FJ-30-R-30.00-4
FJ-30-R-30.00-4
    SAMTEC(申泰)
    1MM FLEX CABLE JUMPER
FJ-30-R-30.00-4 数据手册
FLAT FLEXIBLE CABLE (FCC) JUMPER & SOCKET (1.00 mm) .0394" PITCH • FJ/ZF1/FC1 SERIES FJ Mates: FC1, ZF1 - FJ ZF1/FC1 NO. OF POSITIONS –05, –10, –15, –20, –25, –30 Mates: FJ SPECIFICATIONS FJ Conductor: Tin Plated Copper Conductor Resistance: 300 Ω/km max Operating Temp Range: -30 °C to +80 °C Voltage Rating: 300 VAC Length in inches –R = (76.2 mm) 3.00" = Reversed End –06.00 –12.00 = (304.8 mm) 12.00" –24.00 = (609.6 mm) 24.00" (Standard Lengths) - NO. OF POSITIONS - –05, –10, –15, –16, –20, –25, –30 (No. of pins x (1.00) .03937) + (5.85) .230 –R STYLE - LEAD STYLE PLATING OPTION –01 - –T = Contact Bottom WT OPTION –TR = Weld Tab = Tape & Reel –FR –02 = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (5.30) .209 PROCESSING - FC1 NO. OF POSITIONS (3.00) .118 - –05, –10, –15, –20, –25 LEAD STYLE –01 = Vertical - PLATING OPTION –T = Tin –02 = Horizontal (2.77) .109 (No. of pins x (1.00) .03937)+ (2.33) .092 Some sizes, styles and options are non-standard, non-returnable. - –WT = Matte Tin = Contact Top (10 positions only) (No. of pins x (1.00) .03937) + (7.00) .276 Notes: FJ Stiffener color will be blue or black at Samtec’s discretion. –4 = (4.00 mm) .157" (Required for mating with FC1 & ZF1) = (152.4 mm) 6.00" –D STYLE ZF1 STRIP LENGTH –03.00 (4.00) .157 Insulator Material: Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C Max Cycles: 25 with FJ Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max - LENGTH –D (No. of positions x (1.00) .03937) + (1.00) .03937 FC1 ZF1/FC1 - STYLE = Double End LENGTH ZF1 Insulator Material: Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn over 40 µ" (1.02 µm) Ni Weld Tab: Phosphor Bronze Operating Temp Range: -55 °C to +105 °C - (5.18) .204 (6.35) .250 (4.09) .161 —01 - OPTION –LC = (4.00 mm) .158" DIA Polyimide film Pick & Place Pad (–01 only) –WT = Tape & Reel = Weld Tab (–02 only) —LC —02 samtec.com?FJ, samtec.com?ZF1 or samtec.com?FC1 –K = Locking Clip (Manual placement required) (–01 only) –TR –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) F-224 WEB Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FJ-30-R-30.00-4
物料型号: - FJ系列与FC1和ZF1系列兼容。
器件简介: - 该文档描述了一种扁平柔性电缆跳线和插座,具有1.00毫米的间距。
引脚分配: - 提供了不同长度和样式的FJ跳线,包括双端(-D)和反向端(-R)。
参数特性: - 导体材料为镀锡铜,电阻最大为300Ω/km,工作温度范围为-30°C至+80°C,电压等级为300VAC。 - ZF1和FC1的绝缘材料为液晶聚合物,接触材料为磷青铜,镀锡层厚度超过40µ"(1.02µm)和50µ"(1.27µm),工作温度范围为-55°C至+105°C。
功能详解: - 描述了ZF1和FC1的焊接选项、引脚样式和加工信息。
应用信息: - 该产品适用于需要柔性电缆连接的应用。
封装信息: - 提供了详细的引脚数量、长度和样式选项,以及不同的镀层和焊接选项。
FJ-30-R-30.00-4 价格&库存
很抱歉,暂时无法提供与“FJ-30-R-30.00-4”相匹配的价格&库存,您可以联系我们找货
FJ-30-R-30.00-4
  • 1+239.748391+29.83417
