F-215
SS–132–G–2
ESD–115–TT–05
(2,54 mm) .100"
SS, SD, ESD, ESS, HSS SERIES
PRECISION MACHINED SOCKET STRIPS
Mates with:
TS, TD, HTS, BBS,
BBD, BBL, BDL, BHS
TYPE
STRIP
NO. PINS
PER ROW
1
PLATING
OPTION
LEAD
STYLE
OTHER
OPTION
OPTION
SPECIFICATIONS
–N
For complete specifications
see www.samtec.com?SS,
www.samtec.com?ESS,
www.samtec.com?SD,
www.samtec.com?ESD or
www.samtec.com?HSS
Insulator Material:
SS, SD, ESS, ESD=
Black G.F. Polyester
HSS=
Black Liquid Crystal Polymer
Contact:
BeCu
Shell:
Brass except Style 5A
Phosphor Bronze
Plating:
Au over 50µ" (1,27 µm) Ni or
Sn over 50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C
Contact Resistance:
10 mΩ
Lead Size Range:
(0,38 mm to 0,56 mm)
.015" to .022" DIA
and most IC leads
Insertion Force:
(Single contact only)
Standard=
9 oz (2,50 N) avg.,
16 oz (4,45 N) max
Low Insertion Force=
2.5 oz (0,70 N) avg.,
5.5 oz (1,53 N) max
Withdrawal Force:
Standard=
1.5 oz (0,42 N) min
2.0 oz (0,56 N) avg.,
0.35 oz (0,10 N) min
Insertion Depth:
(-05, -1X & -21X, -5A)
(3,18 mm) .125" to
(3,99 mm) .157"
Insertion Depth:
(-2, -22, -38)
(2,41 mm) .095" to
(3,68 mm) .145"
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
RECOGNITIONS
–S
01 thru 32
= SS, ESS Series
01 thru 36
Add –L suffix for locking
lead socket in end positions.
Requires Style -2 or -22 and
.035" ± .003 DIA board hole.
= 30µ" (0,76 µm) Gold contact,
Tin shell
SS
= Non
Flush
Locking
Socket
–T
= HSS, SD & ESD Series
(0,76)
.030
REF
(7,62)
.300
(3,43)
.135
–G
HSS
= Standard
= High Temp
Single Row Socket Single Row Socket
10µ" (0,25 µm) Gold shell
ALSO AVAILABLE
(MOQ Required)
= Tin contact and shell
(Styles 1, 2, 4, and 05
except LIF N/A)
= Elevated Single Row Socket
N/A Style –5A
Requires -T Plating Option
–TT
ESS
• Locking lead option on ESS
and ESD series
Contact Samtec.
Styles – 5A & –05 socket
heads not countersunk.
(2,54) .100 x No. of Positions
(2,54)
.100
(2,54)
.100 TYP
–1A, –1B or –1C
–03, –04, –05
For LIF specify –21A, –21B or –21C
(SS, HSS, SD)
For LIF specify –23
(ESS, ESD)
(1,83)
.072 DIA
(2,54)
.100
(4,90)
.193
(1,32)
.052
DIA
ESD
= Standard Double
Row Socket
= Elevated Double
Row Socket
(0,64)
.025 SQ
Style – 5A not available.
Styles –5A & –05 socket
LEAD STYLE
Y
–1A or –21A
(9,14)
.360
–1B or –21B
(12,95)
.510
–1C or –21C
(6,60)
.260
(0,76)
.030
B
A
C
(0,64)
.025
SQ
–2, –22*,–5A,
or –38*
*For LIF specify –22 or –38 (SS, HSS, SD)
(2,54)
.100
(5,08)
.200
(0,76)
.030
Y
SD
For complete scope
of recognitions see
www.samtec.com/quality
(1,83)
.072
DIA
(2,54)
.100 TYP
(2,54)
.100
(0,76)
.030
(1,32)
.052
DIA
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–L
= 10µ" (0,25 µm) Gold contact,
Tin shell
(Styles 2 & 22 only)
X
LIF= Low Insertion Force
X
LEAD STYLE DIA
Z
Y
Y
Z
LEAD
STYLE
–2 or –22
(0,51) (3,18) (7,62)
.020 .125 .300
05
–38
(0,51) (4,57) (8,89)
.020 .180 .350
03 or 23
–5A
(0,89) (12,95) (17,86)
.035 .510 .703
04
Locking lead available. See OPTION.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
A
B
C
(17,86) (13,46) (4,39)
.703
.530 .173
(11,51) (8,38) (3,12)
.453
.330 .123
(14,05) (10,92) (3,12)
.553
.430 .123
