F-218
BKS–125–01–L–V
BKS–115–01–L–V
BKS–155–01–L–V–P
BKT–111–01–L–V
BKT–127–01–L–V–S–P
BKT–133–03–L–V
BKT–131–05–L–V–S
(1.00 mm) .0394"
BKT, BKS SERIES
POLARIZED MICRO HEADER & SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?BKT or
www.samtec.com?BKS
Insulator Material:
Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.8 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(1.40 mm) .055" minimum
Normal Force:
40 grams (0.39 N) average
Max Cycles:
100 with 10 µ" (0.25 µm) Au
RoHS Compliant:
Yes
BKT
NO. OF
POSITIONS
1
Mates with:
BKS
07 thru 69
02
(5.08)
.200
(2.54) (5.59)
.100 .220
(1.00)
.03937
A
B
–01
(1.93)
.076
(2.29)
.090
(2.79)
.110
(3.78)
.149
(4.80)
.189
(3.91)
.154
(4.27)
.168
(4.78)
.188
(5.77)
.227
(6.78)
.267
01
–02
(0.31) .012 SQ TYP
–03
(1.65)
.065
–04
A
–05
(0.50) .0197 x
(No. of positions +1)
+ (0.25) .010
OPTIONS
= Shrouded
(15 positions
minimum)
–F
= Gold flash on post,
Matte Tin on tail
–A
–L
BOARD
SPACE
= Alignment
Pin
(Metal or
plastic at
Samtec
discretion)
(13 positions
minimum)
= 10 µ" (0.25 µm) Gold on post,
Matte Tin on tail
(Mated with BKS)
(4.14) .163
(4.50) .177
(5.00) .197
–P
(6.35)
.250
= Pick &
Place Pad
(13 positions
minimum)
(6.00) .236
(7.00) .276
(0.50) .0197 x
+ (2.44) .096
–TR
–S OPTION
(0.20)
.008
(0.89)
.035 DIA
V
–S
(4.17 x 5.71)
.164 x .225
(1.19)
.047
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
BODY
STYLE
(0.50) .020 TYP
PLATING
OPTION
Specify
BODY
STYLE
from
chart
(Odd lead counts only)
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
BODY
STYLE
= Tape & Reel
Packaging
(3.61)
.142
B
–P OPTION
–A OPTION
FILE NO. E111594
APPLICATIONS
BKT
BKS
BKT
LEAD STYLE
–01
–02
–03
–04
–05
MATED
HEIGHT
MATED
HEIGHT*
(4.14) .163
(4.50) .177
(5.00) .197
(6.00) .236
(7.00) .276
*Processing conditions will
affect mated height.
1
BKS
NO. OF
POSITIONS
01
Mates with:
BKT
PLATING
OPTION
V
–A
–F
07 thru 69
(07 positions available with –TR only)
= Alignment Pin
(Metal or plastic at Samtec discretion)
(11 positions minimum)
= Pre-plated
Gold flash on contact,
Matte Tin on tail
–P
–L
02
(4.11)
.162
(2.54) (5.59)
.100 .220
OPTIONS
= Pick & Place Pad
(13 positions minimum)
Not always necessary for auto placement.
= Pre-plated
10 µ"(0.25 µm) Gold contact,
Matte Tin on tail
–TR
= Tape & Reel Packaging
01
(0.36) .014
(1.00) .03937
(0.50) .020 TYP
(0.50) .0197 x
No. of positions
+ (0.81) .032
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
(2.12)
.084
(5.26 x 6.07)
.207 x .239
(1.07)
.042
(2.21)
.087
(0.89)
.035
DIA
(0.20)
.008
–P OPTION
–A OPTION
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“BKS-139-01-L-V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 28+83.2567128+10.80249
