MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
Long life, High ripple, 135℃
GPD
Series
・Guaranteed short time at 150℃
・Downsized and high-ripple current version of GPA series
GPA
・For automobile modules and other high temperature applications
・Endurance with ripple current : 2,000 to 3,000 hours at 125℃ to 135℃
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
Downsized
Higher ripple current
GPD
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +135℃
25 to 100Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.03CV or 4µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃, 1 minute)
Rated voltage (Vdc)
25V 35V 50V 63V 80V 100V
tanδ (Max.)
0.14 0.12 0.10 0.10 0.08 0.08
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
2
2
2
2
2
2
Z(-40℃)/Z(+20℃)
4
4
4
4
4
4
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 125℃ or 135℃.
Time
125℃ 3,000hours
135℃ 25 to 50Vdc:3,000hours
63 to 100Vdc:2,000hours
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the test condition that the rated voltage is
applied for 100 hours at 150℃ and DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage)
Time
125℃ 2,500hours
135℃ 25 to 50Vdc:2,500hours
63 to 100Vdc:1,500hours
Capacitance change
D.F. (tanδ)
Leakage current
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance 1
Endurance 2
Shelf Life
◆DIMENSIONS [mm]
Code : E
φD'
φd
Coated Case
F±0.5
●Terminal
15min.
L'
Vent
4min.
Gas escape end seal
φD
φd
F
φD'
L'
12.5
0.6
5.0
16
0.8
7.5
φD±0.5
+1.5
L
-1.0
18
0.8
7.5
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12 13
14
15
16
17
18
E GPD AAA E AA AAA M AAA H
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 470µF:471, 1,000µF:102)
Lead forming·taping code
Terminal code
Voltage code (ex. 25V:250, 50V:500)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
GPDSeries
◆STANDARD RATINGS
WV
(Vdc)
25
35
50
63
Cap
(µF)
2,000
3,000
3,300
3,600
4,300
4,700
4,700
5,100
5,600
6,200
7,500
7,500
9,100
10,000
12,000
1,300
1,800
2,000
2,200
2,400
2,700
3,000
3,300
3,600
3,900
4,300
4,700
5,600
6,200
7,500
620
820
1,000
1,100
1,300
1,300
1,300
1,600
1,600
1,800
2,200
2,400
2,700
3,000
3,600
390
560
680
750
910
910
1,000
1,100
1,200
1,300
1,600
1,600
1,800
2,200
2,400
Case size
φD×L(mm)
tanδ
12.5 × 20
12.5 × 25
16 × 20
12.5 × 30
18 × 20
12.5 × 35
16 × 25
12.5 × 40
16 × 30
18 × 25
16 × 35
18 × 30
16 × 40
18 × 35
18 × 40
12.5 × 20
12.5 × 25
16 × 20
12.5 × 30
18 × 20
12.5 × 35
16 × 25
12.5 × 40
16 × 30
18 × 25
16 × 35
18 × 30
16 × 40
18 × 35
18 × 40
12.5 × 20
12.5 × 25
16 × 20
12.5 × 30
12.5 × 35
16 × 25
18 × 20
12.5 × 40
16 × 30
18 × 25
16 × 35
18 × 30
16 × 40
18 × 35
18 × 40
12.5 × 20
12.5 × 25
16 × 20
12.5 × 30
12.5 × 35
18 × 20
16 × 25
12.5 × 40
16 × 30
18 × 25
16 × 35
18 × 30
16 × 40
18 × 35
18 × 40
0.16
0.18
0.18
0.18
0.20
0.20
0.20
0.22
0.22
0.24
0.26
0.26
0.30
0.32
0.36
0.12
0.12
0.14
0.14
0.14
