EKZN250EC3821MJ20S
EKZN250EC3821MJ20S
    NCC(贵弥功)
    插件,D10xL20mm
EKZN250EC3821MJ20S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KZN Low impedance, 105℃ Upgrade! Series KZN ・Adoption of innovative high stability electrolyte ・High ripple current and long endurance ・Rated voltage range : 6.3 to 100Vdc, Capacitance range : 8.2 to 22,000µF ・Endurance with ripple current : 6,000 to 10,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Higher ripple KZM ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 6.3 to 100Vdc ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V tanδ (Max.) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.09 0.08 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. Z (-25℃) / Z (+20℃) 2max. Z (-40℃) / Z (+20℃) 3max. Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃. φ10×16L, 20L, 25L Case size φ5&φ6.3 φ8×11.5L φ10×12.5L φ8×15L, 20L φ12.5 to φ18 6.3Vdc 6,000 hours 8,000 hours 9,000 hours 9,000 hours 10,000 hours Time 10,000 hours 10 to 50Vdc 7,000 hours 9,000 hours 9,000 hours 10,000 hours 63 to 100Vdc 6,000 hours 8,000 hours 9,000 hours 9,000 hours 10,000 hours Capacitance change ≦±25% of the initial value (6.3, 10Vdc : ≦±30%) D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±25% of the initial value (6.3, 10Vdc : ≦±30%) D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] φd φD' F±0.5 Code : E Sleeve(PET : Brown) F±0.5 ●Terminal L' 15min. 4min. (φ5 to 10) (φ12.5 to 18) φD φd F D' L' 5 0.5 2.0 6.3 0.5 2.5 8 10 12.5 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 18 0.8 7.5 Gas escape end seal Vent (Except φ5 & φ6.3) ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KZN AAA E AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 100µF:101, 3,900µF:392) Lead forming·taping code Terminal code Voltage code (ex. 16V:160 50V:500) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KZNSeries Upgrade! ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 220 470 820 1,200 1,200 1,500 1,800 2,700 2,700 3,300 3,900 5,600 6.3 6,800 6,800 8,200 8,200 10,000 12,000 12,000 15,000 15,000 18,000 18,000 22,000 150 330 560 820 1,000 1,000 1,200 1,800 1,800 2,200 2,700 3,900 10 4,700 4,700 5,600 5,600 6,800 8,200 8,200 10,000 10,000 12,000 12,000 15,000 120 270 470 680 680 820 16 1,000 1,500 1,500 1,800 2,200 2,700 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 18×20 16×25 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 8×20 10×12.5 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 18×20 16×25 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.38 0.17 0.075 0.059 0.053 0.041 0.038 0.028 0.035 0.026 0.025 0.019 0.018 0.021 0.016 0.020 0.017 0.016 0.016 0.014 0.014 0.013 0.012 0.011 0.38 0.17 0.075 0.059 0.041 0.053 0.038 0.028 0.035 0.026 0.025 0.019 0.018 0.021 0.016 0.020 0.017 0.016 0.016 0.014 0.014 0.013 0.012 0.011 0.38 0.17 0.075 0.059 0.053 0.041 0.038 0.028 0.035 0.026 0.025 0.019 1.2 0.51 0.23 0.18 0.16 0.13 0.12 0.084 0.11 0.072 0.075 0.057 0.054 0.063 0.048 0.060 0.051 0.048 0.048 0.042 0.042 0.039 0.036 0.033 1.2 0.51 0.23 0.18 0.13 0.16 0.12 0.084 0.11 0.072 0.075 0.057 0.054 0.063 0.048 0.060 0.051 