FTR-114-02-S-S
FTR-114-02-S-S
    SAMTEC(申泰)
    SMT .050'' STRIPS
FTR-114-02-S-S 数据手册
F-215 FTR–110–52–G–S FTR–107–02–G–D–A FTR–132–52–G–D–P (1,27 mm) .050" FTR SERIES SMT MICRO HEADER SPECIFICATIONS Single and double row Mates with: RSM, SMS, SLM For complete specifications and recommended PCB layouts see www.samtec.com?FTR Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating (FTR/RSM): 3.1 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold RoHS Compliant: Yes (2,54 mm) .100" OPTIONS –P OPTION Surface Mount Processing: Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (02-20) (0,15 mm) .006" max (21-40) Available with optional Pick & Place Pad Micro pitch (1,27 mm) .050" RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FTR 1 NO. PINS PER ROW 02 thru 40 ALSO AVAILABLE (MOQ Required) • Other platings Contact Samtec. 40 (1,27) .050 x No. of Positions 01 LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart = 10µ" (0,25 µm) Gold on post, Matte Tin on tail –L –G (10,16) .400 x (5,08) (2,48)(5,03) .200 .098 .198 (4,98) (7,52) .196 .296 01 (1,27) .050 79 (0,46) .018 SQ Note: Some sizes, styles and options are non-standard, non-returnable. –D = Alignment Pin (5 positions minimum –D only) (Metal or plastic at Samtec discretion) (N/A with -LC) –A LEAD STYLE B –01 –02 –03 –51 –52 –53 –54 –55 –56 –57 (5,84) .230 (2,54) .100 (3,18) .125 (4,83) .190 (5,21) .205 (7,24) .285 (8,51) .335 (9,91) .390 (10,29) .405 (10,92) .430 = Locking Clip (6 positions minimum –D only) (N/A with -A) (Manual placement required) (1,02) .040 –P (1,09) .043 DIA –A OPTION (2,54) .100 (1,27) .050 (0,46) .018 SQ = Plastic Pick & Place Pad (–D = 5 positions minimum) (–S = 8 positions minimum) –TR –P OPTION B (0,51) .020 –“XX” = Polarized –LC (9,53) (9,91) .375 x .390 (2,54) .100 –S (1,27) .050 –P OPTION 80 OPTION = Single Row = Double Row = 10µ" (0,25 µm) Gold on post, Gold flash on tail (1,27) .050 TYP 02 ROW OPTION B (1,27) .050 –S OPTION = Tape & Reel (–S = 4 positions minimum) (1,27) .050 (0,46) .018 SQ (1,40) .055 –D OPTION WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –LC OPTION
FTR-114-02-S-S 价格&库存
很抱歉,暂时无法提供与“FTR-114-02-S-S”相匹配的价格&库存,您可以联系我们找货
FTR-114-02-S-S
  • 32+28.7856532+3.69498
