ASD465D
ASD465D
    ANBON(安邦)
    TO252
    碳化硅SiC
ASD465D 数据手册
ASD465D 650V,4A Silicon Carbide Schottky Diode Features • Ease of Paralleling • Zero reverse recovery current • Zero forward recovery voltage • Temperature independent switching behaviour • High temperature operation • High frequency operation Key Characteristics 650 V IF, Tc≤155℃ 4 A QC 9 nC VRRM Benefits • Unipolar rectifier • Substantially reduced switching losses • No thermal run-away with parallel devices • Reduced heat sink requirements Applications • Switch Mode Power Supplies (SMPS) • Boost diodes in PFC or DC/DC stages • Motor drives • Solar application,UPS • Power Switching Circuits Part No. Package Type ASD465D TO-252-2 http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 1 Marking ASD465D Document ID Issued Date AS-3240028 2019/09/10 Revised Date / Revision Page A 5 650V,4A Silicon Carbide Schottky Diode ASD465D Maximum Ratings Parameter Repetitive Peak Reverse Voltage Surge Peak Reverse Voltage DC Blocking Voltage Symbol Value Unit VRRM 650 V VRSM 650 V VDC 650 13 6 4 V 15 A 35 A 51 21 W W Continuous Forward Current Repetitive Peak Forward Surge Current Non-repetitive Peak Forward Surge Current IF IFRM IFSM Test Condition TC=25℃ TC=135℃ TC=155℃ TC=25℃, tp=10ms , Half Sine Wave,D=0.3 TC=25℃, tp=10ms , Half Sine Wave TC=25℃ TC=110℃ A Power Dissipation PTOT Operating Junction Tj -55℃ to 175℃ ℃ Tstg -55℃ to 175℃ ℃ 1 8.8 Nm lbf-in Storage Temperature M3 Screw 6-32 Screw Mounting Torque Thermal Characteristics Parameter Symbol Thermal resistance from junction to case Rth JC http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 Test Condition 2 Value Typ. Unit 2.9 ℃/W Document ID Issued Date AS-3240028 2019/09/10 Revised Date / Revision Page A 5 650V,4A Silicon Carbide Schottky Diode ASD465D Electrical Characteristics Parameter Symbol Forward Voltage VF Reverse Current IR Total Capacitive Charge QC IF=4A, Tj=25℃ I F=4A, Tj=175℃ VR=650V, Tj=25℃ VR=650V, Tj=175℃ VR=400V, Tj=150℃ 9 - VR=0V, Tj=25℃, f=1MHZ 230 150 VR=200V, Tj=25℃, f=1MHZ VR=400V, Tj=25℃, f=1MHZ 24 20 25 21 VR Qc   0 C Total Capacitance Numerical Typ. Max. 1.65 1.4 1.7 2.3 1 10 100 5 Test Conditions C (V )dV Unit V µA nC pF Performance Graphs 2) Reverse IV characteristics as a function of Tj : IF (A) IR (μA) 1) Forward IV characteristics as a function of Tj : VF (V) VR (V) Figure 1. Forward Characteristics http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 Figure 2. Reverse Characteristics 3 Document ID Issued Date AS-3240028 2019/09/10 Revised Date / Revision Page A 5 650V,4A Silicon Carbide Schottky Diode ASD465D 3)Current Derating 4)Capacitance vs. reverse voltage : 50 10% Duty 20% Duty 30% Duty 50% Duty 70% Duty DC 40 C (pF) IF(peak) (A) 30 20 10 0 25 50 75 100 TC ( °C ) 125 150 175 VR (V) Figure 4. Total Capacitance vs. Reverse Voltage Figure 3. Current Derating Package TO-252-2 http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 4 Document ID Issued Date AS-3240028 2019/09/10 Revised Date / Revision Page A 5 ASD465D 650V,4A Silicon Carbide Schottky Diode DISCLAIMER ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABITILY, FUNCTION OR DESIGN OR OTHERWISE. Copyright ©2019 Anbon Semiconductor Company Ltd. All rights reserved. http://www.anbonsemi.com TEL:+86-755-23776891 FAX:+86-755-81482182 5 Document ID Issued Date AS-3240028 2019/09/10 Revised Date / Revision Page A 5
ASD465D 价格&库存
很抱歉,暂时无法提供与“ASD465D”相匹配的价格&库存,您可以联系我们找货
