SMT MICRO
TERMINAL STRIPS
(1.00 mm) .0394" PITCH • FTMH/FTM SERIES
FTMH
Mates:
CLM, MLE
FTMH
-1
FTM
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
-DV: (0.10 mm) .004" max
-DH: (0.10 mm) .004" max (05-25)
(0.15 mm) .006" max (26-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
–02
–03
–L
No. of positions x
(1.00) .03937 + B
= 10 µ"
(0.25 µm)
Gold
on post,
Matte Tin
on tail
= Dual
Vertical
(-DV only with
9 pins/row
minimum)
–DH
= End Shroud
–ES
(1.57) .062
–EC
(4.06) .160
–EP
(5.49) .216
(1.80)
.071
-1
NO. PINS
PER ROW
02 thru 50
MOQ Required
–02
= Unshrouded
05 thru 46
= Shrouded
(3.18)
.125
(5.21)
.205
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
PLATING
OPTION
–03
–L
= (1.65 mm)
.065" Post
(Mates
with CLM)
–TR
OPTION
D
–FR
LEAD
STYLE
DV
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
A
–02
(1.91) .075
–03
(1.65) .065
–SA
FLEX SHROUD
OPTION
–S
= End Shroud
(05 positions
minimum).
Molded or
press-fit shroud
at Samtec’s
discretion
= 10 µ"
(0.25 µm)
Gold
on post,
Matte Tin
on tail
–S
(0.97)
.038
= Plastic Pick
& Place Pad
(6 positions min.)
(–DV only)
= Tape & Reel
–F
= Gold flash
on post,
Matte Tin
on tail
(4.44)
.175
–P
= End Shroud
with Guide Post
(Use only when
mating with CLM)
(2.59)
.102
= (1.91 mm)
.075" Post
(Mates
with MLE)
No. of positions x
(1.00) .03937 + C
HIGH MATING
CYCLES
–K
= (2.50 mm)
.098" DIA
Polyimide Film
Pick & Place Pad
(–DH only)
–DH OPTION
LEAD
STYLE
–A
–EC
(5.00)
.197
(5.21)
.205
OTHER
OPTION
= Alignment Pin
(3 positions min.)
Metal or plastic at
Samtec discretion
(–DV only)
–EP
B
–DV OPTION
FTM
–ES
= Dual
Horizontal
A
Shrouded option removed for clarity
FLEX SHROUD
OPTION
= End Shroud
with Locking Clip
(Manual placement
required)
OPTION
(1.49)
.059
End shrouds with board locks
Molded end shrouds for
05 through 08 positions
Other platings
F-224
–DV
A
ALSO AVAILABLE
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
ROW
OPTION
–F
= Gold flash
on post,
Matte Tin
on tail
= (1.65 mm)
.065" Post
(Mates
with CLM)
(3.17)
.125
PLATING
OPTION
= (1.91 mm)
.075" Post
(Mates
with MLE)
No. of positions x
(1.00) .03937
SPECIFICATIONS
LEAD
STYLE
05
thru
50
Mates:
CLM, MLE
Insulator Material:
Black Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (FTMH/CLM):
3.1 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
FTMH: 270 VAC
NO. PINS
PER ROW
–SA
= End Shroud with
Alignment Pins
(05 through 46
positions)
C
(4.00)
.157
(7.00)
.276
(1.27)
.050
No of positions x
(1.00) .03937
LEAD
STYLE
D
–02
(1.91)
.075
–03
(1.65)
.065
OTHER
OPTION
–P
= Plastic Pick
& Place Pad
(7 positions min.)
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
Shrouded options removed for clarity
samtec.com?FTMH or samtec.com?FTM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“FTMH-113-03-F-DH”相匹配的价格&库存,您可以联系我们找货
