LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
LXS
Long life snap-ins, 105℃
LXM
Series
Longer life
・For solar power generation
・Endurance with ripple current : 5,000 hours at 105℃
・Rated voltage range : 160 to 600V
・Downsized from LXQ series
・Non solvent resistant type
・RoHS2 Compliant
LXS
Downsizing
LHS
Longer life
KMS
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-25 to +105℃
160 to 600Vdc
±20% (M)
I≦3 CV
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
160 to 400V
420 to 600V
tanδ (Max.)
0.15
0.20
Rated voltage (Vdc)
160 to 400V
420 to 600V
Z(-25℃)/Z(+20℃)
4
8
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 5 minutes)
(at 20℃, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value (500Vdc : ≦ 250%, 550, 600Vdc : ≦ 300%)
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
≦±15% of the initial value
D.F. (tanδ)
≦150% of the initial specified value
Leakage current
Endurance
Shelf Life
◆DIMENSIONS [mm]
●Terminal
Code : VS (φ22 to φ35) : Standard
Sleeve (PET : Brown)
Negative mark
PC board pin-out
(View from Solder side)
Code : LI (φ30,φ35)
Negative mark
L±2.5
Vent
φD+1max.
φD+1max.
10
2-φ2
4.0±0.5
PC board pin-out
2-1.2×6
4.2±0.5
●Terminal
Vent
5±0.5
L±2.5
4.5±1
14.2±1
The standard design has no plastic disc.
◆PART NUMBERING SYSTEM
1
2
3
4
E LXS
5
6
7
8
9
10
VS N
11
12
13
14
M
15
16
17
18
S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 330µF:331, 2,200µF:222)
Dummy terminal code
Terminal code(VS, LI)
Voltage code (ex. 160V:161, 315V:3B1, 450V:451)
Series code
Category
Please refer to "Product code guide (snap-in type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
LXSSeries
◆STANDARD RATINGS
WV
(Vdc)
160
180
200
Cap
(µF)
Rated ripple
Case size
current
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
470
680
680
820
820
1,000
1,000
1,000
1,000
1,200
1,200
1,200
1,200
1,500
1,500
1,800
1,800
1,800
2,200
2,200
2,200
2,700
2,700
3,300
390
560
560
680
820
820
820
820
1,000
1,000
1,000
1,000
1,000
1,200
1,200
1,500
1,500
1,500
1,800
1,800
2,200
2,200
2,200
2,700
390
470
560
560
680
680
680
820
820
1,000
1,000
1,000
1,000
1,200
1,200
1,200
1,200
1,500
1,500
22 ×25
22 ×30
25.4×25
22 ×35
25.4×30
22 ×40
22 ×45
25.4 ×35
30 ×25
22× 50
25.4× 40
30× 30
35 × 25
25.4× 45
30 × 35
25.4× 50
30 ×40
35 ×30
30 ×45
30 ×50
35 ×35
35× 40
35 × 45
35 × 50
22 × 25
22 × 30
25.4×25
22 ×35
22 ×40
25.4×30
25.4×35
30 ×25
22 ×45
22 ×50
25.4×40
30 ×30
35 ×25
25.4×45
30 ×35
25.4×50
30 ×40
35 ×30
30 ×45
35 ×35
30 ×50
35 ×40
35 ×45
35 ×50
22 ×25
22 ×30
22 ×35
25.4×25
22 ×40
25.4×30
30 × 25
22 × 45
25.4× 35
22 ×50
25.4×40
30 ×30
35 ×25
25.4 ×45
25.4 ×50
30 ×35
35 ×30
30× 40
30 × 45
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
1.47
1.86
1.84
2.09
2.08
2.35
2.40
2.40
2.50
2.69
2.68
2.77
2.91
3.05
3.17
3.40
3.57
3.62
4.05
4.11
4.07
4.67
4.78
5.40
1.34
1.68
1.67
1.90
2.13
2.08
2.17
2.26
2.40
2.45
2.45
2.52
2.66
2.73
2.83
3.10
3.26
3.31
3.66
3.68
4.11
4.22
4.32
4.88
1.34
1.54
1.72
1.67
1.94
1.89
2.06
2.17
2.17
2.45
2.45
2.52
2.66
2.73
2.78
2.83
2.96
3.26
3.34
Part No.
