BAS40-05
BAS40-05
    ANBON(安邦)
    SOT-23
    特性:低正向电流。 有保护环。 低二极管电容。 无铅部件,符合环保标准。 后缀 “-H” 表示无卤部件
BAS40-05 数据手册
Formosa MS BAS40 / BAS40-04 / BAS40-05 / BAS40-06 SMD Small Signal Schottky Diode 120mA Surface Mount Small Signal Schottky Diodes- 40V Package outline SOT-23 0.020 (0.50) 0.034 (0.85) (B) 0.012 (0.30) .084(2.10) .068(1.70) 0.120 (3.04) 0.110 (2.80) standards of MIL-STD-19500 /228 • Suffix "-H" indicates Halogen-free part, ex.BAS40-H. 0.045 (1.15) Features • Low forward current • Guard ring protected • Low diode capacitance • Lead-free parts for green partner, exceeds environmental (C) (A) 0.063 (1.60) 0.027 (0.67) 0.047 (1.20) 0.013 (0.32) 0.108 (2.75) Mechanical data 0.051 (1.30) • Epoxy:UL94-V0 rated flame retardant • Case : Molded plastic, SOT-23 • Terminals : Solder plated, solderable per 0.003 (0.09) 0.007 (0.18) 0.083 (2.10) 0.035 (0.89) Dimensions in inches and (millimeters) MIL-STD-750, Method 2026 • Mounting Position : Any • Weight : Approximated 0.008 gram Maximum ratings and Electrical Characteristics (AT T =25 C unless otherwise noted) o A PARAMETER CONDITIONS Symbol MIN. TYP. MAX. V mA mA Continuous reverse voltage Repetitive Peak forward surge current tp
BAS40-05 价格&库存
很抱歉,暂时无法提供与“BAS40-05”相匹配的价格&库存,您可以联系我们找货