0.048 0.048 0.042 0.042 0.039 0.036 0.033 1.2 0.51 0.23 0.18 0.16 0.13 0.12 0.084 0.11 0.072 0.075 0.057 345 540 945 1,250 1,330 1,500 1,760 1,960 1,900 2,250 2,480 2,900 3,450 3,250 3,570 3,450 3,630 4,100 3,880 4,280 4,190 4,580 4,380 4,960 450 700 1,200 1,600 1,960 1,700 2,000 2,500 2,400 2,900 2,600 3,200 3,660 3,330 4,120 3,450 3,810 4,100 3,880 4,280 4,190 4,580 4,380 4,960 450 700 1,200 1,600 1,700 1,960 2,000 2,500 2,400 2,900 2,600 3,200 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ EKZN6R3E□□221ME11D EKZN6R3E□□471MF11D EKZN6R3E□□821MHB5D EKZN6R3E□□122MH15D EKZN6R3E□□122MJC5S EKZN6R3E□□152MH20D EKZN6R3E□□182MJ16S EKZN6R3E□□272MJ20S EKZN6R3E□□272MK16S EKZN6R3E□□332MJ25S EKZN6R3E□□392MK20S EKZN6R3E□□562MK25S EKZN6R3E□□682MK30S EKZN6R3E□□682ML20S EKZN6R3E□□822MK35S EKZN6R3E□□822MM20S EKZN6R3E□□103ML25S EKZN6R3E□□123MLN3S EKZN6R3E□□123MM25S EKZN6R3E□□153MLP1S EKZN6R3E□□153MMN3S EKZN6R3E□□183ML40S EKZN6R3E□□183MMP1S EKZN6R3E□□223MM40S EKZN100E□□151ME11D EKZN100E□□331MF11D EKZN100E□□561MHB5D EKZN100E□□821MH15D EKZN100E□□102MH20D EKZN100E□□102MJC5S EKZN100E□□122MJ16S EKZN100E□□182MJ20S EKZN100E□□182MK16S EKZN100E□□222MJ25S EKZN100E□□272MK20S EKZN100E□□392MK25S EKZN100E□□472MK30S EKZN100E□□472ML20S EKZN100E□□562MK35S EKZN100E□□562MM20S EKZN100E□□682ML25S EKZN100E□□822MLN3S EKZN100E□□822MM25S EKZN100E□□103MLP1S EKZN100E□□103MMN3S EKZN100E□□123ML40S EKZN100E□□123MMP1S EKZN100E□□153MM40S EKZN160E□□121ME11D EKZN160E□□271MF11D EKZN160E□□471MHB5D EKZN160E□□681MH15D EKZN160E□□681MJC5S EKZN160E□□821MH20D EKZN160E□□102MJ16S EKZN160E□□152MJ20S EKZN160E□□152MK16S EKZN160E□□182MJ25S EKZN160E□□222MK20S EKZN160E□□272MK25S 3,300 3,900 3,900 4,700 5,600 6,800 16 6,800 8,200 8,200 10,000 10,000 12,000 68 150 270 470 470 560 680 820 1,000 1,200 1,500 1,800 25 2,200 2,200 2,700 3,300 3,300 4,700 4,700 5,600 5,600 6,800 6,800 8,200 47 100 180 220 270 330 390 470 560 680 820 1,200 35 1,500 1,500 1,800 1,800 1,800 2,700 2,700 3,300 3,300 3,900 3,900 4,700 12.5×30 12.5×35 16×20 18×20 16×25 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 18×20 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 18×20 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.018 0.016 0.021 0.020 0.017 0.016 0.016 0.014 0.014 0.013 0.012 0.011 0.38 0.17 0.075 0.059 0.053 0.041 0.038 0.028 0.035 0.026 0.025 0.019 0.018 0.021 0.016 0.017 0.020 0.016 0.016 0.014 0.014 0.013 0.012 0.011 0.38 0.17 0.075 0.059 0.053 0.041 0.038 0.028 0.035 0.026 0.025 0.019 0.018 0.021 0.016 0.017 0.020 0.016 0.016 0.014 0.014 0.013 0.012 0.011 0.054 0.048 0.063 0.060 0.051 0.048 0.048 0.042 0.042 0.039 0.036 0.033 1.2 0.51 0.23 0.18 0.16 0.13 0.12 0.084 0.11 0.072 0.075 0.057 0.054 0.063 0.048 0.051 0.060 0.048 0.048 0.042 0.042 0.039 0.036 0.033 1.2 0.51 0.23 0.18 0.16 0.13 0.12 0.084 0.11 0.072 0.075 0.057 0.054 0.063 0.048 0.051 0.060 0.048 0.048 0.042 0.042 0.039 0.036 0.033 3,660 4,120 3,330 3,450 3,810 4,100 3,880 4,280 4,190 4,580 4,380 4,960 450 700 1,200 1,600 1,700 1,960 2,000 2,500 2,400 2,900 2,600 3,200 3,660 3,330 4,120 3,810 3,450 4,100 3,880 4,280 4,190 4,580 4,380 4,960 450 700 1,200 1,600 1,700 1,960 2,000 