0.14
0.16
0.16
0.16
0.16
0.18
0.18
0.20
0.22
0.24
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.12
0.12
0.12
0.14
0.14
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.12
0.12
ESR
(Ω max./100kHz)
Rated ripple current
(mArms/100kHz)
20℃
-40℃
125℃
135℃
0.042
0.033
0.035
0.028
0.034
0.025
0.028
0.024
0.023
0.027
0.020
0.022
0.019
0.019
0.018
0.042
0.033
0.035
0.028
0.034
0.025
0.028
0.024
0.023
0.027
0.020
0.022
0.019
0.019
0.018
0.073
0.058
0.050
0.048
0.042
0.042
0.042
0.037
0.035
0.033
0.029
0.028
0.025
0.024
0.023
0.072
0.052
0.053
0.042
0.035
0.044
0.038
0.031
0.034
0.033
0.027
0.028
0.025
0.022
0.021
0.48
0.30
0.27
0.24
0.22
0.21
0.22
0.19
0.18
0.19
0.14
0.16
0.12
0.12
0.10
0.48
0.30
0.27
0.24
0.22
0.21
0.22
0.19
0.18
0.19
0.14
0.16
0.12
0.12
0.10
0.88
0.67
0.55
0.52
0.44
0.44
0.44
0.36
0.36
0.32
0.27
0.25
0.22
0.20
0.16
0.56
0.39
0.34
0.30
0.25
0.26
0.23
0.22
0.20
0.19
0.15
0.15
0.14
0.12
0.11
2,760
3,480
3,040
4,490
3,250
5,140
4,260
5,810
5,480
4,500
6,070
5,600
6,810
6,280
7,070
2,760
3,480
3,040
4,490
3,250
5,140
4,260
5,810
5,480
4,500
6,070
5,600
6,810
6,280
7,070
2,400
3,350
2,960
4,220
4,810
4,040
3,130
5,240
5,130
4,230
5,480
5,240
5,930
5,870
6,420
1,640
2,520
2,140
3,110
3,760
2,350
2,940
4,610
3,860
3,080
4,590
4,080
5,190
5,220
5,660
1,690
2,010
1,860
2,900
1,870
3,190
2,870
3,470
3,400
2,900
3,630
3,470
3,930
3,750
4,080
1,690
2,010
1,860
2,900
1,870
3,190
2,870
3,470
3,400
2,900
3,630
3,470
3,930
3,750
4,080
1,470
2,260
1,870
2,520
2,780
2,500
2,110
3,020
2,960
2,530
3,160
3,020
3,420
3,390
3,700
1,420
2,050
1,910
2,630
2,970
2,100
2,680
3,260
3,050
2,810
3,420
3,220
3,670
3,690
3,820
Part No.
EGPD250E□□202MK20H
EGPD250E□□302MK25H
EGPD250E□□332ML20H
EGPD250E□□362MK30H
EGPD250E□□432MM20H
EGPD250E□□472MK35H
EGPD250E□□472ML25H
EGPD250E□□512MK40H
EGPD250E□□562ML30H
EGPD250E□□622MM25H
EGPD250E□□752ML35H
EGPD250E□□752MM30H
EGPD250E□□912ML40H
EGPD250E□□103MM35H
EGPD250E□□123MM40H
EGPD350E□□132MK20H
EGPD350E□□182MK25H
EGPD350E□□202ML20H
EGPD350E□□222MK30H
EGPD350E□□242MM20H
EGPD350E□□272MK35H
EGPD350E□□302ML25H
EGPD350E□□332MK40H
EGPD350E□□362ML30H
EGPD350E□□392MM25H
EGPD350E□□432ML35H
EGPD350E□□472MM30H
EGPD350E□□562ML40H
EGPD350E□□622MM35H
EGPD350E□□752MM40H
EGPD500E□□621MK20H
EGPD500E□□821MK25H
EGPD500E□□102ML20H
EGPD500E□□112MK30H
EGPD500E□□132MK35H
EGPD500E□□132ML25H
EGPD500E□□132MM20H
EGPD500E□□162MK40H
EGPD500E□□162ML30H
EGPD500E□□182MM25H
EGPD500E□□222ML35H
EGPD500E□□242MM30H
EGPD500E□□272ML40H
EGPD500E□□302MM35H
EGPD500E□□362MM40H
EGPD630E□□391MK20H
EGPD630E□□561MK25H
EGPD630E□□681ML20H
EGPD630E□□751MK30H
EGPD630E□□911MK35H
EGPD630E□□911MM20H
EGPD630E□□102ML25H
EGPD630E□□112MK40H
EGPD630E□□122ML30H
EGPD630E□□132MM25H
EGPD630E□□162ML35H
EGPD630E□□162MM30H
EGPD630E□□182ML40H
EGPD630E□□222MM35H
EGPD630E□□242MM40H
□□ : Enter the appropriate lead forming or taping code.
