FTM-119-03-F-DV-P
FTM-119-03-F-DV-P
    SAMTEC(申泰)
    1MM MICRO STRIPS
FTM-119-03-F-DV-P 数据手册
SMT MICRO TERMINAL STRIPS (1.00 mm) .0394" PITCH • FTMH/FTM SERIES FTMH Mates: CLM, MLE FTMH -1 FTM PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: -DV: (0.10 mm) .004" max -DH: (0.10 mm) .004" max (05-25) (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) –02 –03 –L No. of positions x (1.00) .03937 + B = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Dual Vertical (-DV only with 9 pins/row minimum) –DH = End Shroud –ES (1.57) .062 –EC (4.06) .160 –EP (5.49) .216 (1.80) .071 -1 - NO. PINS PER ROW 02 thru 50 MOQ Required –02 = Unshrouded 05 thru 46 = Shrouded (3.18) .125 (5.21) .205 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT PLATING OPTION –03 –L = (1.65 mm) .065" Post (Mates with CLM) –TR OPTION D –FR LEAD STYLE - DV - = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) A –02 (1.91) .075 –03 (1.65) .065 –SA FLEX SHROUD OPTION –S = End Shroud (05 positions minimum). Molded or press-fit shroud at Samtec’s discretion = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –S (0.97) .038 = Plastic Pick & Place Pad (6 positions min.) (–DV only) = Tape & Reel –F = Gold flash on post, Matte Tin on tail (4.44) .175 –P = End Shroud with Guide Post (Use only when mating with CLM) (2.59) .102 = (1.91 mm) .075" Post (Mates with MLE) No. of positions x (1.00) .03937 + C HIGH MATING CYCLES –K = (2.50 mm) .098" DIA Polyimide Film Pick & Place Pad (–DH only) –DH OPTION - LEAD STYLE –A –EC (5.00) .197 (5.21) .205 OTHER OPTION = Alignment Pin (3 positions min.) Metal or plastic at Samtec discretion (–DV only) –EP B –DV OPTION FTM - –ES = Dual Horizontal A Shrouded option removed for clarity FLEX SHROUD OPTION = End Shroud with Locking Clip (Manual placement required) OPTION (1.49) .059 End shrouds with board locks Molded end shrouds for 05 through 08 positions Other platings F-224 –DV A ALSO AVAILABLE Note: Some lengths, styles and options are non-standard, non-returnable. - ROW OPTION –F = Gold flash on post, Matte Tin on tail = (1.65 mm) .065" Post (Mates with CLM) (3.17) .125 - PLATING OPTION = (1.91 mm) .075" Post (Mates with MLE) No. of positions x (1.00) .03937 SPECIFICATIONS - LEAD STYLE 05 thru 50 Mates: CLM, MLE Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (FTMH/CLM): 3.1 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: FTMH: 270 VAC - NO. PINS PER ROW –SA = End Shroud with Alignment Pins (05 through 46 positions) C (4.00) .157 (7.00) .276 (1.27) .050 No of positions x (1.00) .03937 LEAD STYLE D –02 (1.91) .075 –03 (1.65) .065 - OTHER OPTION –P = Plastic Pick & Place Pad (7 positions min.) –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) Shrouded options removed for clarity samtec.com?FTMH or samtec.com?FTM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FTM-119-03-F-DV-P
1. 物料型号:FTMH/FTM系列,具有不同的引脚排列和选项。 2. 器件简介:端子条用于SMT应用,有多种引脚排列和端子样式。 3. 引脚分配:提供从5到50个引脚每排的选项,以及不同的引脚样式和端子选项。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 端子材料:磷青铜 - 镀层:锡或金,覆盖在50微米(1.27微米)镍上 - 电流额定值:每针3.1安培(2针供电) - 工作温度范围:-55°C至+125°C - 电压额定值:FTMH 270 VAC 5. 功能详解:包括端子的电气特性和机械特性,如引脚共面性、端子选项等。 6. 应用信息:适用于需要高电流和高电压应用的场合。 7. 封装信息:提供了不同选项的封装细节,如端子后端的镀金、端子尾部的镀锡等。
FTM-119-03-F-DV-P 价格&库存
很抱歉,暂时无法提供与“FTM-119-03-F-DV-P”相匹配的价格&库存,您可以联系我们找货
