ESD3Z15C
ESD3Z15C
    ANBON(安邦)
    SOD-323
    双向ESD 15V截止 峰值浪涌电流:10A
ESD3Z15C 数据手册
ESD3ZxxC SERIES Surface Mount Bi-Directional TVS For ESD Protection Diode - 3.3V - 36 V Package outline Features • This series is designed for average power 320W approximated ESD protection, different V RWM , different peak pulse power available. 0.053(1.35) 0.045(1.15) 0.071(1.80) 0.063(1.60) MIL-STD-19500 /228 0.016(0.40) 0.010(0.25) SOD-323 • Protects one I/O or power line . • Low clamping voltage . • Working voltages: 3.3V, 5.0V, 12V, 15V, 18V, 24V, 36V. • Low leakage current . • Lead-free parts meet environmental standards of • Compliant to Halogen-free. IEC compatibility 0.039(1.00) 0.031(0.80) 0.003(0.08) 0.016(0.40) • IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) • IEC61000-4-4 (EFT) 40A (5/50ηs) • IEC61000-4-5 (Lightning) 12A (8/20us) Applications 0.106(2.70) 0.091(2.30) • Cell Phone Handsets and Accessories • Microprocessor based equipment • Personal Digital Assistants (PDA’s) • Notebooks, Desktops, and Servers • Portable Instrumentation Dimensions in inches and (millimeters) Mechanical data • Epoxy:UL94-V0 rated flame retardant • Case : Molded plastic, SOD-323 • Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 • Mounting Position : Any • Weight : Approximated 0.005 gram Maximum ratings (at T =25 C unless otherwise noted) o A PARAMETER CONDITIONS Total power dissipation SYMBOL P PP Peak pulse power (tp = 8/20us) TJ Operating junction temperature range Storage temperature range T STG VALUE UNIT 320 W -55 to +150 o C -55 to +150 o C Electrical characteristics (at T =25 C unless otherwise noted) o A V RWM (V) I R(uA) @V RWM (Max.) (Max.) ESD3Z3.3C 3.3 200 ESD3Z5.0C 5.0 ESD3Z12C 12 ESD3Z15C ESD3Z18C Part No. V BR(V) @I T (Note 2) (Min.) IT (mA) V C(V) @I PP=1.0A I PP (A) V C(V) @ I PP CJ (pF) (Max.) (Max.) (Max.) (Max.) 7.0 25.0 16.0 350 4.0 1.0 10 6.0 1.0 9.8 24.0 17.0 260 1 13.3 1.0 19.0 13.0 25.0 110 15 1 16.7 1.0 24.0 9.0 32.0 100 18 1 19.0 1.0 28.0 8.0 35.0 90 ESD3Z24C 24 1 26.7 1.0 43.0 6.0 52.0 75 ESD3Z36C 36 1 40.0 1.0 60.0 4.0 75.0 35 Note 1. Surge current waveform per Fig.1 2. V BR is measured with a pulse test current I T at an ambient temperature of 25°C. http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 1 Document ID Issued Date Revised Date Revision Page. AS-3110017 2003/03/08 2017/11/16 E 3 ESD3ZxxC SERIES Surface Mount Bi-Directional TVS For ESD Protection Diode - 3.3V - 36 V Typical characteristics (at T =25 C unless otherwise noted) o A I I PP IT IR V C V BR V RWM V V RWMV BRV C IR IT I PP Bi-Directional TVS V C : Clamping voltage @ I PP I PP : Maximum reverse peak pulse current V RWM : Maximum working peak reverse voltage I R : Maximum reverse leakage current @V RWM V BR : Breakdown voltage @I T I T : Test current C J : Max. capacitance @V R = 0V and f = 1MHz Rating and characteristic curves (ESD3ZxxC SERIES) http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 1 Document ID Issued Date Revised Date Revision Page. AS-3110017 2003/03/08 2017/11/16 E 3 ESD3ZxxC SERIES Surface Mount Bi-Directional TVS For ESD Protection Diode - 3.3V - 36 V Pinning information Pin Simplified outline Symbol Bi-Directional Marking Type number Marking code ESD3Z3.3C ESD3Z5.0C ESD3Z12C ESD3Z15C ESD3Z18C ESD3Z24C ESD3Z36C 03B/2A 05B/3M 12B/12C 15B/2J 2K 24B/M 2N Suggested solder pad layout C A B Dimensions in inches and (millimeters) http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 PACKAGE A B C SOD-323 0.033 (0.83) 0.025 (0.63) 0.063 (1.60) Page 1 Document ID Issued Date Revised Date Revision Page. AS-3110017 2003/03/08 2017/11/16 E 3
ESD3Z15C 价格&库存
很抱歉,暂时无法提供与“ESD3Z15C”相匹配的价格&库存,您可以联系我们找货
