FCF8-10-01-L-20.00-S 数据手册
F-217
FCF8–20–01–L–03.00–S
FCF8–10–01–L–03.00–S
FCS8–10–01–L–S–A–TR
FCS8–20–01–L–S–A–TR
(0.80 mm) .0315"
FCF8, FCS8 SERIES
HIGH-SPEED COST EFFECTIVE COAX CABLE
SPECIFICATIONS
For complete specifications see
www.samtec.com?FCF8
Cable: 38 AWG coax
Overmold: Nylon
Terminal Material:
Phosphor Bronze
Contact Plating:
Au or Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-25 °C to +105 °C
Current Rating:
1.8 A per pin
(1 pin powered per row)
RoHS Compliant: Yes
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
FILE NO. E111594
Notes:
Design your High-Speed Cable
with Samtec’s High-Speed
Cable Solutionator®
at www.samtec.com/hdr
NO. OF
POSITIONS
FCF8
Mates with:
FCS8
CABLE
LENGTH
PLATING
OPTION
01
–L
–10, –20, –30
–“XX.XX”
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Length in Inches
03.00" (76.2 mm) minimum
CABLE LENGTH + (16.43) .647
NO. OF
POSITIONS
GND
GND
A
Insulator Material: Black LCP
Contact Material: BeCu
Contact Plating:
Shield:
Nickel Plated Phosphor Bronze
-55 °C to +125 °C
Current Rating:
1.8 A per pin
RoHS Compliant: Yes
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max
–10
–20
(19.85) (27.00)
.781
1.063
–30
(27.85) (35.00)
1.096 1.378
GND
ALSO
AVAILABLE
(MOV Required)
(12.55) .494
• Other sizes and lengths
Contact Samtec.
(2.42)
.095
NO. OF
POSITIONS
FCS8
Mates with:
FCF8
(0.80)
.0315
PLATING
OPTION
01
–L
–10, –20, –30
A
(7.46)
.294
(0.30)
.012
S
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
A
TR
–TR
= Tape & Reel
NO. OF
A
B
C
D
POSITIONS
(16.59) .653 (15.56) .613 (10.70) .421 (13.06) .514
–10
(24.59) .968 (23.56) .928 (18.70) .736 (21.06) .829
–20
(32.59) 1.283 (31.56) 1.243 (26.70) 1.051 (29.06) 1.144
–30
(7.48)
.294
B
• Weld tabs
• Positive latching
RECOGNITIONS
For complete scope
of recognitions see
B
N
01
GND
Some lengths, styles and
options are non-standard,
non-returnable.
SPECIFICATIONS
B
A
(11.85) (19.00)
.467
.748
01
N
Cable lengths longer than
40.00" (1 meter) are not
supported with S.I. test data.
For complete specifications and
recommended PCB layouts see
www.samtec.com?FCS8
S
• Shielded for EMI
protection
C
D
(0.49)
.019
(1.85)
.073
(0.20)
.008
(1.32)
.052
DIA
FILE NO. E111594
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
FCF8-10-01-L-20.00-S 价格&库存
很抱歉,暂时无法提供与“FCF8-10-01-L-20.00-S”相匹配的价格&库存,您可以联系我们找货