2,500 2,400 2,900 2,600 3,200 3,660 3,330 4,120 3,810 3,450 4,100 3,880 4,280 4,190 4,580 4,380 4,960 Part No. EKZN160E□□332MK30S EKZN160E□□392MK35S EKZN160E□□392ML20S EKZN160E□□472MM20S EKZN160E□□562ML25S EKZN160E□□682MLN3S EKZN160E□□682MM25S EKZN160E□□822MLP1S EKZN160E□□822MMN3S EKZN160E□□103ML40S EKZN160E□□103MMP1S EKZN160E□□123MM40S EKZN250E□□680ME11D EKZN250E□□151MF11D EKZN250E□□271MHB5D EKZN250E□□471MH15D EKZN250E□□471MJC5S EKZN250E□□561MH20D EKZN250E□□681MJ16S EKZN250E□□821MJ20S EKZN250E□□102MK16S EKZN250E□□122MJ25S EKZN250E□□152MK20S EKZN250E□□182MK25S EKZN250E□□222MK30S EKZN250E□□222ML20S EKZN250E□□272MK35S EKZN250E□□332ML25S EKZN250E□□332MM20S EKZN250E□□472MLN3S EKZN250E□□472MM25S EKZN250E□□562MLP1S EKZN250E□□562MMN3S EKZN250E□□682ML40S EKZN250E□□682MMP1S EKZN250E□□822MM40S EKZN350E□□470ME11D EKZN350E□□101MF11D EKZN350E□□181MHB5D EKZN350E□□221MH15D EKZN350E□□271MJC5S EKZN350E□□331MH20D EKZN350E□□391MJ16S EKZN350E□□471MJ20S EKZN350E□□561MK16S EKZN350E□□681MJ25S EKZN350E□□821MK20S EKZN350E□□122MK25S EKZN350E□□152MK30S EKZN350E□□152ML20S EKZN350E□□182MK35S EKZN350E□□182ML25S EKZN350E□□182MM20S EKZN350E□□272MLN3S EKZN350E□□272MM25S EKZN350E□□332MLP1S EKZN350E□□332MMN3S EKZN350E□□392ML40S EKZN350E□□392MMP1S EKZN350E□□472MM40S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KZNSeries Upgrade! ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 50 63 27 56 100 120 150 180 220 330 330 390 470 680 820 820 1,000 1,200 1,200 1,500 1,500 1,800 2,200 2,200 2,700 3,300 18 39 68 100 120 120 180 270 270 330 390 560 680 680 820 820 1,000 1,200 1,200 1,500 1,500 1,800 1,800 2,200 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 18×20 16×31.5 18×25 16×35.5 16×40 18×31.5 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 8×20 10×12.5 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 18×20 16×25 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.40 0.18 0.085 0.065 0.073 0.049 0.053 0.038 0.045 0.032 0.032 0.025 0.023 0.026 0.021 0.022 0.025 0.019 0.021 0.016 0.014 0.016 0.013 0.012 0.52 0.24 0.15 0.10 0.077 0.090 0.061 0.045 0.058 0.037 0.033 0.026 0.024 0.027 0.022 0.026 0.024 0.020 0.022 0.018 0.018 0.016 0.017 0.015 1.3 0.54 0.26 0.20 0.22 0.16 0.16 0.12 0.14 0.10 0.10 0.080 0.074 0.084 0.067 0.070 0.075 0.057 0.063 0.048 0.042 0.048 0.039 0.036 2.3 1.1 0.68 0.45 0.35 0.36 0.25 0.18 0.18 0.12 0.10 0.080 0.075 0.085 0.068 0.078 0.072 0.060 0.066 0.054 0.054 0.048 0.051 0.045 450 700 1,200 1,600 1,280 1,960 1,650 2,060 2,160 2,420 2,300 2,800 3,370 3,070 3,810 3,510 3,120 4,030 3,530 4,220 4,500 4,080 4,270 4,850 240 420 720 990 1,200 990 1,200 1,570 1,570 1,990 1,990 2,460 2,760 2,380 3,040 2,530 2,890 3,280 2,930 3,440 3,380 3,690 3,550 3,930 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ EKZN500E□□270ME11D EKZN500E□□560MF11D EKZN500E□□101MHB5D EKZN500E□□121MH15D EKZN500E□□151MJC5S EKZN500E□□181MH20D EKZN500E□□221MJ16S EKZN500E□□331MJ20S EKZN500E□□331MK16S EKZN500E□□391MJ25S EKZN500E□□471MK20S EKZN500E□□681MK25S EKZN500E□□821MK30S EKZN500E□□821ML20S EKZN500E□□102MK35S EKZN500E□□122ML25S EKZN500E□□122MM20S EKZN500E□□152MLN3S EKZN500E□□152MM25S EKZN500E□□182MLP1S