GBLC12C
GBLC12C
    ANBON(安邦)
    SOD-323
    ESD 12V截止 峰值浪涌电流:6A
GBLC12C 数据手册
GBLC03 thru GBLC24C ESD electrostatic protection element FEATURES ◆ 350 Watts Peak Pulse Power (tp=8/20μs) ◆ Replacement for SOD323 ◆ Protects two I/O and one power line ◆ Low Clamping Voltage ◆ Reverse Voltage: 5 V ◆ Low Leakage Current ◆ Response Time is Typically < 1 ns IEC COMPATIBILITY (EN61000-4) ◆ IEC 61000-4-2 ESD air±15KV,contact±8KV ◆ IEC 61000-4-4 ETF 20A (5/50ns) ◆ IEC 61000-4-5 Surge 17A (8/20μs) Mechanical Characteristics ◆ JEDEC SOD323 package ◆ RoHS Compliant Applications ◆ ◆ ◆ ◆ ◆ Cellular Handsets and Accessories Portable Electronics Industrial Controls Set-Top Box Servers, Notebook, and Desktop PC Schematic & PIN Configuration SOD323 Top View http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 1 Document ID Issued Date Revised Date Revision Page. AS-3110020 2003/03/08 2012/05/16 D 5 GBLC03 thru GBLC24C ESD electrostatic protection element ABSOLUTE MAXIMUM RATING Rating Symbol Value Units Peak Pulse Power (tp = 8/20µs) PPK 350 Watts Lead Soldering Temperature TL 260 (10sec) Operating Temperature TJ -55~150 o C o C Storage Temperature TSTG -40~120 IEC61000-4-2 VPP Air 15 Contact 8 o C/W KV ELECTRICAL CHARACTERISTICS GBLC03C Parameter Reverse Stand-Off Voltage Symbol Conditions Min Typical VRWM Max Units 3.3 V VBR It=1mA Leakage Current IR @VRWM 5 μA Clamping Voltage VC @1A 7 V Clamping Voltage VC @19A 19 V Junction Capacitance CJ VR=0V,f=1Mhz Symbol Conditions Reverse Breakdown Voltage 4 V 0.8 pf GBLC05C Parameter Reverse Stand-Off Voltage Min Typical VRWM Max Units 5 V VBR It=1mA Leakage Current IR @VRWM 5 μA Clamping Voltage VC @1A 9.8 V Clamping Voltage VC @17A 18.3 V Junction Capacitance CJ VR=0V,f=1Mhz Reverse Breakdown Voltage http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 2 6 V 0.8 pf Document ID Issued Date Revised Date Revision Page. AS-3110020 2003/03/08 2012/05/16 D 5 GBLC03 thru GBLC24C ESD electrostatic protection element ELECTRICAL CHARACTERISTICS GBLC08C Parameter Reverse Stand-Off Voltage Symbol Conditions Min Typical VRWM Max Units 8.0 V VBR It=1mA Leakage Current IR @VRWM 2 μA Clamping Voltage VC @1A 13.4 V Clamping Voltage VC @17A 18.5 V Junction Capacitance CJ VR=0V,f=1Mhz Symbol Conditions Reverse Breakdown Voltage 8.5 V 0.8 pf GBLC12C Parameter Reverse Stand-Off Voltage Min Typical VRWM Max Units 12 V VBR It=1mA Leakage Current IR @VRWM 1 μA Clamping Voltage VC @1A 19 V Clamping Voltage VC @11A 28.6 V Junction Capacitance CJ VR=0V,f=1Mhz Symbol Conditions Reverse Breakdown Voltage 13.3 V 0.8 pf GBLC24C Parameter Reverse Stand-Off Voltage Min Typical VRWM Max Units 24 V VBR It=1mA Leakage Current IR @VRWM 1 μA Clamping Voltage VC @1A 43 V Clamping Voltage VC @10A 31.8 V Junction Capacitance CJ VR=0V,f=1Mhz Reverse Breakdown Voltage http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 3 26.7 V 0.8 pf Document ID Issued Date Revised Date Revision Page. AS-3110020 2003/03/08 2012/05/16 D 5 GBLC03 thru GBLC24C ESD electrostatic protection element http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 4 Document ID Issued Date Revised Date Revision Page. AS-3110020 2003/03/08 2012/05/16 D 5 GBLC03 thru GBLC24C ESD electrostatic protection element Marking Type number Marking code GBLC03C GBLC05C GBLC08C GBLC12C GBLC24C CA1 5B/AC 8B/BC AB CB/HC Example CA1 OUTLINE DRAWING - SOD323 http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 5 Document ID Issued Date Revised Date Revision Page. AS-3110020 2003/03/08 2012/05/16 D 5
GBLC12C 价格&库存
很抱歉,暂时无法提供与“GBLC12C”相匹配的价格&库存,您可以联系我们找货
GBLC12C
    • 1+0.61880
    库存:5
