ASD465F
650V,4A Silicon Carbide Schottky Diode
Features
• Ease of Paralleling
• Zero reverse recovery current
• Zero forward recovery voltage
• Temperature independent switching behavior
• High temperature operation
• High frequency operation
Key Characteristics
VRRM
IF, Tc=141℃
QC
650
V
4
A
9
nC
Benefits
• Unipolar rectifier
• Substantially reduced switching losses
• No thermal run-away with parallel devices
• Reduced heat sink requirements
K
A
Applications
• Switch Mode Power Supplies (SMPS)
• Boost diodes in PFC or DC/DC stages
• Motor drives
• Solar application,UPS
• Power Switching Circuits
Part No.
Package Type
Marking
ASD465F
TO-220-2F
ASD465F
http://www.anbonsemi.com
TEL:+86-755-23776891
FAX:+86-755-81482182
1
Document ID
Issued Date
AS-3240029
2019/09/10
Revised Date
Revision
Page
A
5
ASD465F
Maximum Ratings
Parameter
Repetitive Peak Reverse
Voltage
Surge Peak Reverse
Voltage
DC Blocking Voltage
Symbol
Value
Unit
VRRM
650
V
VRSM
650
V
VDC
650
11
4.9
4
V
21
A
33
A
50
22
W
W
Continuous Forward
Current
Repetitive Peak Forward
Surge Current
Non-repetitive Peak
Forward Surge Current
IF
IFRM
IFSM
Test Condition
TC=25℃
TC=135℃
TC=141℃
TC=25℃, tp=10ms , Half Sine
Wave,D=0.3
Wave
TC=25℃
TC=110℃
A
Power Dissipation
PTOT
Operating Junction
Tj
-55℃ to 175℃
Tstg
-55℃ to 175℃
1
8.8
Nm
lbf-in
Storage Temperature
M3 Screw
6-32 Screw
Mounting Torque
Thermal Characteristics
Parameter
Symbol
Thermal resistance from
junction to case
Rth JC
Test Condition
2
Value
Typ.
Unit
4.7
℃/W
Document ID
Issued Date
AS-3240029
2019/09/10
Revised Date
Revision
Page
A
5
ASD465F
Electrical Characteristics
Parameter
Symbol
Forward Voltage
VF
Reverse Current
IR
Total Capacitive Charge
QC
IF=4A, Tj=25℃
I F=4A, Tj=175℃
VR=650V, Tj=25℃
VR=650V, Tj=175℃
VR=400V, Tj=25℃
VR
Qc
C
Total Capacitance
Numerical
Typ.
Max.
1.4
1.65
2.3
1.7
1
10
2
50
Test Conditions
9
C(V )dV
Unit
V
µA
VR=0V, Tj=25℃, f=1MHZ
230
260
VR=200V, Tj=25℃, f=1MHZ
VR=400V, Tj=25℃, f=1MHZ
24
21
nC
pF
Performance Graphs
2) Reverse IV characteristics as a function of Tj :
IF (A)
IR (μA)
1) Forward IV characteristics as a function of Tj :
VF (V)
VR (V)
Figure 1. Forward Characteristics
Figure 2. Reverse Characteristics
3
Document ID
Issued Date
AS-3240029
2019/09/10
Revised Date
Revision
Page
A
5
ASD465F
3)Current Derating
4)Capacitance vs. reverse voltage :
40
DC
Duty=70%
Duty=50%
30
Duty=30%
Duty=10%
C (pF)
IF(peak) (A)
Duty=20%
50
75
100
125
150
175
Tc (°C)
VR (V)
Figure 4. Capacitance vs. Reverse Voltage
Figure 3. Current Derating
Package TO-220-2F
4
Document ID
Issued Date
AS-3240029
2019/09/10
Revised Date
Revision
Page
A
5
ASD465F
DISCLAIMER
ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT
TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABITILY,
FUNCTION OR DESIGN OR OTHERWISE.
Copyright ©2019 Anbon Semiconductor Company Ltd.
All rights reserved.
5
Document ID
Issued Date
as-3240029
2019/09/10
Revised Date
Revision
Page
A
5
很抱歉,暂时无法提供与“ASD465F”相匹配的价格&库存,您可以联系我们找货
