FMPS-04-01-L-S-RA-LC 数据手册
F-224 WEB
FMPT–06–01–L–S–V
FMPS–06–01–L–S–RA–SD
(5.00 mm) .1969"
FMPS, FMPT SERIES
“HINGING” 30 A POWER HEADER & SOCKET
SPECIFICATIONS
For complete specifications
see www.samtec.com?FMPS
or www.samtec.com?FMPT
Insulator Material:
Black LCP
Terminal Material:
Copper Alloy
Plating: Sn or Au over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
525 VAC/742 VDC
Standard Creepage:
FMPS: (3.67 mm) .144"
FMPT: (6.53 mm) .257"
Standard Clearance:
(2.71 mm) .106"
RoHS Compliant: Yes
Lead–Free Solderable: Yes
PLATING
OPTION
01
02, 04, 06, 08
RA
S
= Screw Down
(Not Available with –LC)
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
–LC
–T
NUMBER OF
POSITIONS
–02
(14.17)
.558
–04
–06
–08
(5.00)
.1969
TYP
(9.27)
.365
(1.87)
.074
A
(22.63)
.891
(32.63)
1.285
(42.63)
1.678
(52.63)
2.072
B
(16.28)
.641
(26.28)
1.035
(36.28)
1.428
(46.28)
1.822
C
(15.63)
.615
(25.63)
1.009
(35.63)
1.403
(45.63)
1.796
CREEPAGE
AND CLEARANCE
(2.72)
.107
(2.54)
.100
(0.41) .016
–SD OPTION
(6 POSITIONS SHOWN)
For complete scope
of recognitions see
www.samtec.com/quality
= Locking Clip
(Manual placement
required)
(Not Available with –SD)
= Matte Tin
A
B
ALSO AVAILABLE
C
–LC OPTION
(2 POSITIONS SHOWN)
(MOQ Required)
• Other sizes
NO. OF
POSITIONS
FMPT
01
02, 04, 06, 08
PLATING
OPTION
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
(1.00)
.039
DIA
NUMBER OF
POSITIONS
(2.54)
.100
(0.41) .016
–LC
–T
(5.00) .1969 TYP
–02
(6.30)
.248
(0.79)
.031
B
OPTION
= Locking
Clip
(Manual
placement
required)
= Matte Tin
(9.40)
.370
(1.87)
.074
V
Matte Tin on tail
A
Ideal for blind mating applications.
S
–L
(Standard sizes)
(4.24)
.167
Selectively loading
contacts achieves customer
specific creepage and
clearance requirements.
Contact asp@samtec.com
FILE NO. E111594
APPLICATION
OPTION
–SD
–L
(Standard sizes)
FMPT/FMPS
CURRENT RATING
PINS
(PER CONTACT)
1
26.7 A
2
22.9 A
3
19.1 A
4
17.6 A
8
15.8 A
–L PLATING
RECOGNITIONS
NO. OF
POSITIONS
FMPS
(2.72)
.107
(2.54)
.100
–04
(1.42)
.056
–06
(1.42)
.056
–LC
–08
A
B
(22.63) (16.53)
.891
.651
(32.63) (26.53)
1.285 1.044
(42.63) (36.53)
1.678 1.438
(52.63) (46.53)
2.072 1.832
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FMPS-04-01-L-S-RA-LC 价格&库存
很抱歉,暂时无法提供与“FMPS-04-01-L-S-RA-LC”相匹配的价格&库存,您可以联系我们找货