ELXS161VSN471MP25S
ELXS161VSN681MP30S
ELXS161VSN681MQ25S
ELXS161VSN821MP35S
ELXS161VSN821MQ30S
ELXS161VSN102MP40S
ELXS161VSN102MP45S
ELXS161VSN102MQ35S
ELXS161VSN102MR25S
ELXS161VSN122MP50S
ELXS161VSN122MQ40S
ELXS161VSN122MR30S
ELXS161VSN122MA25S
ELXS161VSN152MQ45S
ELXS161VSN152MR35S
ELXS161VSN182MQ50S
ELXS161VSN182MR40S
ELXS161VSN182MA30S
ELXS161VSN222MR45S
ELXS161VSN222MR50S
ELXS161VSN222MA35S
ELXS161VSN272MA40S
ELXS161VSN272MA45S
ELXS161VSN332MA50S
ELXS181VSN391MP25S
ELXS181VSN561MP30S
ELXS181VSN561MQ25S
ELXS181VSN681MP35S
ELXS181VSN821MP40S
ELXS181VSN821MQ30S
ELXS181VSN821MQ35S
ELXS181VSN821MR25S
ELXS181VSN102MP45S
ELXS181VSN102MP50S
ELXS181VSN102MQ40S
ELXS181VSN102MR30S
ELXS181VSN102MA25S
ELXS181VSN122MQ45S
ELXS181VSN122MR35S
ELXS181VSN152MQ50S
ELXS181VSN152MR40S
ELXS181VSN152MA30S
ELXS181VSN182MR45S
ELXS181VSN182MA35S
ELXS181VSN222MR50S
ELXS181VSN222MA40S
ELXS181VSN222MA45S
ELXS181VSN272MA50S
ELXS201VSN391MP25S
ELXS201VSN471MP30S
ELXS201VSN561MP35S
ELXS201VSN561MQ25S
ELXS201VSN681MP40S
ELXS201VSN681MQ30S
ELXS201VSN681MR25S
ELXS201VSN821MP45S
ELXS201VSN821MQ35S
ELXS201VSN102MP50S
ELXS201VSN102MQ40S
ELXS201VSN102MR30S
ELXS201VSN102MA25S
ELXS201VSN122MQ45S
ELXS201VSN122MQ50S
ELXS201VSN122MR35S
ELXS201VSN122MA30S
ELXS201VSN152MR40S
ELXS201VSN152MR45S
WV
(Vdc)
200
250
315
400
Cap
(µF)
Rated ripple
Case size
current
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
1,500
1,800
1,800
2,200
2,700
270
330
390
390
470
470
560
560
560
680
680
680
680
820
820
820
820
1,000
1,200
1,200
1,200
1,200
1,500
1,800
180
220
220
270
270
330
330
390
390
390
470
470
470
470
560
560
560
680
680
680
820
820
1,000
1,200
120
150
180
180
220
220
220
270
270
270
330
330
330
390
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
22 × 35
25.4 × 25
22 × 40
25.4 × 30
22 × 45
25.4 × 35
30 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4 × 45
25.4 × 50
30 × 35
35 × 30
30 × 40
30 × 45
30 × 50
35 × 35
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
25.4 × 25
22 × 35
25.4 × 30
22 × 40
30 × 25
22 × 45
22 × 50
25.4 × 35
25.4 × 40
25.4 × 45
30 × 30
35 × 25
25.4 × 50
30 × 35
35 × 30
30 × 40
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
22 × 25
22 × 30
22 × 35
25.4 × 25
22 × 40
25.4 × 30
30 × 25
22 × 45
22 × 50
25.4 × 35
25.4 × 40
30 × 30
35 × 25
25.4 × 45
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
3.36
3.72
3.81
4.32
4.88
1.11
1.29
1.44
1.40
1.61
1.57
1.79
1.79
1.87
2.02
2.02
2.08
2.19
2.26
2.29
2.34
2.45
2.66
2.99
3.04
3.00
3.11
3.56
3.98
0.95
1.10
1.10
1.24
1.25
1.40
1.43
1.56
1.59
1.57
1.76
1.79
1.73
1.82
1.99
1.93
2.02
2.19
2.25
2.26
2.51
2.57
2.91
3.25
0.77
0.90
1.02
0.99
1.15
1.13
1.17
1.29
1.32
1.30
1.47
1.45
1.52
1.63
Part No.
