DSF1A THRU DSF1J
1.0A Surface Mount Super
Fast Rectifiers-50-600V
Features
Package outline
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
Compliant to RoHS Directive 2011/65/EU
Compliant to Halogen-free
SOD-123
1.1± 0.25
0.10-0.30
1.8± 0.2
1.0±0.2
Cathode Band
Top View
0.6±0.25
Mechanical data
Case : JEDEC SOD-123 molded plastic body over
passivated chip
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight :0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
Maximum ratings and Electrical Characteristics (AT
PARAMETER
T A=25 oC unless otherwise noted)
CONDITIONS
Symbol
MIN.
TYP.
MAX.
UNIT
Forward rectified current
See Fig.2
IO
1.0
A
Forward surge current
8.3ms single half sine-wave (JEDEC methode)
I FSM
25
A
V R = V RRM T A = 25 OC
Reverse current
V R = V RRM T A = 100 C
Thermal resistance
Junction to ambient
NOTE 1
Diode junction capacitance
f=1MHz and applied 4V DC reverse voltage
Storage temperature
V RMS*2
(V)
*3
VR
(V)
DSF1A
50
35
50
DSF1B
100
70
100
DSF1C
150
105
150
DSF1D
200
140
200
DSF1E
300
210
300
DSF1G
400
280
400
DSF1J
600
420
600
*4
VF
(V)
*5
t rr
(ns)
Operating
temperature
T J, ( OC)
μA
50
R θJA
85
CJ
10
T STG
*1
V RRM
(V)
SYMBOLS
5.0
IR
O
O
pF
+150
-65
C/W
O
C
*1 Repetitive peak reverse voltage
*2 RMS voltage
0.95
*3 Continuous reverse voltage
35
-55 to +150
*4 Maximum forward voltage@I F=1.0A
1.25
*5 Maximum Reverse recovery time, note 2
1.70
Note: 1.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
2. Reverse recovery time test condition, I F =0.5A, I R =1.0A, I RR =0.25A
http://www.anbonsemi.com
TEL:886-755-23776891
FAX:886-755-81482182
Page 1
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3040002
2003/03/08
2012/05/16
D
3
DSF1A THRU DSF1J
Rating and characteristic curves
FIG.2-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.1-TYPICAL FORWARD
CHARACTERISTICS
SF
~D
1E
D
SF
1J
D
SF
1.0
AVERAGE FORWARD CURRENT,(A)
1G
DS
F1
D
DS
F1
A~
.1
1.2
1.0
0.8
0.6
P.C.B. Mounted on
0.2"x0.2" (5.0 mm x 5.0 mm)
Copper Pad Areas
0.4
0.2
50
75
100
125
150
175
LEAD TEMPERATURE (°C)
TJ=25 C
Pulse Width 300us
1% Duty Cycle
.01
.001
.4
.6
.8
1.0
1.2
1.4
1.6
1.8
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PULSE
GENERATOR
(NOTE 2)
PEAK FORWAARD SURGE CURRENT,(A)
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
50
40
30
8.3ms Single Half
TJ=25 C
Sine Wave
JEDEC method
10
5
1W
NONINDUCTIVE
50
10
100
NUMBER OF CYCLES AT 60Hz
OSCILLISCOPE
(NOTE 1)
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
FIG.5-TYPICAL JUNCTION CAPACITANCE
70
trr
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
10
+0.5A
-0.25A
-1.0A
60
50
40
30
1cm
SET TIME BASE FOR
50 / 10ns / cm
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
Page 2
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3040002
2003/03/08
2012/05/16
D
3
DSF1A THRU DSF1J
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
DSF1A
DSF1B
DSF1C
DSF1D
DSF1E
DSF1G
DSF1J
E1A
E1B
E1C
E1D
E1E
E1G
E1J
Suggested solder pad layout
C
A
B
Dimensions in inches and (millimeters)
PACKAGE
A
B
C
SOD-123
0.075 (1.90)
0.055 (1.40)
0.075 (1.90)
Page 3
Document ID
Issued Date
Revised Date
Revision
Page.
AS-3040002
2003/03/08
2012/05/16
D
3
很抱歉,暂时无法提供与“DSF1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09102
- 500+0.07111
- 3000+0.06269
- 6000+0.05602
- 24000+0.05018
- 51000+0.04709
