FFSD-05-D-11.80-01-N-SR
    SAMTEC(申泰)
    .050 X .050 C.L. FEMALE IDC ASSE
FFSD-05-D-11.80-01-N-SR 数据手册
F-214 FFSD–20–S–10.00–01–N ™ FFSD–10–D–02.00–01–N ••••••••••••••••••• (1,27 mm) .050" FFSD SERIES ™ TIGER EYE FLAT IDC WIRE CABLES Mates with: FTS, FTSH, EHF, SHF, ESHF TYPE STRIP NO. PINS PER ROW OVERALL LENGTH END OPTION 01 OTHER OPTION N SPECIFICATIONS For complete specifications see www.samtec.com?FFSD Insulator Material: PBT Contact: BeCu Plating: 10µ" (0,25 µm) Au over 50µ" (1,27 µm) Ni on contact area; Sn over 50µ" (1,27 µm) Ni on balance Wire: 30 AWG Current Rating (FFSD/FTSH): 2.3 A per pin (1 pin powered per row) Operating Temp Range: -40°C to +105°C Lead Size Accepted: (0,41 mm) .016" SQ Contact Resistance: 15 mΩ Insertion Depth: (2,64 mm) .104" to (3,17 mm) .125" Insertion Force: (Single contact only) 5 oz (1,39 N) avg. Withdrawal Force: (Single contact only) 3 oz (0,83 N) avg. RoHS Compliant: Yes –04, –05, –06, –08, –10, –11, –12, –13, –15, –17, –20, –25 –S –N = Single End = Notch Polarization –“XX.XX” = Assembled Length –D Assembled Length in INCHES (1/8") 2 inches minimum = Double End (Standard sizes) FFSD = Socket Strip (1,90) .075 01 (3,05) .120 (1,02) .040 RECOGNITIONS No. of positions x (1,27) .050 + (4,19) .165 For complete scope of recognitions see www.samtec.com/quality (5,08) .200 (1,27) .050 Reverse –RW = Wiring Daisy –D “XX” = Chain Strain –SR = Relief Outside –O = Reverse –R = Reverse (Mates only with ESHF Series) ALSO AVAILABLE 2" min. (MOQ Required) • Other sizes Contact Samtec. “XX” ± 1/8" Requires –DXX 3 No. of positions x (1,27) .050 + (8,00) .315 3 –M 01 = Middle Reverse 4" minimum 02 Note: This Series is non-standard, non-returnable. Red wire opposite position #1. 1 2 Requires –DXX WWW.SAMTEC.COM 3 • Strain relief option Not available with –O, –M, –R or –DXX
FFSD-05-D-11.80-01-N-SR 价格&库存
很抱歉,暂时无法提供与“FFSD-05-D-11.80-01-N-SR”相匹配的价格&库存,您可以联系我们找货
