HLST-102-07-S-D
HLST-102-07-S-D
    SAMTEC(申泰)
HLST-102-07-S-D 数据手册
F-213 SUPPLEMENT LST–112–07–G–D LST–120–07–G–D (2,54 mm) .100" LST, HLST SERIES SELF-MATING HERMAPHRODITIC STRIP Hermaphroditic self-mating combination header/socket system Mates with: LST, HLST SPECIFICATIONS For complete specifications see www.samtec.com?LST or www.samtec.com?HLST APPLICATION Polarized LST Insulator Material: LST: Black Glass Filled Polyester Terminal Material: Phosphor Bronze Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Insertion Depth: (3,68 mm) .145" to (6,35 mm) .250" Insertion Force: (Single contact only) 6 oz (1,67 N) avg Withdrawal Force: (Single contact only) 4 oz (1,11 N) avg Cycles: 100 with 10µ" (0,25 µm) Au RoHS Compliant: Yes Lead–Free Solderable: Wave Only (13,59) .535 MATED HEIGHT One part number for both socket and terminal CURRENT RATING (PER CONTACT) AMBIENT 5 Contacts TEMP 20°C 6.0A 40°C 5.3A 60°C 4.2A 80°C 3.0A (2,54 mm) .100" pitch (0,64 mm) .025" square post TYPE STRIP 1 NO. PINS PER ROW Locking feature increases unmating force and provides audible “click” when properly mated PLATING OPTION 07 HLST Same as LST except: Insulator Material: Liquid Crystal Polymer (Socket Black, Header Natural) Lead-Free Solderable: Yes Note: Some lengths, styles and options are non-standard, non-returnable. LST Call Samtec. HLST –G = 10µ" (0,25 µm) Gold on contact area, Gold flash on balance No. of Positions x (2,54) .100 + (0,51) .020 (2,54) .100 –T 02 = Matte Tin (2,54) .100 Note: Other Gold plating options available. Contact Samtec. (0,64) .025 SQ Elevated Call Samtec. 01 (8,51) .335 (6,10) .240 Surface Mount Call Samtec. Edge Mount –F = Gold flash on contact area, Matte Tin on tail = High Temperature Also Available Right Angle 02 thru 30 = Standard (11,05) .435 (2,54) .100 (2,29) .090 (5,08) .200 (5,84) .230 Call Samtec. WWW.SAMTEC.COM D
HLST-102-07-S-D 价格&库存
很抱歉,暂时无法提供与“HLST-102-07-S-D”相匹配的价格&库存,您可以联系我们找货