EKZN500E□□222ML40S EKZN500E□□222MMN3S EKZN500E□□272MMP1S EKZN500E□□332MM40S EKZN630E□□180ME11D EKZN630E□□390MF11D EKZN630E□□680MHB5D EKZN630E□□101MH15D EKZN630E□□121MH20D EKZN630E□□121MJC5S EKZN630E□□181MJ16S EKZN630E□□271MJ20S EKZN630E□□271MK16S EKZN630E□□331MJ25S EKZN630E□□391MK20S EKZN630E□□561MK25S EKZN630E□□681MK30S EKZN630E□□681ML20S EKZN630E□□821MK35S EKZN630E□□821MM20S EKZN630E□□102ML25S EKZN630E□□122MLN3S EKZN630E□□122MM25S EKZN630E□□152MLP1S EKZN630E□□152MMN3S EKZN630E□□182ML40S EKZN630E□□182MMP1S EKZN630E□□222MM40S 12 27 47 68 82 82 120 180 180 220 270 390 80 470 470 560 680 680 820 820 1,000 1,200 1,200 1,500 1,800 8.2 18 33 47 56 56 82 100 120 150 180 220 100 270 270 390 390 390 470 560 560 680 680 820 1,000 5×11 6.3×11 8×11.5 8×15 8×20 10×12.5 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 18×20 16×31.5 18×25 16×35.5 16×40 18×31.5 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 8×20 10×12.5 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 18×20 16×31.5 16×35.5 18×25 16×40 18×31.5 18×35.5 18×40 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.72 0.34 0.20 0.14 0.12 0.14 0.090 0.068 0.090 0.055 0.048 0.038 0.033 0.036 0.026 0.028 0.032 0.022 0.027 0.020 0.018 0.020 0.018 0.017 0.72 0.34 0.20 0.14 0.12 0.14 0.090 0.068 0.090 0.055 0.048 0.038 0.033 0.036 0.026 0.028 0.032 0.022 0.020 0.027 0.018 0.020 0.018 0.017 3.2 1.5 0.90 0.63 0.54 0.56 0.36 0.28 0.27 0.22 0.15 0.12 0.11 0.12 0.078 0.084 0.096 0.066 0.081 0.060 0.054 0.060 0.054 0.051 3.2 1.5 0.90 0.63 0.54 0.56 0.36 0.28 0.27 0.22 0.15 0.12 0.11 0.12 0.078 0.084 0.096 0.066 0.060 0.081 0.054 0.060 0.054 0.051 235 390 650 820 1,090 860 1,150 1,570 1,430 1,780 1,800 2,210 2,520 2,150 2,860 2,620 2,280 2,900 2,750 3,150 3,710 3,150 3,710 4,060 235 390 650 820 1,090 860 1,150 1,570 1,430 1,780 1,800 2,210 2,520 2,150 2,860 2,620 2,280 2,900 3,150 2,750 3,710 3,150 3,710 4,060 Part No. EKZN800E□□120ME11D EKZN800E□□270MF11D EKZN800E□□470MHB5D EKZN800E□□680MH15D EKZN800E□□820MH20D EKZN800E□□820MJC5S EKZN800E□□121MJ16S EKZN800E□□181MJ20S EKZN800E□□181MK16S EKZN800E□□221MJ25S EKZN800E□□271MK20S EKZN800E□□391MK25S EKZN800E□□471MK30S EKZN800E□□471ML20S EKZN800E□□561MK35S EKZN800E□□681ML25S EKZN800E□□681MM20S EKZN800E□□821MLN3S EKZN800E□□821MM25S EKZN800E□□102MLP1S EKZN800E□□122ML40S EKZN800E□□122MMN3S EKZN800E□□152MMP1S EKZN800E□□182MM40S EKZN101E□□8R2ME11D EKZN101E□□180MF11D EKZN101E□□330MHB5D EKZN101E□□470MH15D EKZN101E□□560MH20D EKZN101E□□560MJC5S EKZN101E□□820MJ16S EKZN101E□□101MJ20S EKZN101E□□121MK16S EKZN101E□□151MJ25S EKZN101E□□181MK20S EKZN101E□□221MK25S EKZN101E□□271MK30S EKZN101E□□271ML20S EKZN101E□□391MK35S EKZN101E□□391ML25S EKZN101E□□391MM20S EKZN101E□□471MLN3S EKZN101E□□561MLP1S EKZN101E□□561MM25S EKZN101E□□681ML40S EKZN101E□□681MMN3S EKZN101E□□821MMP1S EKZN101E□□102MM40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 8.2 220 680 2,200 4,700 to to to to to 180 560 1,800 3,900 22,000 120 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 Note : The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKZN250EC3821MJ20S 价格&库存
很抱歉,暂时无法提供与“EKZN250EC3821MJ20S”相匹配的价格&库存,您可以联系我们找货
