FTR-105-54-G-D-A
FTR-105-54-G-D-A
    SAMTEC(申泰)
    SMT .050'' STRIPS
FTR-105-54-G-D-A 数据手册
SMT MICRO HEADER & SOCKET (1.27 mm) .050" PITCH • FTR/RSM SERIES FTR Mates: RSM, SMS, SLM FTR -1 RSM NO. PINS PER ROW - LEAD STYLE 02 thru 40 Mates: FTR, HTMS, HDWM, DWM, TML, ZML, TMS - –L Specify LEAD STYLE from chart PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: RSM: (0.10 mm) .004" max FTR: (0.10 mm) .004" max (02-20) FTR: (0.15 mm) .006" max (21-40)* *(.004" stencil solution may be available; contact ipg@samtec.com)         LEAD STYLE A –01 (5.84) .230 –02 (2.54) .100 –03 (3.18) .125 –51 (4.83) .190 –52 (5.21) .205 –53 (7.24) .285 –54 (8.51) .335 –55 (9.91) .390 –56 (10.29) .405 –57 (10.92) .430 - NO. PINS PER ROW —D 02 02 thru 36 –P = Plastic Pick & Place Pad (5 positions min. for –D) (8 positions min. for –S) –TR = Tape & Reel (4 positions min. for –S) - —LC —A - PLATING OPTION –L ROW OPTION –S = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail  [1R RI3RVLWLRQV   –LC = Locking Clip (6 positions min. for –D) (Not available with -A) (Manual placement required) = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (4 positions min. for –S)     -1 –A = Alignment Pin (5 positions min. for –D) (Metal or plastic at Samtec discretion) (Not available with -LC) –FR $ RSM –“XX” = Polarized –D = 10 µ" (0.25 µm) Gold on post, Gold flash on tail —S OPTION = Double Row = Single Row –D = Double Row   - OPTION –K = (6.25 mm) .246" DIA Polyimide film Pick & Place Pad (5 positions minimum for –D) (7 positions minimum for –S) –P ALSO AVAILABLE MOQ Required   Note: Some lengths, styles and options are non-standard, non-returnable. - = Single Row –G  [ 1RRI3RVLWLRQV ROW OPTION –S = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: RSM: Phosphor Bronze Terminal Material: FTR: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: FTR: -55 °C to +105 °C with Tin; FTR: -55 °C to +125 °C with Gold RSM: -55 °C to +125 °C Current Rating (FTR/RSM): 3.8 A per pin (2 pins powered) Voltage Rating: 290 VAC Lead Size Accepted: RSM: (0.46 mm) .018" SQ Insertion Depth: RSM: Top Entry = (2.64 mm) .104"to (5.84 mm) .230" with (0.38 mm) .015" wipe, or pass-through. RSM: Bottom Entry = (5.49 mm) .216" minimum (Add board thickness for correct post OAL) - PLATING OPTION Other platings Locking clips     —S —D   = Plastic Pick & Place Pad (5 positions minimum for –D) (6 positions minimum for –S) –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) samtec.com?FTR or samtec.com?RSM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
FTR-105-54-G-D-A
1. 物料型号:文档中提到了FTR和RSM系列。 2. 器件简介:FTR和RSM是连接器系列,具有不同的引脚排列和选项。 3. 引脚分配:提供了不同排数(单排或双排)和引脚数量(02至40)的选项。 4. 参数特性: - 绝缘体材料:黑色液晶聚合物 - 接触材料:磷青铜 - 端子材料:磷青铜 - 镀层:金或锡覆盖50微英寸(1.27微米)镍 - 工作温度范围:FTR为-55°C至+105°C(锡),FTR为-55°C至+125°C(金),RSM为-55°C至+125°C - 电流额定值:每针3.8A(2针供电) - 电压额定值:290VAC 5. 功能详解:连接器支持多种配置,包括不同的引脚样式、引脚间距、极化选项、对齐销和锁定夹等。 6. 应用信息:文档提到了连接器的SMT兼容性和无铅焊接能力。 7. 封装信息:提供了详细的引脚尺寸和插入深度信息。
FTR-105-54-G-D-A 价格&库存
很抱歉,暂时无法提供与“FTR-105-54-G-D-A”相匹配的价格&库存,您可以联系我们找货
