AESD0524P
AESD0524P
    ANBON(安邦)
    DFN-10(2.5x1)
    ESD 5V截止 峰值脉冲电流:5A@8/20US
AESD0524P 数据手册
AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY Dimensions DFN2510 Features • Ultra low capacitance: 0.3pF typical (I/O to I/O) • Ultra low leakage: nA level • Low operating voltage: 5V • Low clamping voltage • Up to 4 lines protects • Leadless flow-through package • Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±25kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20µs) • Pin Configuration NC NC GND NC NC I/O_1 I/O_2 GND I/O_3 I/O_4 RoHS Compliant Applications • HDMI 1.3 & 1.4, USB 2.0 & 3.0 and MDDI ports • Monitors and flat panel displays • Set-top box and Digital TV • Video graphics cards • Digital Video Interface (DVI) • Notebook Computers • PCI Express and Serial SATA Ports Marking Information 0524S = Device Marking Code YYWW = Date Code Dot denotes Pin1 0524S YYWW Mechanical Characteristics • Package: DFN2510 (2.5×1.0×0.5mm) • Lead Finish: Matte Tin • Case Material: “Green” Molding Compound. • UL Flammability Classification Rating 94V-0 • Moisture Sensitivity: Level 3 per J-STD-020 Part Number Packaging Reel Size • Terminal Connections: See Diagram Below AESD0524P 3000/Tape & Reel 7 inch • Marking Information:0524S or 5R2P or AEB http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Ordering Information Page 1 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 100 W Peak Pulse Current (8/20µs) IPP 5 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±25 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 5 V Any I/O pin to ground V IT = 1mA, any I/O pin to ground 6 Test Condition Reverse Leakage Current IR 0.5 µA VRWM = 5V, any I/O pin to ground Clamping Voltage VC 15 V IPP = 1A (8 x 20µs pulse), any I/O pin to ground Clamping Voltage VC 20 V IPP = 5A (8 x 20µs pulse), any I/O pin to ground Junction Capacitance CJ 0.4 pF VR = 0V, f = 1MHz, between I/O pins Junction Capacitance CJ 0.8 pF VR = 0V, f = 1MHz, any I/O pin to ground http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 0.3 Page 2 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY Typical Performance Characteristics (TA=25°C unless otherwise Specified) 10 Peak Pulse Power_Ppp (W) Junction Capacitance_Cj (pF) 1 0.8 0.6 0.4 0.2 0 1 0.1 0.01 0 1 2 3 4 Reverse Voltage_VR (V) 5 0.1 Junction Capacitance vs. Reverse Voltage 16 10 100 1000 120 14 100 12 % of Rated Power Clamping Voltage_Vc (V) 1 Pulse Duration_tp (us) Peak Pulse Power vs. Pulse Time 10 8 6 4 80 60 40 20 2 0 0 0 1 2 3 4 5 Peak Pulse Current_Ipp (A) 6 0 Clamping Voltage vs. Peak Pulse Current 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 Power Derating Curve 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 20 40 Time_t(uS) 60 80 ESD Clamping Voltage 8 X 20uS Pulse Waveform http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 8 kV Contact per IEC61000−4−2 Page 3 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY Typical Application The AESD0524P is designed for easy PCB layout by allowing the traces to run straight through the device . The PCB traces could be used to connect the pin pairs for each line. For example, line 1 enters at pin 1 and exits at pin 10 and the PCB trace connects Pin 1 and Pin 10 together. Ground is connected at Pin 3 and Pin 8. 1 10 2 9 3 8 4 7 5 6 AESD0524P on USB 3.0 Port Application Vbus Vbus DD+ ID GND MicB_SSTX- MicB_SSTX+ GND_DRAIN MicB_SSRX- MicB_SSRX+ http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 4 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY AESD0524P on DVI Port Application http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 5 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY AESD0524P on HDMI Port Application TMDS D2+ GND TMDS D2TMDS D1+ GND TMDS D1TMDS D0+ GND TMDS D0HDMI Graphic Video Controller TMDS Clock+ GND TMDS ClockCEC NC SCL SDA GND 5V Power Hot Plug Detect http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 6 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY AESD0524P on VGA Port Application AESD0524P on eSATA Port Application http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 7 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY AESD0524P on MDDI Port Application ULC0524P ULC0524P ULC0511CDN ULC0511CDN ULC0511CDN SD05 ULC0511CDN SD05 AESD0524P on 10/100 Base Ethernet Port Application http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 8 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9 AESD0524P ULTRA LOW CAPACITANCE TVS DIODE ARRAY DFN2510 Package Outline Drawing INCHES NOM MAX E SYM DIMENSIONS MILLIMETERS MIN NOM MAX MIN TOP VIEW L2 L1 L SIDE VIEW A 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.15 0.20 0.25 0.006 0.008 0.010 b1 0.35 0.40 0.45 0.014 0.016 0.018 b2 0.20 0.25 0.30 0.008 0.010 0.012 c 0.10 0.15 0.20 0.004 0.006 0.008 D 2.45 2.50 2.55 0.098 0.100 0.102 e 0.50BSC 0.020BSC Nd 2.00BSC 0.080BSC E 0.95 1.00 1.05 0.038 0.040 0.042 L 0.35 0.40 0.45 0.014 0.016 0.018 L1 0.075REF 0.003REF L2 0.050REF 0.002REF h 0.08 0.12 0.15 0.003 0.005 0.006 R 0.05 0.10 0.15 0.002 0.004 0.006 BOTTOM VIEW Suggested Land Pattern SYM http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 DIMENSIONS MILLIMETERS INCHES X1 0.200 0.008 X2 0.400 0.016 X3 0.500 0.020 Y 0.600 0.024 Z 1.400 0.056 Page 9 Document ID Issued Date Revised Date Revision Page. AS-311P017 2003/03/08 2012/05/16 D 9
AESD0524P 价格&库存
很抱歉,暂时无法提供与“AESD0524P”相匹配的价格&库存,您可以联系我们找货
