BZT52C Series
350mW Surface Mount Zener
Diodes - 2.4V-75V
Package outline
Features
• Silicon epitaxial planar chip structure.
• Zener breakdown voltage range, 2.4V to 75V ex.BZT52C2V4
• Small package size for high density applications.
• Ideally suited for automated assembly processes.
• Pb-Free package is available.
• Compliant to Halogen-free
0.110(2.80)
0.098(2.50)
0.053(1.35)
0.037(0.95)
0.008(0.20)MAX
Mechanical data
0.026(0.65)
0.018(0.45)
0.071(1.80)
0.055(1.40)
SOD-123
• Epoxy : UL94-V0 rated flame retardant
• Case : Molded plastic, SOD-123
• Terminals :Plated terminals, solderable per MIL-STD-750,
0.152(3.85)
0.140(3.55)
Method 2026
• Polarity : Indicated by cathode band
• Mounting Position : Any
Dimensions in inches and (millimeters)
Maximum ratings (at T =25 C unless otherwise noted)
o
A
PARAMETER
Forward voltage
Total power dissipation
Thermal resistance
CONDITIONS
@IF = 10mA
MIN.
TYP.
VF
o
at T A=25 C Mounted on FR-5 board, note1
Junction to ambient, note1
Junction to case, note1
Storage temperature range
Note1.Device mounted on ceramic PCB; 7.6mm x 9.4mm x 0.87mm with pad area 25mm
PD
MAX.
UNIT
0.9
V
350
R θJA
R θJC
Operating junction temperature range
http://www.anbonsemi.com
TEL:886-755-23776891
FAX:886-755-81482182
Symbol
mW
O
305
200
O
C/W
C/W
TJ
-55
+150
o
C
T STG
-55
+150
o
C
2
Page 1
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3100005
2003/03/08
2017/05/23
E
4
BZT52C Series
Diodes - 2.4V-75V
Electrical characteristics (at T =25 C unless otherwise noted)
o
A
Zener
voltage
Part No.
Marking
code
Test
current
Zener
impedance
Leakage
current
I ZT
Z ZT @ I ZT
Z ZK @ I ZK
I ZK
IR
VR
Min.(V) Nom.(V) Max.(V)
V Z @ I ZT
mA
(Ω)Max
(Ω)Max
mA
(uA)Max
Volts
BZT52C2V4
WX
2.2
2.4
2.6
5
100
600
1.0
50.0
1.0
BZT52C2V7
W1
2.5
2.7
2.9
5
100
600
1.0
20.0
1.0
BZT52C3V0
W2
2.8
3.0
3.2
5
95
600
1.0
10.0
1.0
BZT52C3V3
W3
3.1
3.3
3.5
5
95
600
1.0
5.0
1.0
BZT52C3V6
W4
3.4
3.6
3.8
5
90
600
1.0
5.0
1.0
BZT52C3V9
W5
3.7
3.9
4.1
5
90
600
1.0
3.0
1.0
BZT52C4V3
W6
4.0
4.3
4.6
5
90
600
1.0
3.0
1.0
BZT52C4V7
W7
4.4
4.7
5.0
5
80
500
1.0
3.0
2.0
BZT52C5V1
W8
4.8
5.1
5.4
5
60
480
1.0
2.0
2.0
BZT52C5V6
W9
5.2
5.6
6.0
5
40
400
1.0
1.0
2.0
BZT52C6V2
WA
5.8
6.2
6.6
5
10
150
1.0
3.0
4.0
BZT52C6V8
WB
6.4
6.8
7.2
5
15
80
1.0
2.0
4.0
BZT52C7V5
WC
7.0
7.5
7.9
5
15
80
1.0
1.0
5.0
BZT52C8V2
WD
7.7
8.2
8.7
5
15
80
1.0
0.7
5.0
BZT52C9V1
WE
8.5
9.1
9.6
5
15
100
1.0
0.5
6.0
BZT52C10
WF
9.4
10
10.6
5
1.0
0.2
7.0
BZT52C11
WG
10.4
11
11.6
5
1.0
0.1
8.0
BZT52C12
WH
11.4
12
12.7
5
25
150
1.0
0.1
8.0
BZT52C13
WI
12.4
13
14.1
5
30
170
1.0
0.1
8.0
BZT52C15
WJ
13.8
15
15.8
5
30
200
1.0
0.1
10.5
BZT52C16
WK
15.3
16
17.1
5
40
200
1.0
0.1
11.2
