SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
MVY
Low impedance, 105℃
Upgrade!
Series
MZA
Lower Z
・Endurance : 1,000 to 5,000 hours at 105℃
・Low impedance
・For digital equipment, especially DC-DC converters
・Solvent resistant type except 80 & 100Vdc (see PRECAUTIONS AND GUIDELINES)
・Vibration resistant structure
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
MVY
Longer life
MLA
Lower Z
MVE
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +105℃ (6.3 to 63Vdc)
-40 to +105℃ (80 & 100Vdc)
6.3 to 100Vdc
(at 20℃, 120Hz)
±20% (M)
I=0.01CV or 3μA, whichever is greater.
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 80V 100V When nominal capacitance exceeds
- 1,000μF, add 0.02 to the value above
D55 to F80
0.24 0.20 0.16 0.14 0.12 0.12
tanδ (Max.)
HA0 & JA0
0.28 0.24 0.20 0.16 0.14 0.12
- for each 1,000μF increase.
(at 20℃, 120Hz)
KE0 to MN0 0.26 0.22 0.18 0.16 0.14 0.12 0.14 0.10 0.10
Rated voltage (Vdc)
D55 to JA0
3
2
2
2
2
2
Z(-40℃)/Z(+20℃)
KE0 to MN0
10
8
6
4
3
3
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for specified
ime at 105℃.
D55 to F80 : 1,000 hours
Time
HA0 & JA0 : 2,000 hours
KE0 to MN0 : 5,000 hours
Rated voltage
6.3Vdc (D55 to JA0)
6.3 to 100Vdc
Capacitance change
≦±30% of the initial value
≦±20% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Rated voltage
6.3Vdc (D55 to JA0)
6.3 to 100Vdc
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
● Size
Vent
(Except F61 to HA0)
0.3max.
L±0.3 (Note)
φD±0.5
P
C±0.2
B±0.2
φD±0.5
W
0.3max.
L±0.3 (Note)
Note : L±0.5 for HA0 to MN0
A±0.2
2
3
4
5
6
7
8
9
10
11
12
A±0.2
: Dummy terminals
◆PART NUMBERING SYSTEM
1
W
P
C±0.2
Vent
(Except D55 to HA0)
Code : G(Vibration resistant structure)
code : F61 to MN0
Size code
B±0.2
Code : A
code : D55 to MN0
13
14
15
16
17
18
E MV Y AAA A DA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,10µF:100)
Taping·Tray code
Terminal code (A, G)
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
D55
E55
F55
F61
F80
HA0
JA0
KE0
KG5
LH0
LN0
MH0
MN0
D
4
5
6.3
6.3
6.3
8
10
12.5
12.5
16
16
18
18
L
5.2
5.2
5.2
5.8
7.7
10.0
10.0
13.5
16.0
16.5
21.5
16.5
21.5
A
4.3
5.3
6.6
6.6
6.6
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
B
4.3
5.3
6.6
6.6
6.6
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
C
5.1
5.9
7.2
7.2
7.2
9.0
11.0
13.7
13.7
18.0
18.0
20.0
20.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
P
1.0
1.4
1.9
1.9
1.9
3.1
4.5
4.2
4.2
6.5
6.5
6.5
6.5
◆MARKING
D55 to JA0
EX) 6.3V100µF
7hY
100
6.3V
KE0 to MN0
EX) 16V1,000µF
0V
MVY
1000
16V
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U Ver.3
TM
AIchip
MVYSeries
Upgrade!
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
Low impedance, 105℃
Cap
(µF)
Size
code
22
33
47
100
220
330
470
680
1,000
1,500
2,200
2,200
3,300
3,300
4,700
4,700
6,800
6,800
8,200
22
33
47
100
220
330
470
680
1,000
2,200
2,200
3,300
3,300
4,700
4,700
6,800
10
22
33
47
100
220
330
470
680
1,000
1,000
2,200
2,200
3,300
3,300
4,700
10
22
33
47
100
220
D55
E55
E55
F55
F55
F80
HA0
HA0
HA0
JA0
KE0
LH0
KG5
MH0
LN0
MH0
LN0
MN0
MN0
E55
E55
F55
F55
F80
HA0
HA0
JA0
JA0
KG5
LH0
LH0
MH0
LN0
MN0
MN0
D55
E55
F55
F55
F55
F80
HA0
HA0
JA0
KE0
LH0
LH0
MH0
LN0
MH0
MN0
E55
F55
F55
F55
F80
HA0
is not solvent resistant (80/100Vdc).
