FFMD-13-T-04.00-01-N
    SAMTEC(申泰)
    .050 CABLE PLUG
FFMD-13-T-04.00-01-N 数据手册
F-219 (Rev 15NOV19) FFMD–20–T–02.00–01–N–R TIGER ™ IDC EYE (1.27 mm) .050" FFMD–10–S–10.00–01 FFMD SERIES TIGER EYE FLAT IDC WIRE CABLES ™ Mates with: FLE*, SFMC*, Transfer End Option Mates with: FTS, FTSH, EHF, SHF, ESHF TYPE STRIP END OPTION NO. PINS PER ROW OVERALL LENGTH 01 –“XX.XX” SPECIFICATIONS Leave blank for –S and –D End Options. = Assembled Length For complete specifications see www.samtec.com?FFMD Insulator Material: PBT Terminal: Phosphor Bronze Contact: BeCu (-T) Plating: Sn over 50 µ" (1.27 µm) Ni Wire: 30 AWG Current Rating: 2.5 A per pin (2 pins powered) Operating Temp Range: -40 °C to +105 °C Voltage Rating: 215 VAC 304 VDC RoHS Compliant: Yes –N Assembled Length in INCHES (± .130") 2 inches minimum –04, –05, –08, –10, –13, –17, –20, –25 = Notch Polarization on socket (-T end only) (Not available with -04 position) (Standard sizes) –S = Single End For complete scope of recognitions see www.samtec.com/quality –T = Transfer End –D = Double End Reverse Daisy –RW = Wiring –D “XX” = Chain RECOGNITIONS (50.8 mm) 2.00 min. –R = Reverse Outside –O = Reverse ± 1/8" 3 01 ALSO AVAILABLE (MOQ Required) • Other sizes 3 (101.60 mm) 4.00 min. Red wire opposite position #1. 1 2 Requires –DXX Not available with –O, –M, –R or –DXX 3 • Strain relief option FFMD = Terminal Strip 01 (3.05) .120 No. of positions x (1.27) .050 + (4.19) .165 *Note: Standard FFMD callout will not mate with FLE, SFMC. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates with Pin 1, etc. Note: This Series is non-standard, non-returnable. No. of positions x (1.27) .050 + (8.00) .315 Requires –DXX Middle –M = Reverse 02 Strain –SR = Relief (Mates only with ESHF Series) “XX” FILE NO. E111594 OTHER OPTION TRANSFER OPTION (5.08) .200 (3.07) .121 (0.41) .016 SQ (1.27) .050 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
FFMD-13-T-04.00-01-N 价格&库存
很抱歉,暂时无法提供与“FFMD-13-T-04.00-01-N”相匹配的价格&库存,您可以联系我们找货
  • 1+107.055291+13.89034