ELXS201VSN152MA35S
ELXS201VSN182MR50S
ELXS201VSN182MA40S
ELXS201VSN222MA45S
ELXS201VSN272MA50S
ELXS251VSN271MP25S
ELXS251VSN331MP30S
ELXS251VSN391MP35S
ELXS251VSN391MQ25S
ELXS251VSN471MP40S
ELXS251VSN471MQ30S
ELXS251VSN561MP45S
ELXS251VSN561MQ35S
ELXS251VSN561MR25S
ELXS251VSN681MP50S
ELXS251VSN681MQ40S
ELXS251VSN681MR30S
ELXS251VSN681MA25S
ELXS251VSN821MQ45S
ELXS251VSN821MQ50S
ELXS251VSN821MR35S
ELXS251VSN821MA30S
ELXS251VSN102MR40S
ELXS251VSN122MR45S
ELXS251VSN122MR50S
ELXS251VSN122MA35S
ELXS251VSN122MA40S
ELXS251VSN152MA45S
ELXS251VSN182MA50S
ELXS3B1VSN181MP25S
ELXS3B1VSN221MP30S
ELXS3B1VSN221MQ25S
ELXS3B1VSN271MP35S
ELXS3B1VSN271MQ30S
ELXS3B1VSN331MP40S
ELXS3B1VSN331MR25S
ELXS3B1VSN391MP45S
ELXS3B1VSN391MP50S
ELXS3B1VSN391MQ35S
ELXS3B1VSN471MQ40S
ELXS3B1VSN471MQ45S
ELXS3B1VSN471MR30S
ELXS3B1VSN471MA25S
ELXS3B1VSN561MQ50S
ELXS3B1VSN561MR35S
ELXS3B1VSN561MA30S
ELXS3B1VSN681MR40S
ELXS3B1VSN681MR45S
ELXS3B1VSN681MA35S
ELXS3B1VSN821MR50S
ELXS3B1VSN821MA40S
ELXS3B1VSN102MA45S
ELXS3B1VSN122MA50S
ELXS401VSN121MP25S
ELXS401VSN151MP30S
ELXS401VSN181MP35S
ELXS401VSN181MQ25S
ELXS401VSN221MP40S
ELXS401VSN221MQ30S
ELXS401VSN221MR25S
ELXS401VSN271MP45S
ELXS401VSN271MP50S
ELXS401VSN271MQ35S
ELXS401VSN331MQ40S
ELXS401VSN331MR30S
ELXS401VSN331MA25S
ELXS401VSN391MQ45S
CAT. No. E1001U
LXSSeries
◆STANDARD RATINGS
WV
(Vdc)
400
420
450
Cap
(µF)
Rated ripple
Case size
current
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
390
390
390
470
470
560
560
560
680
820
100
120
120
150
180
180
180
220
220
220
270
270
270
270
330
330
330
390
390
390
470
470
560
680
82
120
120
120
150
150
180
180
180
220
220
25.4×50
30 ×35
35 ×30
30 ×40
35× 35
30× 45
30 × 50
35 × 40
35 ×45
35 ×50
22 ×25
22 ×30
25.4 ×25
22× 35
22 × 40
25.4× 30
30 × 25
22 × 45
22 ×50
25.4×35
25.4×40
25.4×45
30 ×30
35 ×25
25.4 ×50
30 ×35
35 ×30
30 ×40
30 ×45
35 ×35
30 ×50
35 ×40
35 ×45
35 ×50
22 ×25
22 ×30
22 ×35
25.4×25
22 ×40
25.4×30
22 ×45
25.4×35
30 ×25
22 ×50
25.4×40
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1.66
1.61
1.68
1.82
1.88
2.04
2.07
2.13
2.40
2.69
0.70
0.81
0.81
0.93
1.04
1.02
1.06
1.17
1.20
1.18
1.33
1.36
1.31
1.38
1.52
1.48
1.55
1.66
1.70
1.71
1.90
1.95
2.17
2.45
0.64
0.81
0.83
0.81
0.94
0.93
1.06
1.06
1.06
1.20
1.20
Part No.