Rated ripple
Impedance
current
(Ω max./20℃,
(mArms/105℃,
100kHz)
100kHz)
3.0
1.8
1.8
1.0
1.0
0.34
0.30
0.30
0.30
0.15
0.070
0.054
0.060
0.054
0.038
0.054
0.038
0.038
0.038
1.8
1.8
1.0
1.0
0.34
0.30
0.30
0.15
0.15
0.060
0.054
0.054
0.054
0.038
0.038
0.038
3.0
1.8
1.0
1.0
1.0
0.34
0.30
0.30
0.15
0.070
0.054
0.054
0.054
0.038
0.054
0.038
1.8
1.0
1.0
1.0
0.34
0.30
60
95
95
140
140
280
450
450
450
670
820
1,260
950
1,350
1,630
1,350
1,630
1,750
1,750
95
95
140
140
280
450
450
670
670
950
1,260
1,260
1,350
1,630
1,750
1,750
60
95
140
140
140
280
450
450
670
820
1,260
1,260
1,350
1,630
1,350
1,750
95
140
140
140
280
450
Part No.
EMVY6R3ARA220MD55G
EMVY6R3ARA330ME55G
EMVY6R3ARA470ME55G
EMVY6R3ARA101MF55G
EMVY6R3ARA221MF55G
EMVY6R3□RA331MF80G
EMVY6R3□RA471MHA0G
EMVY6R3□RA681MHA0G
EMVY6R3□RA102MHA0G
EMVY6R3□RA152MJA0G
EMVY6R3□RA222MKE0S
EMVY6R3□RA222MLH0S
EMVY6R3□RA332MKG5S
EMVY6R3□RA332MMH0S
EMVY6R3□RA472MLN0S
EMVY6R3□RA472MMH0S
EMVY6R3□RA682MLN0S
EMVY6R3□RA682MMN0S
EMVY6R3□RA822MMN0S
EMVY100ARA220ME55G
EMVY100ARA330ME55G
EMVY100ARA470MF55G
EMVY100ARA101MF55G
EMVY100□RA221MF80G
EMVY100□RA331MHA0G
EMVY100□RA471MHA0G
EMVY100□RA681MJA0G
EMVY100□RA102MJA0G
EMVY100□RA222MKG5S
EMVY100□RA222MLH0S
EMVY100□RA332MLH0S
EMVY100□RA332MMH0S
EMVY100□RA472MLN0S
EMVY100□RA472MMN0S
EMVY100□RA682MMN0S
EMVY160ARA100MD55G
EMVY160ARA220ME55G
EMVY160ARA330MF55G
EMVY160ARA470MF55G
EMVY160ARA101MF55G
EMVY160□RA221MF80G
EMVY160□RA331MHA0G
EMVY160□RA471MHA0G
EMVY160□RA681MJA0G
EMVY160□RA102MKE0S
EMVY160□RA102MLH0S
EMVY160□RA222MLH0S
EMVY160□RA222MMH0S
EMVY160□RA332MLN0S
EMVY160□RA332MMH0S
EMVY160□RA472MMN0S
EMVY250ARA100ME55G
EMVY250ARA220MF55G
EMVY250ARA330MF55G
EMVY250ARA470MF55G
EMVY250□RA101MF80G
EMVY250□RA221MHA0G
□ : Enter the appropriate terminal code.
