FFSD-07-S-05.00-01-N-RW
    SAMTEC(申泰)
    .050 X .050 C.L. FEMALE IDC ASSE
FFSD-07-S-05.00-01-N-RW 数据手册
TIGER ™ IDC EYE TIGER EYE™ FLAT IDC WIRE CABLES (1.27 mm) .050" PITCH • FFSD SERIES FFSD SERIES Mates: FTS, FTSH, EHF, SHF, ESHF SPECIFICATIONS Insulator Material: PBT Contact: BeCu Plating: 10 µ" (0.25 µm) Au over 50 µ" (1.27 µm) Ni on contact area; Sn over 50 µ" (1.27 µm) Ni on balance Wire: 30 AWG Current Rating (FFSD/FTSH): 2.3 A per pin (2 pins powered) Operating Temp Range: -40 °C to +105 °C Lead Size Accepted: (0.41 mm) .016" SQ Insertion Depth: (2.64 mm) .104" to (3.17 mm) .125" FFSD = Socket Strip - - NO. PINS PER ROW –04, –05,–06, –08, –10, –11, –12, –13, –15, –17, –20, –25 (Standard sizes) END OPTION –S = Single End - OVERALL LENGTH - 01 - –“XX.XX” = Assembled Length –D = Double End - N –N = Notch Polarization (Notch option not available with -04 position) OTHER OPTION –RW = Reverse Wiring (Red wire opposite position #1) –D “XX” = Daisy Chain –SR = Strain Relief (Mates only with ESHF Series) (Not available with –O, –M, –R or –DXX) –R 01 = Reversed (3.05) .120 –M = Middle Reversed (Requires –DXX) No. of positions x (1.27) .050 + (4.19) .165 –O = Outside Reversed (Requires –DXX) (5.08) .200 ALSO AVAILABLE MOQ Required Other Sizes Assembled Length in INCHES (1/8") 1 inch minimum 01 02 Single End (—S) Double End (—D) Assembled Length (—“XX.XX”) Reverse Wiring (—RW) No. of positions x (1.27) .050 + (8.00) .315 (50.8 mm) 2.00 min. “XX” ± 1/8" (101.60 mm) 4.00 min. Daisy Chain (—D “XX”) Strain Relief (—SR) Reversed (—R) Middle Reversed (—M) Outside Reversed (—O) Note: This Series is non-standard, non-returnable. F-224 samtec.com?FFSD Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
物料型号:FFSD
器件简介:TIGER EYE™ FLAT IDC WIRE CABLES,具有1.27mm(0.050")间距的FFSD系列,与FTS, FTSH, EHF, SHF, ESHF系列兼容。
引脚分配:文档中未明确提供引脚分配的详细信息。
参数特性: - 绝缘体材料:PBT - 接触材料:BeCu - 镀层:接触区域为10 µ" (0.25 µm) Au over 50 µ" (1.27 µm) Ni;其余部分为Sn over 50 µ" (1.27 µm) Ni - 线材规格:30 AWG - 电流额定值:每针2.3A(当2针供电时) - 操作温度范围:-40°C至+105°C - 接受的引线尺寸:(0.41 mm) .016" SQ - 插入深度:(2.64 mm) .104" 至末端
功能详解:文档中未提供详细的功能解释。
应用信息:文档中未提供具体的应用信息
封装信息:提供了不同配置的选项,包括单端(-S)、双端(-D)、反向布线(-RW)、菊花链(-D "XX")、应变缓解(-SR,仅与ESHF系列兼容)等。
FFSD-07-S-05.00-01-N-RW 价格&库存
很抱歉,暂时无法提供与“FFSD-07-S-05.00-01-N-RW”相匹配的价格&库存,您可以联系我们找货