CAT. No. E1001U
GPDSeries
◆STANDARD RATINGS
WV
(Vdc)
80
100
Cap
(µF)
270
390
470
510
620
620
680
750
750
820
1,000
1,100
1,300
1,300
1,600
160
220
270
300
360
360
390
430
470
510
560
620
750
820
910
Case size
φD×L(mm)
tanδ
12.5 × 20
12.5 × 25
16 × 20
12.5 × 30
12.5 × 35
18 × 20
16 × 25
12.5 × 40
16 × 30
18 × 25
16 × 35
18 × 30
16 × 40
18 × 35
18 × 40
12.5 × 20
12.5 × 25
16 × 20
12.5 × 30
12.5 × 35
18 × 20
16 × 25
12.5 × 40
16 × 30
18 × 25
16 × 35
18 × 30
16 × 40
18 × 35
18 × 40
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
ESR
(Ω max./100kHz)
(mArms/100kHz)
20℃
-40℃
125℃
135℃
0.072
0.052
0.053
0.042
0.035
0.044
0.038
0.031
0.034
0.033
0.027
0.028
0.025
0.022
0.021
0.090
0.068
0.067
0.052
0.045
0.061
0.048
0.038
0.041
0.045
0.036
0.037
0.028
0.030
0.026
0.56
0.39
0.34
0.30
0.25
0.26
0.23
0.22
0.20
0.19
0.15
0.15
0.14
0.12
0.11
0.75
0.55
0.47
0.41
0.35
0.35
0.33
0.29
0.27
0.25
0.23
0.20
0.18
0.16
0.14
1,640
2,520
2,140
3,110
3,760
2,350
2,940
4,610
3,860
3,080
4,590
4,080
5,190
5,220
5,660
1,580
2,140
2,050
2,950
3,530
2,270
2,790
4,140
3,440
2,920
4,190
3,920
5,020
4,710
5,280
1,420
2,050
1,910
2,630
2,970
2,100
2,680
3,260
3,050
2,810
3,420
3,220
3,670
3,690
3,820
1,410
1,960
1,670
2,330
2,630
1,860
2,360
2,920
2,720
2,470
2,960
2,920
3,380
3,330
3,560
Part No.
EGPD800E□□271MK20H
EGPD800E□□391MK25H
EGPD800E□□471ML20H
EGPD800E□□511MK30H
EGPD800E□□621MK35H
EGPD800E□□621MM20H
EGPD800E□□681ML25H
EGPD800E□□751MK40H
EGPD800E□□751ML30H
EGPD800E□□821MM25H
EGPD800E□□102ML35H
EGPD800E□□112MM30H
EGPD800E□□132ML40H
EGPD800E□□132MM35H
EGPD800E□□162MM40H
EGPD101E□□161MK20H
EGPD101E□□221MK25H
EGPD101E□□271ML20H
EGPD101E□□301MK30H
EGPD101E□□361MK35H
EGPD101E□□361MM20H
EGPD101E□□391ML25H
EGPD101E□□431MK40H
EGPD101E□□471ML30H
EGPD101E□□511MM25H
EGPD101E□□561ML35H
EGPD101E□□621MM30H
EGPD101E□□751ML40H
EGPD101E□□821MM35H
EGPD101E□□911MM40H
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
160
220 to 620
680 to 2,000
2,200 to 4,300
4,700 to 12,000
120
0.40
0.50
0.60
0.75
0.85
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
Please contact us for lifetime estimation.
CAT. No. E1001U