WV
(Vdc)
25
35
50
63
80
100
Cap
(µF)
Size
code
330
470
1,000
1,000
2,200
2,200
3,300
4.7
10
22
33
47
47
68
100
220
330
470
470
1,000
1,000
2,200
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
330
470
470
1,000
68
100
220
220
330
330
470
470
100
220
330
330
470
47
68
100
100
220
220
330
HA0
JA0
LH0
MH0
LN0
MN0
MN0
D55
E55
F55
F55
F55
F61
F80
HA0
HA0
JA0
KE0
LH0
LH0
MH0
MN0
D55
D55
D55
E55
F55
F55
F80
F80
HA0
HA0
JA0
KE0
LH0
LH0
MH0
MN0
KE0
KE0
KE0
LH0
LH0
MH0
LN0
MH0
KE0
KG5
LN0
MH0
MN0
KE0
KE0
KE0
LH0
LN0
MH0
MN0
Rated ripple
Impedance
current
(Ω max./20℃,
(mArms/105℃,
100kHz)
100kHz)
0.30
0.15
0.054
0.054
0.038
0.038
0.038
3.0
1.8
1.0
1.0
1.0
1.0
0.34
0.30
0.30
0.15
0.070
0.054
0.054
0.054
0.038
5.0
5.0
5.0
3.0
2.0
2.0
0.60
0.60
0.60
0.60
0.30
0.11
0.087
0.087
0.087
0.050
0.19
0.19
0.19
0.12
0.12
0.12
0.085
0.12
0.33
0.26
0.16
0.24
0.16
0.33
0.33
0.33
0.24
0.16
0.24
0.16
450
670
1,260
1,350
1,630
1,750
1,750
60
95
140
140
140
140
280
450
450
670
820
1,260
1,260
1,350
1,750
30
30
30
50
70
70
170
170
300
300
500
650
900
900
1,060
1,520
500
500
500
845
845
905
1,100
905
450
550
900
700
950
450
450
450
650
900
700
950
Part No.
EMVY250□RA331MHA0G
EMVY250□RA471MJA0G
EMVY250□RA102MLH0S
EMVY250□RA102MMH0S
EMVY250□RA222MLN0S
EMVY250□RA222MMN0S
EMVY250□RA332MMN0S
EMVY350ARA4R7MD55G
EMVY350ARA100ME55G
EMVY350ARA220MF55G
EMVY350ARA330MF55G
EMVY350ARA470MF55G
EMVY350□RA470MF61G
EMVY350□RA680MF80G
EMVY350□RA101MHA0G
EMVY350□RA221MHA0G
EMVY350□RA331MJA0G
EMVY350□RA471MKE0S
EMVY350□RA471MLH0S
EMVY350□RA102MLH0S
EMVY350□RA102MMH0S
EMVY350□RA222MMN0S
EMVY500ARA1R0MD55G
EMVY500ARA2R2MD55G
EMVY500ARA3R3MD55G
EMVY500ARA4R7ME55G
EMVY500ARA100MF55G
EMVY500ARA220MF55G
EMVY500□RA330MF80G
EMVY500□RA470MF80G
EMVY500□RA680MHA0G
EMVY500□RA101MHA0G
EMVY500□RA221MJA0G
EMVY500□RA331MKE0S
EMVY500□RA331MLH0S
EMVY500□RA471MLH0S
EMVY500□RA471MMH0S
EMVY500□RA102MMN0S
EMVY630□RA680MKE0S
EMVY630□RA101MKE0S
EMVY630□RA221MKE0S
EMVY630□RA221MLH0S
EMVY630□RA331MLH0S
EMVY630□RA331MMH0S
EMVY630□RA471MLN0S
EMVY630□RA471MMH0S
EMVY800□RA101MKE0S
EMVY800□RA221MKG5S
EMVY800□RA331MLN0S
EMVY800□RA331MMH0S
EMVY800□RA471MMN0S
EMVY101□RA470MKE0S
EMVY101□RA680MKE0S
EMVY101□RA101MKE0S
EMVY101□RA101MLH0S
EMVY101□RA221MLN0S
EMVY101□RA221MMH0S
EMVY101□RA331MMN0S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Size code
D55 to JA0
KE0 to MN0
Capacitance(µF)
Frequency(Hz)
1.0 to 4.7
10 to 100
220 to 470
680 to 1,500
47 to 100
220 to 470
1,000
2,200 to 3,300
4,700 to 8,200
120
0.35
0.40
0.50
0.60
0.40
0.50
0.60
0.75
0.85
1k
0.70
0.75
0.85
0.87
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.90
0.94
0.95
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
