FJH-15-R-14.00-4
FJH-15-R-14.00-4
    SAMTEC(申泰)
    .5MM FLEX CABLE JUMPER
FJH-15-R-14.00-4 数据手册
FLAT FLEXIBLE CABLE (FFC) JUMPER & SOCKET (0.50 mm) .0197" PITCH • FJH/ZF5S SERIES FJH FJH Mates: ZF5S NO. OF POSITIONS - –10, –15, –20, –25, –30, –40, –43, –50 SPECIFICATIONS Conductor: Tin Plated Copper Conductor Resistance: 1000 Ω/km max Current Rating: 1.8 A per pin (1 pin powered) Operating Temp Range: -55 °C to +80 °C Voltage Rating: 195 VAC - –D Length in inches –R = (76.2 mm) 3.00" –06.00 –12.00 = (304.8 mm) 12.00" LENGTH ± (3.18) .125 –24.00 = (609.6 mm) 24.00" A ± (1.52) 0.06 (Standard Lengths) (4.00) .157 —D STYLE OTHER SOLUTIONS For 1.00 mm pitch flat flexible cable series, visit: www.samtec.com?FJ www.samtec.com?ZF1 www.samtec.com?FC1 —R STYLE ZF5S - SPECIFICATIONS NO. OF POSITIONS - –10, –15, –20, –25, –30, –40, –43, –50 Insulator Material: Natural LCP Contact Material: Phosphor Bronze Plating: Sn over 50 µ" (1.27 µm) Ni Weld Tab: Phosphor Bronze Operating Temp Range: -55 °C to +105 °C Current Rating: 1.8 A per pin (1 pin powered) (Standard sizes) - LEAD STYLE –01 = Contact Bottom NO. OF POSTIONS A –10 (5.50) .217 –15 (8.00) .315 –20 (10.50) .413 –25 (13.00) .512 –30 (15.50) .610 –40 (20.50) .807 –43 (22.00) .866 –50 (25.50) 1.00 PLATING OPTION –T = Matte Tin - Notes: Stiffener color will be blue or black at Samtec’s discretion. Some sizes, styles and options are non-standard, non-returnable. - WT –WT = Weld Tab OPTION –K = (3.00 mm) .118" DIA Polyimide Film Pick & Place Pad –TR = Tape & Reel (No. of positions -1) x (0.50) .0197 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (4.82) .190 PROCESSING No. of positions x (0.50) .0197 + (5.65) .222 (2.00) .079 (2.10) .083 Note: Some sizes, styles and options are non-standard, non-returnable. F-224 (Rev 20OCT23) –4 = (4.00 mm) .157" –03.00 = Reversed End Other Platings Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (10-30) (0.15 mm) .006" max (40-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) STRIP LENGTH = (152.4 mm) 6.00" MOQ Required Mates: FJH - LENGTH = Double End (Standard sizes) ALSO AVAILABLE ZF5S - STYLE ALSO AVAILABLE MOQ Required Vertical Contact top Other positions samtec.com?FJH or samtec.com?ZF5S Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FJH-15-R-14.00-4
1. 物料型号:FJH/ZF5S 系列,包括标准尺寸和长度,如 -10, -15, -20, -25, -30, -40, -43, -50。 2. 器件简介:文档描述了FFC跳线和插座,它们具有0.50毫米间距和0.0197英寸间距。 3. 引脚分配:提供了不同引脚数量的FJH和ZF5S的尺寸,如 -10 至 -50。 4. 参数特性: - 导体:镀锡铜导体,电阻率最大为1000 Ω/km。 - 电流额定值:每针1.8A(单针供电)。 - 工作温度范围:-55°C 至 +80°C。 - 电压额定值:195 VAC。 5. 功能详解:文档提供了FJH和ZF5S的详细规格,包括绝缘材料、接触材料、镀层、焊接标签等。 6. 应用信息:文档提到了不同引脚数量的FJH和ZF5S的应用,以及它们的操作温度范围和电流额定值。 7. 封装信息:提供了不同引脚数量的FJH和ZF5S的封装尺寸和选项,如带焊料垫的聚酰亚胺膜、拾取和放置垫等。
FJH-15-R-14.00-4 价格&库存
很抱歉,暂时无法提供与“FJH-15-R-14.00-4”相匹配的价格&库存,您可以联系我们找货
