FFMD-08-D-12.00-01
FFMD-08-D-12.00-01
    SAMTEC(申泰)
    .050 CABLE PLUG
FFMD-08-D-12.00-01 数据手册
TIGER ™ IDC EYE TIGER EYE™ FLAT IDC WIRE CABLES (1.27 mm) .050" PITCH • FFMD SERIES FFMD Mates: FLE*, SFMC* TRANSFER END Mates: FTS, FTSH, EHF, SHF, ESHF SERIES - NO. PINS PER ROW FFMD - –04, –05, –08, –10, –13, –17, –20, –25 = Terminal Strip –S = Single End –D - OVERALL LENGTH - 01 - –“XX.XX” –N = Notch Polarization on socket (-T end only) (Not available with -04 position) –T = Transfer End Insulator Material: PBT Terminal: Phosphor Bronze Contact: BeCu (-T) Plating: Sn over 50 µ" (1.27 µm) Ni Wire: 30 AWG Current Rating: 2.5 A per pin (2 pins powered) Operating Temp Range: -40 °C to +105 °C Voltage Rating: 215 VAC / 304 VDC - TRANSFER OPTION Leave blank for –S and –D End Options. = Assembled Length = Double End (Standard sizes) SPECIFICATIONS END OPTION OTHER OPTION –RW = Reverse Wiring (Red wire opposite position #1) –D “XX” = Daisy Chain –SR = Strain Relief (Mates only with ESHF Series) (Not available with –O, –M, –R or –DXX) –R 01 = Reversed (3.05) .120 –M = Middle Reversed (Requires –DXX) No. of positions x (1.27) .050 + (4.19) .165 –O = Outside Reversed (Requires –DXX) (5.08) .200 Assembled Length in INCHES (± .130") 2 inches minimum ALSO AVAILABLE MOQ Required Other sizes Assemble Length (–“XX.XX”) Single End (—S) Double End (—D) (50.8 mm) 2.00 min. Transfer End (—T) “XX” ± 1/8" No. of positions x (1.27) .050 + (8.00) .315 01 02 *Note: Standard FFMD callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates with Pin 1, etc. Note: This Series is non-standard, non-returnable. (101.60 mm) 4.00 min. Reverse Wiring (—RW) Reversed (—R) Daisy Chain (—D “XX”) Middle Reversed (—M) Strain Relief (—SR) Outside Reversed (—O) samtec.com?FFMD Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
FFMD-08-D-12.00-01
1. 物料型号:文档中提到的型号是FFMD系列,具有1.27毫米间距和0.050英寸间距。
2. 器件简介:TIGER EYE™ FLAT IDC WIRE CABLES是一种扁平的IDC(绝缘位移连接)电缆,适用于多种连接需求。
3. 引脚分配:文档中提到了不同配置的引脚分配,例如单端(-S)、双端(-D)和传输端(-T)。
4. 参数特性: - 绝缘体材料:PBT - 端子材料:磷青铜 - 接触材料:BeCu (-T) - 镀层:锡,超过50微英寸(1.27微米)镍 - 线材规格:30 AWG - 电流额定值:每针2.5A(2针供电) - 工作温度范围:-40°C至+105°C - 电压额定值:215 VAC / 304 VDC
5. 功能详解:文档中提到了不同的配置选项,如反向布线(-RW)、中间反向(-M)、外部反向(-O)等。
6. 应用信息:文档中没有明确提供应用信息,但根据参数特性,这些电缆适用于需要高电流和高电压的应用。
7. 封装信息:文档提供了不同长度和配置的电缆选项,以及如何定制特定长度的电缆。
FFMD-08-D-12.00-01 价格&库存
很抱歉,暂时无法提供与“FFMD-08-D-12.00-01”相匹配的价格&库存,您可以联系我们找货
