F-215
CLT–115–02–F–D–A–K–BE
CLT–125–02–L–D
CLT–105–02–F–D
(2,00 mm) .0787"
CLT SERIES
LOW PROFILE DUAL WIPE SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLT
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating: Sn or Au over
50µ" (1,27 µm) Ni
Current Rating (TMMH/CLT):
4.1 A per pin
(1 pin powered per row)
Operating Temp Range:
-55°C to +125°C
Contact Resistance:
10 mΩ
Insertion Depth:
Top Entry=
(1,40 mm) .055" minimum
Bottom Entry=
(2,57 mm) .101" minimum
(add board thickness for
correct post OAL)
Insertion Force:
(Single contact only)
1.8 oz (0,50 N) avg.
Withdrawal Force:
.6 oz (0,17 N) avg.
Max Cycles:
100 with 10µ" (0,25 µm) Au
RoHS Compliant:
Yes
Mates with:
TMM, TMMH, MTMM,
MMT, TW, TSH
Available with optional
Pick & Place Pads
Tiger ClawTM
contacts
APPLICATION
(MOQ Required)
• Other platings
Contact Samtec.
Pass-Thru
CLT
1
LEAD
STYLE
NO. PINS
PER ROW
PLATING
OPTION
–01
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (02-25)
(0,15 mm) .006" max (26-34)
(0,20 mm) .008" max (35-50)
02 thru 50
= 10µ" (0,25 µm)
Gold on contact,
Matte Tin on tail
–03
A
(2,16) .085
–BE
= Bottom Entry
(Required for bottom
entry applications)
–L
= Surface
Mount
–01
–03
All options require
Style –02
= Gold flash
on contact,
Matte Tin on tail
–02
LEAD
STYLE
= Throughhole
–A
= Alignment Pin
(3 positions minimum)
Metal or plastic at
Samtec’s discretion
–G
= 10µ" (0,25 µm)
Gold on contact,
Gold flash on tail
(2,95) .116
–K
(5,08)
.200
x
(5,71)
.225
No. of positions x
(2,00) .0787
ILITY
L AVAILAB
02
E
arges.
No tooling chthe lesser of
der is
Minimum orantity or 125 pieces.
a full reel quantity above minimum.
Order any qudesign, manufacture.
In-house turn-around.
Quick
OTHER
OPTIONS
D
–F
= Throughhole
RECOGNITIONS
TAPE & RE
ALSO AVAILABLE
(2,00 mm)
.0787" pitch
Processing:
For complete scope of
recognitions see
www.samtec.com/quality
Low profile
(2,21 mm)
.087"
Suitable for
pass-through
applications
(4,00)
.157
(2,00)
.0787
–P
= Pick & Place Pad
(4 positions minimum)
(Not always necessary
for auto placement.)
–P
(0,51)
.020
ions
for specificat
Call Samtecring information.
and orde
01
(2,13)
.084
(3,02)
.119
–01 or –03
(0,51)
.020
–TR
(0,81)
.032
(2,27)
.090
A
= (5,00 mm) .197" DIA
Polyimide Film
Pick & Place Pad
(04 thru 50 only)
(0,64)
.025
DIA
(5,16)
.203
–02
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–A
= Tape & Reel
Packaging
(36 positions max)
很抱歉,暂时无法提供与“CLT-126-02-L-D-BE”相匹配的价格&库存,您可以联系我们找货
