BAT42W / BAT43W
SMD Small Signal Schottky Diode
Absolute Maximum Ratings
Symbol
TA = 25°C unless otherwise noted
Parameter
PD
Value
Units
Power Dissipation
TSTG
Storage Temperature Range
400
mW
-65 to +125
°C
TJ
Operating Junction Temperature
+125
°C
VRRM
Repetitive Peak Reverse Voltage
30
V
Maximum DC Blocking Voltage
30
V
IF(AV)
Average Forward Rectified Current
200
mA
IFSM
Peak Forward Surge Current
4
A
VR
These ratings are limiting values above which the serviceability of the diode may be impaired.
Specification Features:
Low Forward Voltage Drop
Flat Lead SOD-123 Small Outline Plastic Package
Surface Device Type Mounting
RoHS Compliant
DEVICE MARKING CODE:
Device Type
Device Marking
BAT42W
C1
BAT43W
C2
Green EMC
Matte Tin(Sn) Lead Finish
Band Indicates Cathode
Electrical Characteristics
Symbol
Parameter
Limits
Test Condition
Min
BV
IR=100µA
Breakdown Voltage
IR
Reverse Leakage Current
VF
Forward Voltage
TCBAT42,
TCBAT42,
BAT42W
BAT43W
BAT42W, BAT43W
TRR
Reverse Recovery Time
Unit
Max
30
Volts
VR=25V
500
IF=10mA
0.40
IF=50mA
0.65
IF=2mA
0.26
0.33
IF=15mA
0.45
IF=200mA
1.0
nA
Volts
IF=IR=10mA
RL=100Ω
5 (Typical)
nS
7 (Typical)
pF
IRR=1mA
C
Capacitance
VR=1V, f=1MHZ
Page 1
Document ID
Issued Date
Revised Date
A S-221354
2009/08/10
2011/08/12
2
Revision
B
Page.
4
BAT42W / BAT43W
Typical Performance Characteristics
Total Capacitance
Forward Voltage vs Ambient Temperature
Page 2
Document ID
Issued Date
Revised Date
A S-221354
2009/08/10
2011/08/12
2
Revision
B
Page.
4
BAT42W / BAT43W
Reverse Current vs Reverse VoltageReverse
Page 3
Document ID
Issued Date
Revised Date
A S-221354
2009/08/10
2011/08/12
Revision
B
Page.
4
BAT42W / BAT43W
SOD-123 Package Outline
NOTE: The above package outline is similar to JEITA SC-90.
Page 4
Document ID
Issued Date
Revised Date
A S-221354
2009/08/10
2011/08/12
Revision
B
Page.
4
很抱歉,暂时无法提供与“BAT43W”相匹配的价格&库存,您可以联系我们找货
