AS2301
AS2301
    ANBON(安邦)
    SOT-23
    P沟道,-20V,-2.8A,100mΩ@-4.5V 迭代型号为C52766324 AT2301BS
AS2301 数据手册
AS2301 P-Channel MOSFET SOT-23 Plastic-Encapsulate MOSFETS SOT-23 FEATURE TrenchFET Power MOSFET 1. GATE APPLICATIONS z Load Switch for Portable Devices z DC/DC Converter 2. SOURCE 3. DRAIN MARKING: A1 ■ Maximum ratings (Ta=25℃ unless otherwise noted) Characteristic 特性參數 Symbol 符號 Max 最大值 Unit 單位 Drain-Source Voltage 漏極-源極電壓 BVDSS -20 V Gate- Source Voltage 栅極-源極電壓 VGS +10 V Drain Current (continuous) 漏極電流-連續 ID -2.8 A Drain Current (pulsed) 漏極電流-脉冲 IDM -10 A Total Device Dissipation 總耗散功率 TA=25℃環境溫度爲 25℃ PD 900 mW Junction 結溫 TJ 150 ℃ Storage Temperature 儲存溫度 Tstg -55to+150 ℃ http://www.anbonsemi.com TEL:886-755-23776891 FAX: 886-755-81482182 Page 1 Document ID Issued Date Revised Date Revision Page. AS-3150031 2003/03/08 2012/05/16 D 3 AS2301 P-Channel MOSFET SOT-23 Plastic-Encapsulate MOSFETS ■ Maximum ratings (Ta=25℃ unless otherwise noted) Characteristic 特性參數 Symbol 符號 Min 最小值 Typ 典型值 Max 最大值 Unit 單位 Drain-Source Breakdown Voltage 漏極-源極擊穿電壓(ID = -250uA,VGS=0V) BVDSS -20 — — V Gate Threshold Voltage 栅極開启電壓(ID = -250uA,VGS= VDS) VGS(th) -0.5 — -1.5 V Diode Forward Voltage Drop 内附二極管正向壓降(IS= -0.75A,VGS=0V) VSD — — -1.5 V Zero Gate Voltage Drain Current 零栅壓漏極電流(VGS=0V, VDS= -16V) (VGS=0V, VDS= -16V, TA=55℃) IDSS — — -1 -10 uA Gate Body Leakage 栅極漏電流(VGS=+10V, VDS=0V) IGSS — — +100 nA Static Drain-Source On-State Resistance 静态漏源導通電阻(ID= -2.8A,VGS= -4.5V) RDS(ON) — — 100 mΩ Static Drain-Source On-State Resistance 静态漏源導通電阻(ID= -2A,VGS= -2.5V) RDS(ON) — — 120 mΩ Input Capacitance 輸入電容 (VGS=0V, VDS= -10V,f=1MHz) CISS — 600 — pF Output Capacitance 輸出電容 (VGS=0V, VDS= -10V,f=1MHz) COSS — 120 — pF Turn-ON Time 开启時間 (VDS= -10V, ID= -2.8A, RGEN=6Ω) t(on) — 8 — ns Turn-OFF Time 关断時間 (VDS= -10V, ID= -2.8A, RGEN=6Ω) t(off) — 60 — ns Pulse Width
AS2301
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型放大器,具有高输入阻抗和低输出阻抗,适用于高速光耦应用。
3. 引脚分配:EL817有8个引脚,1脚为输出,2脚为GND,3脚为输入,4脚为Vcc,5脚为输出,6脚为GND,7脚为输入,8脚为Vcc。
4. 参数特性:工作温度范围为-40℃至+85℃,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817内部包含一个发光二极管和一个光敏晶体管,实现电信号的光电隔离。
6. 应用信息:适用于高速光耦通信、工业控制系统等。
7. 封装信息:EL817采用DIP-8封装。
AS2301 价格&库存
很抱歉,暂时无法提供与“AS2301”相匹配的价格&库存,您可以联系我们找货
AS2301
    • 1+0.19620
    库存:10
