ASD3065A
ASD3065A
    ANBON(安邦)
    TO-220-2
    ASD3065A
ASD3065A 数据手册
ASD3065A 650V,30A Silicon Carbide Schottky Diode Features • Ease of Paralleling • Zero reverse recovery current • Zero forward recovery voltage • Temperature independent switching behaviour • High temperature operation • High frequency operation Key Characteristics VRRM 650 V IF, Tc≤155℃ 30 A QC 101 nC Benefits • Unipolar rectifier • Substantially reduced switching losses • No thermal run-away with parallel devices • Reduced heat sink requirements Applications • Switch Mode Power Supplies (SMPS) • Boost diodes in PFC or DC/DC stages • Motor drives • Solar application,UPS • Power Switching Circuits Part No. ASD3065A http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 Package Type Marking TO-220-2 ASD3065A 1 Document ID Issued Date AS-3240015 2018/09/10 Revised Date / Revision Page A 5 650V,30A Silicon Carbide Schottky Diode ASD3065A Maximum Ratings Parameter Repetitive Peak Reverse Voltage Surge Peak Reverse Voltage DC Blocking Voltage Symbol Value Unit VRRM 650 V VRSM 650 V VDC 650 110 60 30 V 150 A 290 A 429 186 W W Continuous Forward Current Repetitive Peak Forward Surge Current Non-repetitive Peak Forward Surge Current IF IFRM IFSM Test Condition TC=25℃ TC=125℃ TC=155℃ TC=25℃, tp=10ms , Half Sine Wave,D=0.3 TC=25℃, tp=10ms , Half Sine Wave TC=25℃ TC=110℃ A Power Dissipation PTOT Operating Junction Tj -55℃ to 175℃ ℃ Tstg -55℃ to 175℃ ℃ 1 8.8 Nm lbf-in Storage Temperature M3 Screw 6-32 Screw Mounting Torque Thermal Characteristics Parameter Symbol Thermal resistance from junction to case Rth JC http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 Test Condition 2 Value Typ. Unit 0.35 ℃/W Document ID Issued Date AS-3240015 2018/09/10 Revised Date / Revision Page A 5 650V,30A Silicon Carbide Schottky Diode ASD3065A Electrical Characteristics Parameter Symbol Forward Voltage VF Reverse Current IR Total Capacitive Charge QC Test Conditions IF=30A, Tj=25℃ IF=30A, Tj=175℃ VR=650V, Tj=25℃ VR=650V, Tj=175℃ VR=400V, Tj=150℃ 101 - VR=0V, Tj=25℃, f=1MHZ 2150 2300 VR=200V, Tj=25℃, f=1MHZ 188 191 VR=400V, Tj=25℃, f=1MHZ 183 184 VR Qc   0 Total Capacitance C Numerical Typ. Max. 1.46 1.7 1.8 2.5 10 50 20 100 C(V )dV Unit V µA nC pF Performance Graphs 1) Forward IV characteristics as a function of Tj : http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 2) Reverse IV characteristics as a function of Tj : 3 Document ID Issued Date AS-3240015 2018/09/10 Revised Date / Revision Page A 5 650V,30A Silicon Carbide Schottky Diode ASD3065A 3) Current Derating 4) Capacitance vs. reverse voltage : Package TO-220-2 http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 4 Document ID Issued Date AS-3240015 2018/09/10 Revised Date / Revision Page A 5 650V,30A Silicon Carbide Schottky Diode ASD3065A DISCLAIMER ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABITILY, FUNCTION OR DESIGN OR OTHERWISE. Copyright ©2018 Anbon Semiconductor Company Ltd. All rights reserved. http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 5 Document ID Issued Date FM-3240015 2018/09/10 Revised Date / Revision Page A 5
ASD3065A 价格&库存
很抱歉,暂时无法提供与“ASD3065A”相匹配的价格&库存,您可以联系我们找货
