BCS-141-L-S-TE
BCS-141-L-S-TE
    SAMTEC(申泰)
    CONN RCPT 41POS .100" SNGL VERT
BCS-141-L-S-TE 数据手册
BCS–108–L–D–HE F-215 BCS–110–L–S–DE BCS–110–L–S–HE BCS–115–L–D–TE BCS–112–L–D–PE (2,54 mm) .100" BCS SERIES ™ TIGER CLAW PASS-THROUGH SOCKET Mates with: TSW, MTSW, HTSW, HMTSW, TSS, ZSS, DW, EW, ZW, HW, TSM, MTLW, PHT 1 BCS PLATING OPTION NO. PINS PER ROW ENTRY OPTION ROW OPTION –S SPECIFICATIONS For complete specifications see www.samtec.com?BCS = Gold flash on contact, Matte Tin on tail Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating (BCS/TSW): 4.6 A per pin (1 pin powered per row) Voltage Rating: 475 VAC (-TE/-DE/-PE mated with TSM) 450 VAC (-HE mated with TSW) Operating Temp Range: -55°C to +125°C Contact Resistance: 10 mΩ Insertion Depth: (4,34 mm) .171" to (7,24 mm) .285" from top, (5,64 mm) .222" plus board thickness minimum from bottom. –HE is (4,34 mm) .171" to (6,35 mm) .250" Insertion Force: (Single contact only) 5 oz (1,39 N) avg. (.025" (0,64 mm) SQ pin) Withdrawal Force: (Single contact only) 3 oz (0,83 N) avg. (.025" (0,64 mm) SQ pin) RoHS Compliant: Yes Lead–Free Solderable: Yes –“XXX” = Single –F OTHER OPTION = Polarized Position (–BE not available) –D = Double –L = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail 01 thru 50 –TE 01 = Top Entry 02 (3,05) .120 (0,25) .010 (2,54) .100 (2,54) .100 (0,89) .035 SQ TYP 02 –DE (2,54) .100 (5,08) .200 01 (0,25) .010 (3,05) .120 (2,54) .100 x No. of Positions (4,06) .160 (1,78) .070 = Top Entry (For Bottom Entry specify –DE–BE) Cannot be used with plated through-holes (7,37) .290 –PE RECOGNITIONS (3,25) .128 (0,48) .019 For complete scope of recognitions see www.samtec.com/quality (2,54) .100 (0,51) .020 (0,25) .010 (5,08) .200 (7,62) .300 = PassThrough Entry (For Bottom Entry specify –PE–BE) FILE NO: 090871_0_000 APPLICATIONS ALSO AVAILABLE (MOQ Required) BCS TSW (0,89) .035 SQ TYP (8,13) .320 (2,79) .110 (3,18) .125 (0,25) .010 • Other platings Contact Samtec. HORIZONTAL –HE = Horizontal Entry (5,72) .225 (5,33) .210 (3,18) .125 Note: Some lengths, styles and options are non-standard, non-returnable. (0,51) .020 (2,54) .100 (7,87) .310 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
BCS-141-L-S-TE 价格&库存
很抱歉,暂时无法提供与“BCS-141-L-S-TE”相匹配的价格&库存,您可以联系我们找货