BZT52C18
WL
16.8
18
19.1
5
45
225
1.0
0.1
12.6
BZT52C20
WM
18.8
5
55
225
1.0
0.1
14.0
BZT52C22
WN
20.8
22
23.3
5
55
250
1.0
0.1
15.4
BZT52C24
WO
22.8
24
25.6
5
70
250
1.0
0.1
16.8
BZT52C27
WP
25.1
27
28.9
2
80
300
0.5
0.1
18.9
BZT52C30
WQ
28.0
30
32.0
2
80
300
0.5
0.1
21.0
BZT52C33
WR
31.0
33
35.0
2
80
325
0.5
0.1
23.1
BZT52C36
WS
34.0
36
38.0
2
90
350
0.5
0.1
25.2
BZT52C39
WT
37.0
39
41.0
2
130
350
0.5
0.1
27.3
BZT52C43
WU
40.0
43
46.0
2
150
375
0.5
0.1
32.0
BZT52C47
WV
44.6
47
49.4
2
170
1000
0.25
0.1
35.0
BZT52C51
X1
48.4
51
53.6
2
180
1300
0.25
0.1
38.0
BZT52C56
X2
53.2
56
58.8
2
200
1400
0.25
0.1
42.0
BZT52C62
X3
58.9
62
65.1
2
225
1400
0.25
0.1
46.0
BZT52C68
X4
64.6
68
71.4
2
240
1600
0.25
0.1
51.0
BZT52C75
X5
71.2
75
78.8
2
265
1700
0.25
0.1
56.0
Note:
1. Tested with pulses, period = 5ms, pulse width = 300us.
2. When provided, otherwise, parts are provided with date code only, and type number identifications appears on reel only.
3. f=1KHz.
Page 2
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3100005
2003/03/08
2017/05/23
E
4
BZT52C Series
Diodes - 2.4V-75V
Rating and characteristic curves (BZT52C Series)
100
Ta =25℃
PD =350mW
Pulsed
1
43
39
36
33
27
30
22
24
15
18
10
15
10
9.1
8.2
7.5
6.2
6.8
5.6
4.7
2.4
5.1
10
PD =350mW
11
12
13
IZ, ZENER CURRENT (mA)
Pulsed
16
Ta =25℃
Zener Characteristics(11 V to 43 V)
Zener Characteristics(VZ Up to 10 V)
100
1
0.5
1
2
3
4
5
6
7
8
9
10
11
VZ, ZENER VOLTAGE (V)
Temperature Coefficients
30
35
40
45
Pulsed
TYPICAL Ta VALUES
35
50
Typical Leakage Current
100
FOR BZT52CXXX SERIES
10
30
IR, LEAKAGE CURRENT (uA)
θVZ, TEMPERATURE COEFFICIENT (mV/℃)
40
25
25
VZ @ IZT
15
10
5
1
0.1
0.01
Ta=100℃
1E-3
Ta=25℃
-5
1E-4
8
12
16
28
32
36
40
44
VZ, NOMINAL ZENER VOLTAGE (V)
10
15
35
40
45
Effect of Zener Voltage on Zener Impedance
Typical Capacitance
1000
1000
Ta=25℃
Ta=25℃
f=1MHz
ZZT, DYNAMIC IMPEDANCE(Ω)
100
1V BIAS
BIAS AT
50% OF VZ NOM
10
IZ(AC)=0.1IZ(DC)
IZ=1mA
0V BIAS
C, CAPACITANCE (pF)
30
1
f=1kHz
100
IZ=5mA
10
1
1
10
100
1
10
100
Power Derating Curve
400
POWER DISSIPATION
PD
(mW)
350
300
250
200
150
100
50
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
Page 3
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3100005
2003/03/08
2017/05/23
E
4
BZT52C Series
Diodes - 2.4V-75V
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Suggested solder pad layout
C
A
B
PACKAGE
SOD-123
A
B
C
0.048 (1.22)
0.036 (0.91)
0.093 (2.36)
Page 4
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3100005
2003/03/08
2017/05/23
E
4
很抱歉,暂时无法提供与“BZT52C18”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11779
- 500+0.09255
- 3000+0.07479
- 6000+0.06638
- 24000+0.05910
- 51000+0.05520
