TIGER CLAW™
PASS-THROUGH SOCKET
(2.54 mm) .100" PITCH • BCS SERIES
BCS
Mates:
TSW, MTSW, HTSW,
HMTSW, TSS, ZSS, DW, EW,
ZW, HW, TSM, MTLW, PHT
BCS
-1
NO. PINS
PER ROW
01 thru 50
SPECIFICATIONS
PLATING
OPTION
–F
ENTRY
OPTION
–S
= Gold flash
on contact,
Matte Tin on tail
–TE
= Single
–D
OTHER
OPTION
–“XXX”
= Top Entry
= Polarized Position
(–BE not available)
–DE
= Double
–L
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Voltage Rating:
495 VAC
(-TE/-DE/-PE mated with TSM)
450 VAC
(-HE mated with TSW)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(4.34 mm) .171" to
(7.24 mm) .285" from top,
(5.64 mm) .222" plus board
thickness minimum from bottom.
–HE is (4.34 mm) .171"
to (6.35 mm) .250"
ROW
OPTION
= Top Entry
(For Bottom Entry
specify –DE–BE)
Cannot be used with
plated through-holes
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–PE
= Pass-through Entry
(For Bottom Entry
specify –PE–BE)
–HE
= Horizontal Entry
PROCESSING
Lead–Free Solderable:
Yes
MATES
BCS/TSW
[1RRI3RVLWLRQV
CURRENT RATING
(PER PIN)
BCS/TSM
4.6 A
5.0 A
2 POSITIONS POWERED
ALSO AVAILABLE
MOQ Required
—TE
Other Platings
—DE
—PE
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
—HE
samtec.com?BCS
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“BCS-118-L-S-DE-BE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 12+32.1789012+4.15910
