AS5100-AL
AS5100-AL
    ANBON(安邦)
    SMA-L
    电压:60V 电流:5A
AS5100-AL 数据手册
AS540-AL& AS560-AL& AS5100-AL 5.0A Surface Mount Schottky Barrier Rectifiers Package outline Features • Batch process design, excellent power dissipation offers better reverse leakage current and thermal resistance. SMA-L • Low profile surface mounted application in order to • • • • • • • • optimize board space. Low power loss, high efficiency. High current capability, low forward voltage drop. High surge capability. Guardring for overvoltage protection. Ultra high-speed switching. Silicon epitaxial planar chip, metal silicon junction. Lead-free parts meet environmental standards of MIL-STD-19500 /228 Suffix "-H" indicates Halogen-free parts, e x. ΑS540-Α L-H. 0.209(5.3) 0.185(4.7) 0.012(0.3) Typ. 0.114(2.9) 0.091(2.3) Mechanical data • Epoxy:UL94-V0 rated flame retardant • Case : Molded plastic, DO-214AC / SMA-L • Terminals : Solder plated, solderable per 0.080(2.0) 0.063(1.6) 0.032(0.8) Typ. 0.032 (0.8) Typ. MIL-STD-750, Method 2026 • Polarity : Indicated by cathode band • Mounting Position : Any • Weight : Approximated 0.05 gram Dimensions in inches and (millimeters) Maximum ratings and Electrical Characteristics (AT PARAMETER T A=25 oC unless otherwise noted) Symbol CONDITIONS Forward rectified current See Fig.1 Forward surge current 8.3ms single half sine-wave superimposed on rate load (JEDEC methode) MIN. TYP. 5.0 A I FSM 150 A 0.5 IR V R = V RRM T J = 100 OC Thermal resistance Junction to case Diode junction capacitance f=1MHz and applied 4V DC reverse voltage Storage temperature SYMBOLS AS540-AL AS560-AL *1 V RRM (V) 40 60 UNIT IO V R = V RRM T J = 25 OC Reverse current MAX. R θJC 28 CJ 380 -65 T STG V RMS*2 (V) 28 42 mA 20 O C/W pF O +175 C *1 Repetitive peak reverse voltage *3 VR (V) *4 VF (V) Operating temperature T J, ( OC) *2 RMS voltage 40 0.55 -55 to +125 *3 Continuous reverse voltage 60 0.70 *4 Maximum forward voltage@I F=5.0A -55 to +150 AS5100-A L 100 70 100 0.85 Document ID Page 1 A S-12161U-H1 Issued Date 2015/10/14 Revised Date Revision Page. A 3 Rating and characteristic curves (AS540-AL&AS560-AL&AS5100-AL ) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 6.0 0 0 20 40 60 80 100 120 140 160 180 200 LEAD TEMPERATURE,(°C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 54 0AL 56 3.0 AS AL 0- 1.0 AS 10 2.0 10 AS INSTANTANEOUS FORWARD CURRENT,(A) AL 0- 5 AS L& -A 54 3.0 60 AS 5 AS 4.0 0AL 51 00 -A L 50 5.0 1.0 TJ=25 C Pulse Width 300us 1% Duty Cycle 0.1 .01 200 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 150 8.3ms Single Half TJ=25 C Sine Wave 100 JEDEC method 50 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 40V 60V&100V NUMBER OF CYCLES AT 60Hz 10 REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE 1400 JUNCTION CAPACITANCE,(pF) PEAK FORWARD SURGE CURRENT,(A) 250 1200 1000 800 600 400 TJ=100°C 1.0 0.1 TJ=25°C 0.01 200 0 .01 .05 .1 .5 1 5 10 50 100 0.001 0 REVERSE VOLTAGE,(V) 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) Document ID Page 2 A S-12161U-H1 Issued Date 2015/10/14 Revised Date Revision Page. A 3 AS540-AL& AS560-AL& AS5100-AL 5.0A Surface Mount Schottky Barrier Rectifiers Pinning information Pin Pin1 Pin2 Simplified outline cathode anode 1 Symbol 2 1 2 Marking Type number Marking code AS540-AL AS560-AL AS5100-AL SS54 SS56 S510 Suggested solder pad layout C A B Dimensions in inches and (millimeters) PACKAGE A B C SMA-L 0.110 (2.80) 0.059 (1.50) 0.110 (2.80) Document ID Page 3 A S-12161U-H1 Issued Date 2015/10/14 Revised Date Revision Page. A 3
AS5100-AL 价格&库存
很抱歉,暂时无法提供与“AS5100-AL”相匹配的价格&库存,您可以联系我们找货
