1SS355
1SS355
    ANBON(安邦)
    SOD-323
    80V 150MA
1SS355 数据手册
1SS355 150mA Surface Mount Small Signal Switching Diode-90V Package Outline Features • Small surface mounting type. • High Speed. • High reliability with high surge current handling capability. • We declare that the material of product compliance with SOD-323 0.106(2.70) 0.091(2.30) RoHS requirements. • Silicon epitaxial planar chip, metal silicon junction. • Lead-free parts for green partner, exceeds environmental standards of MIL-STD-19500 /228 • Compliant to Halogen-free 0.016(0.40) 0.010(0.25) 0.053(1.35) 0.045(1.15) 0.078(1.95) 0.063(1.60) Mechanical data • Epoxy : UL94-V0 rated flame retardant • Case : Molded plastic, SOD-323 • Terminals :Plated terminals, solderable per MIL-STD-750, 0.010(0.25) 0.002(0.05) 0.035(0.90) 0.023(0.60) Method 2026 • Polarity : Indicated by cathode band • Mounting Position : Any Dimensions in inches and (millimeters) Maximum ratings (AT T =25 C unless otherwise noted) o A PARAMETER SYMBOL Limits UNIT 90 V Peak reverse voltage V RM DC reverse voltage VR 80 V Peak forward current I FM 225 mA Mean rectifying current IO 150 mA I surge 500 mA Surge current (1s) Operating junction temperature range TJ Storage temperature range T STG -55 to +150 o C -55 to +150 o C Electrical Characteristics (AT T =25 C unless otherwise noted) o A PARAMETER MAX. UNIT Forward Voltage(I F=100mAdc) VF 1.2 Reverse Voltage Leakage Current(V R=80Vdc) IR 0.1 V uA Diode Capacitance(V R=0.5V, f=1.0MHz) CT 4.0 pF Revarse Recover Time(V R =6V, I F =10mA, R L =100Ω) t rr 4.0 ns MAX. UNIT 225 mW SYMBOL MIN. TYP. Thermal Characteristics PARAMETER Total Device Dissipation FR-5 SYMBOL Board* 1, T A = 25 OC TYP. PD O Derate Above 25 C 1.8 Thermal Resistance Junction to Ambient Total Device Dissipation Alumina MIN. R θJA 2 556 O Substrate* , T A = 25 C O Derate Above 25 C Thermal Resistance Junction to Ambient mW/ OC O PD 2.4 R θJA 417 C/W mW 300 mW/ OC O C/W 1. FR-5 = 1.0 x 0.75 x 0.062 in. 2. Alumina = 0.4 x 0.3 x 0.024 in. 99.5% alumina. http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 1 Document ID Issued Date Revised Date Revision Page. AS-3120013 2003/03/08 2012/05/16 D 3 1SS355 150mA Surface Mount Small Signal Switching Diode-90V Rating and characteristic curves (1SS355) REVERSE CURRENT : IR (A) FORWARD CURRENT : IF (A) 100m Ta=125°C 75°C 25°C −25°C 10m 1m 100µ 10µ 0 0.2 0.4 0.6 0.8 1.0 1.2 0.1m 10µ 100n Ta=25°C 10n 20 40 60 80 100 120 REVERSE VOLTAGE : VR (V) FORWARD VOLTAGE : VF (V) Fig.4 Reverse recovery time characteristics 10 5 2 1 0.5 0.2 0.1 0 2 4 6 8 10 12 14 REVERSE VOLTAGE : VR (V) Fig.5 Surge current characteristics 100 3 VR=6V Irr=1/10IR SURGE CURRENT : Isurge (A) REVERSE RECOVERY TIME : trr (ns) Ta=75°C 1µ 1n 0 1.4 Ta=125°C CAPACITANCE BETWEEN TERMINALS : CT (pF) 1m 1 2 1 0 0 Fig.3 Capacitance between terminals characteristics Fig.2 Reverse characteristics Fig.1 Forward characteristics 10 20 30 PULSE Single pulse 50 20 10 5 2 1 0.1 1 FORWARD CURRENT : IF (mA) 10 100 1000 10000 PULSE W DTH : TW (ms) Fig.6 Reverse recovery time (trr) measurement circuit 0 01µF D.U.T. 5kΩ PULSE GENERATOR OUTPUT 50Ω 50Ω http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 SAMPL NG OSC LLOSCOPE Page 2 Document ID Issued Date Revised Date Revision Page. AS-3120013 2003/03/08 2012/05/16 D 3 1SS355 150mA Surface Mount Small Signal Switching Diode-90V Pinning information Pin Pin1 Pin2 Simplified outline cathode anode Symbol 1 2 1 2 Marking Type number Marking code 1SS355 S5 Suggested solder pad layout C A B Dimensions in inches and (millimeters) PACKAGE A B C SOD-323 0.032 (0.82) 0.022 (0.56) 0.069 (1.75) Reel packing PACKAGE REEL SIZE SOD-323 7" REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) 4.0 30,000 195*195*150 178 460*400*420 360,000 14.8 3000 http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 3 Document ID Issued Date Revised Date Revision Page. AS-3120013 2003/03/08 2012/05/16 D 3
1SS355 价格&库存
很抱歉,暂时无法提供与“1SS355”相匹配的价格&库存,您可以联系我们找货
1SS355
    • 1+0.10760
    库存:50
