AS5822-AL
AS5822-AL
    ANBON(安邦)
    SMA(DO-214AC)
    特性:批量工艺设计,出色的功耗提供更好的反向漏电流和热阻。 低轮廓表面贴装应用,以优化电路板空间。 高电流能力,低正向压降。 过压保护。 超高速开关。 硅外延平面芯片,金属硅结。 无铅部件符合RoHS...
AS5822-AL 数据手册
AS5820-AL THRU AS5822-AL 3.0A Surface Mount Schottky Barrier Rectifiers - 20V-40V Package outline Features • Batch process design, excellent power dissipation offers better reverse leakage current and thermal resistance SMA-L • Low profile surface mounted application in order to optimize board space 0.209(5.3) 0.185(4.7) • High current capability, low forward voltage drop • Guardring for overvoltage protection • Ultra high-speed switching • Silicon epitaxial planar chip, metal silicon junction • Lead-free parts meet RoHS requirements • Suffix "-H" indicates Halogen free parts, ex. AS5820-AL-H 0.012(0.3) Typ. 0.114(2.9) 0.091(2.3) Mechanical data 0.080(2.0) 0.063(1.6) • Epoxy:UL94-V0 rated flame retardant • Case : Molded plastic, DO-214AC / SMA-L • Terminals : Solder plated, solderable per 0.032(0.8) Typ. 0.032 (0.8) Typ. MIL-STD-750, Method 2026 • Polarity : Indicated by cathode band • Mounting Position : Any • Weight : Approximated 0.05 gram Maximum ratings Dimensions in inches and (millimeters) (AT T A =25 o C unless otherwise noted) PARAMETER SYMBOLS AS5820-AL AS5821-AL AS5822-AL UNITS Maximum repetitive peak reverse voltage VRRM 20 30 40 V Maximum RMS voltage VRMS 14 21 28 V 20 30 40 V Maximum continuous reverse voltage VR Maximum average forward rectified current IO 3.0 A IFSM 80 A CJ 250 pF Operating junction temperature range TJ -55 to +125 °C Storage temperature range TSTG -65 to +175 °C Non-repetitive peak forward surge current 8.3ms single half sine-wave Typical junction capacitance (Note 1) Electrical characteristics (AT o T A =25 C unless otherwise noted) PARAMETER SYMBOLS AS5820-AL AS5821-AL Maximum instantaneous forward voltage at IF=3.0A VF 0.475 0.50 Maximum reverse leakage current at rated V R IR TJ =25 °C TJ =100 °C AS5822-AL UNITS V 0.50 mA mA 0.5 20 Thermal characteristics PARAMETER SYMBOLS Typical thermal resistance junction to ambient (Note 2) Typical thermal resistance junction to case (Note 2) AS5820-AL RθJA RθJC AS5821-AL AS5822-AL UNITS °C / W °C / W 52 26 Notes1: Measured at 1MHz and applied reverse voltage of 4.0V D.C 2: Mounted on FR-4 PCB copper, minimum recommended pad layout Page 1 Document ID Issued Date Revised Date Revision Page. AS-121628 2008/02/10 2015/06/02 F 3 Rating and characteristic curves (AS5820-AL THRU AS5822-AL) FIG.2-TYPICAL FORWARD FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 50 2.5 0 20 40 60 80 100 120 140 160 180 200 LEAD TEMPERATURE (°C) PEAK FORWAARD SURGE CURRENT,(A) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT L 2-A 582 -AL 3.0 ~AS -AL 821 0.5 820 1.0 10 1.0 AS 5 1.5 AS 5 2.0 INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 3.0 TJ=25 C Pulse Width 300us 1% Duty Cycle 0.1 100 .01 80 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 60 8.3ms Single Half TJ=25 C Sine Wave 40 JEDEC method 20 FIG.5 - TYPICAL REVERSE 0 1 5 50 10 CHARACTERISTICS 100 100 NUMBER OF CYCLES AT 60Hz 10 REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 700 600 500 400 300 200 TJ=100°C 1.0 0.1 TJ=25°C 0.01 100 0 .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) 0.001 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) Page 2 Document ID Issued Date Revised Date Revision Page. AS-121628 2008/02/10 2015/06/02 F 3 AS5820-AL THRU AS5822-AL 3.0A Surface Mount Schottky Barrier Rectifiers - 20V-40V Pinning information Pin Pin1 Pin2 Simplified outline cathode anode 1 Symbol 2 1 2 Marking Type number Marking code AS5820-AL AS5821-AL AS5822-AL SK32 S K33 SK34 Suggested solder pad layout C A B Dimensions in inches and (millimeters) PACKAGE A B C SMA-L 0.110 (2.80) 0.059 (1.50) 0.110 (2.80) Page 3 Document ID Issued Date Revised Date Revision Page. AS-121628 2008/02/10 2015/06/02 F 3
AS5822-AL
物料型号: - AS5820-AL - AS5821-AL - AS5822-AL
器件简介: - 这些是3.0A表面安装肖特基势垒整流器,适用于20V至40V的电压范围。 - 具有批量处理设计,优秀的功耗散能力,更好的反向漏电流和热阻。 - 低轮廓表面安装应用,以优化板空间。 - 高电流能力,低正向电压降。 - 保护环用于过压保护。 - 超高速开关。 - 硅外延平面芯片,金属硅结。 - 无铅部件符合RoHS要求。 - 后缀"-H"表示无卤部件,例如AS5820-AL-H。
引脚分配: - 引脚1为阴极,引脚2为阳极。
参数特性: - 最大重复峰值反向电压:20V、30V、40V - 最大RMS电压:14V、21V、28V - 最大连续反向电压:20V、30V、40V - 最大平均正向整流电流:3.0A - 非重复峰值正向浪涌电流(8.3ms单半正弦波):80A - 典型结电容:250pF - 工作结温范围:-55至+125摄氏度 - 存储温度范围:-65至+175摄氏度
功能详解: - 正向电流降额曲线、最大非重复正向浪涌电流特性、典型结电容和反向漏电流特性等图表提供了器件的性能数据。
应用信息: - 适用于需要高电流能力和低正向电压降的应用。
封装信息: - 封装类型:SMA-L - 尺寸:0.209(5.3) x 0.185(4.7) x 0.012(0.3)英寸(典型值) - 引脚:镀锡,符合MIL-STD-750方法2026的可焊性 - 极性:通过阴极带指示 - 安装位置:任意 - 重量:大约0.05克
机械数据: - 环氧树脂:UL94-V0级阻燃 - 外壳:模塑塑料,DO-214AC / SMA-L
热特性: - 典型结到环境的热阻(注2) - 典型结到外壳的热阻(注2)
注释: - 注1:在1MHz和4.0V直流反向电压下测量 - 注2:安装在FR-4 PCB铜上,最小推荐垫布局
AS5822-AL 价格&库存
很抱歉,暂时无法提供与“AS5822-AL”相匹配的价格&库存,您可以联系我们找货
