EJH-105-01-F-D-SM-01-P-TR
    SAMTEC(申泰)
    .100 X .100 EJECTOR HEADER ASSEM
EJH-105-01-F-D-SM-01-P-TR 数据手册
SHROUDED IDC EJECTOR HEADERS (2.54 mm) .100" PITCH • EJH SERIES EJH Mates: IDSD (EJH-01 Required), HCSD (EJH-02 Required) EJH -1 NO. PINS PER ROW 05, 07, 08, 10, 13, 15, 17, 20, 25 SPECIFICATIONS Insulator Material: -01=Black LCP -02=Natural LCP Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C (Standard sizes) - LEAD STYLE - –01 PLATING OPTION -D- TAIL OPTION –F = Standard (Mates to IDSD) = Gold flash on post, Matte Tin on tail –02 = Extended (Mates to HCSD) –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –SM = Surface Mount –TH = Through-hole –RA =Right-angle - OTHER OPTION –“XX” = Polarized Position –LC = Locking Clip (–SM only) (Manual placement required) –K = .475" (12.00 mm) DIA Polyimide Film Pick & Place Pad (–SM only) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max –P = Pick & Place Pad (–SM only) ² 1RRISRVLWLRQV[     ² 1RRISRVLWLRQV[     ALSO AVAILABLE MOQ Required –TR = Tape & Reel (–SM only) (25 position not available)    1RRISRVLWLRQV[     Other sizes Other platings –FR   = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–SM only) (25 position not available) —RA OPTION $     –LC OPTION LEAD STYLE A –01 (16.88) .665 –02 (17.39) .685   —SM OPTION —TH OPTION (Latch removed for clarity) Note: Some lengths, styles and options are non-standard, non-returnable. F-224 samtec.com?EJH Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
- 物料型号:EJH系列,有多种尺寸和引脚数量可供选择。 - 器件简介:这些是2.54毫米间距的带护罩的IDC排针头,适用于多种应用。 - 引脚分配:提供了两种引脚分配选项,-01和-02,分别对应不同的尾长和引脚长度。 - 参数特性:绝缘体材料有黑色LCP和天然LCP两种选择,端子材料为磷青铜,镀层有锡或金,操作温度范围为-55°C至+125°C。 - 功能详解:支持无铅焊接,SMT引脚共面性最大为0.10毫米。 - 应用信息:提供了不同选项,如表面贴装(-SM)、直插(-TH)、直角(-RA)等,以及锁扣(-LC)和拾取放置垫(-P)等特殊选项。 - 封装信息:提供了不同引脚样式的长度信息,以及一些特殊长度、样式和选项是非标准、不可退货的。
EJH-105-01-F-D-SM-01-P-TR 价格&库存
很抱歉,暂时无法提供与“EJH-105-01-F-D-SM-01-P-TR”相匹配的价格&库存,您可以联系我们找货
