格&库存
很抱歉,暂时无法提供与“ERWE451LGC472MED0M”相匹配的价格&库存,您可以联系我们找货