ELXS401VSN391MQ50S
ELXS401VSN391MR35S
ELXS401VSN391MA30S
ELXS401VSN471MR40S
ELXS401VSN471MA35S
ELXS401VSN561MR45S
ELXS401VSN561MR50S
ELXS401VSN561MA40S
ELXS401VSN681MA45S
ELXS401VSN821MA50S
ELXS421VSN101MP25S
ELXS421VSN121MP30S
ELXS421VSN121MQ25S
ELXS421VSN151MP35S
ELXS421VSN181MP40S
ELXS421VSN181MQ30S
ELXS421VSN181MR25S
ELXS421VSN221MP45S
ELXS421VSN221MP50S
ELXS421VSN221MQ35S
ELXS421VSN271MQ40S
ELXS421VSN271MQ45S
ELXS421VSN271MR30S
ELXS421VSN271MA25S
ELXS421VSN331MQ50S
ELXS421VSN331MR35S
ELXS421VSN331MA30S
ELXS421VSN391MR40S
ELXS421VSN391MR45S
ELXS421VSN391MA35S
ELXS421VSN471MR50S
ELXS421VSN471MA40S
ELXS421VSN561MA45S
ELXS421VSN681MA50S
ELXS451VSN820MP25S
ELXS451VSN121MP30S
ELXS451VSN121MP35S
ELXS451VSN121MQ25S
ELXS451VSN151MP40S
ELXS451VSN151MQ30S
ELXS451VSN181MP45S
ELXS451VSN181MQ35S
ELXS451VSN181MR25S
ELXS451VSN221MP50S
ELXS451VSN221MQ40S
WV
(Vdc)
450
500
550
600
Cap
(µF)
Rated ripple
Case size
current
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
220
220
270
270
270
270
330
390
390
390
470
470
560
100
120
120
150
180
180
220
220
270
270
330
390
470
120
150
180
180
220
220
270
330
390
120
120
150
150
180
180
220
220
270
330
30 × 30
35 × 25
25.4 × 45
25.4 × 50
30 × 35
35 × 30
30 × 40
30 × 45
30 × 50
35 × 35
35 × 40
35 × 45
35 × 50
30 × 25
30 × 30
35 × 25
30 × 35
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 50
35 × 60
30 × 30
30 × 35
30 × 40
35 × 30
30 × 50
35 × 40
35 × 45
35 × 50
35 × 60
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
30 × 60
35 × 45
35 × 50
35 × 60
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
1.18
1.24
1.36
1.38
1.34
1.40
1.52
1.70
1.73
1.71
1.95
1.99
2.22
0.82
0.91
0.88
1.04
1.17
1.10
1.33
1.23
1.50
1.42
1.60
1.78
2.03
0.91
1.04
1.17
1.10
1.35
1.28
1.45
1.64
1.85
0.96
0.95
1.10
1.07
1.22
1.22
1.40
1.38
1.56
1.79
Part No.
ELXS451VSN221MR30S
ELXS451VSN221MA25S
ELXS451VSN271MQ45S
ELXS451VSN271MQ50S
ELXS451VSN271MR35S
ELXS451VSN271MA30S
ELXS451VSN331MR40S
ELXS451VSN391MR45S
ELXS451VSN391MR50S
ELXS451VSN391MA35S
ELXS451VSN471MA40S
ELXS451VSN471MA45S
ELXS451VSN561MA50S
ELXS501VSN101MR25S
ELXS501VSN121MR30S
ELXS501VSN121MA25S
ELXS501VSN151MR35S
ELXS501VSN181MR40S
ELXS501VSN181MA30S
ELXS501VSN221MR45S
ELXS501VSN221MA35S
ELXS501VSN271MR50S
ELXS501VSN271MA40S
ELXS501VSN331MA45S
ELXS501VSN391MA50S
ELXS501VSN471MA60S
ELXS551VSN121MR30S
ELXS551VSN151MR35S
ELXS551VSN181MR40S
ELXS551VSN181MA30S
ELXS551VSN221MR50S
ELXS551VSN221MA40S
ELXS551VSN271MA45S
ELXS551VSN331MA50S
ELXS551VSN391MA60S
ELXS601VSN121MR40S
ELXS601VSN121MA30S
ELXS601VSN151MR45S
ELXS601VSN151MA35S
ELXS601VSN181MR50S
ELXS601VSN181MA40S
ELXS601VSN221MR60S
ELXS601VSN221MA45S
ELXS601VSN271MA50S
ELXS601VSN331MA60S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
160 to 250Vdc
315 to 450Vdc
500 to 600Vdc
50
0.81
0.77
0.70
120
1.00
1.00
1.00
300
1.17
1.16
1.16
1k
1.32
1.30
1.30
10k
1.45
1.41
1.41
50k
1.50
1.43
1.43
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
CAT. No. E1001U
