FWS-14-01-T-S
FWS-14-01-T-S
    SAMTEC(申泰)
    HEADER 14 POS HI TEMP THRU HOLE
FWS-14-01-T-S 数据手册
F-215 SUPPLEMENT HFWS–06–02–T–S–RA FWS–06–01–T–S SW–10–04–T–S–350–150 (5,08 mm) .200" FWS, HFWS, SW SERIES POWER TERMINAL STRIP FWS, HFWS Mates with: PSS, HPF SW Mates with: PSS, HPF TYPE STRIP SPECIFICATIONS For complete specifications see www.samtec.com?FWS www.samtec.com?HFWS or www.samtec.com?SW FWS/HFWS Insulator Material: Glass Filled Polyester (FWS, SW-TH) Liquid Crystal Polymer (HFWS, SW-VS) Terminal Material: Phosphor Bronze Plating: Sn over 50µ" (1,27 µm) Ni Current Rating (FWS/PSS): 11.4 A per pin (1 pin powered) Operating Temp Range: -55°C to +105°C Voltage Rating: 500 VAC mated with PSS RoHS Compliant: Yes NO. PINS LEAD STYLE FWS RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TAIL OPTION S = Matte Tin HFWS –VS–P = High Temp Header = Surface Mount with Pick & Place Pad (3 Pos. min.) (6,98 mm) .275" min. post height Specify LEAD STYLE from chart below. E B F C (0,51) .020 A 01 thru 20 (6,35) .250 –RA A B C –01 (4,57) .180 (4,57) .180 (4,09) .161 (4,57) .180 (11,94) .470 (13,21) .520 (21,06) .829 (3,81) .150 — –04 (2,54) .100 –05 No. of Positions X (5,08) .200 (2,54) .100 (4,95) .195 D E F G S — — — — STACK HEIGHT –“XXX” = Stacker Height (in inches) (0,13 mm) .005" increments –T –VS = Surface Mount (2 pins/row minimum) Requires HFWS — SW = Matte Tin = Right Angle — = Standard Stacker FILE NO: 090871_0_000 –RA (10,72) (8,64) .422 .340 (4,57) (8,08) (12,24) (8,38) .482 .330 .180 .318 (3,96) (13,82) — — .156 .544 — PLATING OPTION 04 Leave blank for Through-Hole –VS LEAD STYLE –02 NO. PINS (2,54) .100 D G (5,08) .200 TYP (1,14) .045 SQ TYPE STRIP POST HEIGHT Example: –250 = (6,35 mm) .250" = Post Height (in inches) 02 thru 20 (5,08) .200 TYP Note: Some lengths, styles and options are non-standard, non-returnable. STACKER HEIGHT (22,61) .890 MAX WITH (0,00) .000 POST (7,62) .300 MIN STACKER HEIGHT (20,83) .820 MAX WITH (0,00) .000 POST (5,08) .200 MIN (2,29) .090 (2,54) .100 (1,14) .045 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. TAIL OPTION Leave blank for Through-Hole –“XXX” POST HEIGHT (0,00) .000 MIN OTHER OPTION –T = Standard Header Processing: Lead–Free Solderable (HFWS–VS, SW-VS): Yes SMT Lead Coplanarity (FWS, HFWS): (0,20 mm) .008" max (02-15) (0,25 mm) .010" max (16-20) SMT Lead Coplanarity (SW): (0,25 mm) .010" max PLATING OPTION –VS =Surface Mount (2 pins/row minimum) –VS–P = Surface Mount with Pick & Place Pad (3 Pos. min.) (6,98 mm) .275" max. post height
FWS-14-01-T-S 价格&库存
很抱歉,暂时无法提供与“FWS-14-01-T-S”相匹配的价格&库存,您可以联系我们找货
