SHROUDED .025" SQ
POST HEADERS
(2.54 mm) .100" PITCH • TSS/HTSS/ZSS SERIES
TSS/HTSS/ZSS
SERIES
Mates:
SSW, SSQ, ESW, ESQ,
SSM, BCS
SPECIFICATIONS
Insulator Material:
TSS, ZSS=Black Glass
Filled Polyester
HTSS=Natural PCT
Insulation Resistance:
5000 MΩ min
Terminal Material:
Phosphor Bronze
Plating: Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Withstanding Voltage:
1000 VRMS
1
TSS
NO. PINS
PER ROW
03
= Connector Strip
(TSS only)
HTSS
05, 07, 08, 10,
12, 13, 15, 17,
20, 25, 32, 36
= High Temp
Connector Strip
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING OPTION
–F
–L
(2.92) .115
–02
(4.19) .165
–03
(14.35) .565
= Matte Tin
–D–RA
LEAD
STYLE
RIGHT
ANGLE
(B)
–04
(3.30) .130
–05
(5.84) .230
PROCESSING
= Double Row
Right-angle
(lead style –04
& –05 only)
Lead–Free Solderable:
HTSS=Yes
TSS, ZSS=No, Lead Wave only
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
ALSO AVAILABLE
—D
-1
ZSS
—DV
(HTSS ONLY)
NO. PINS
PER ROW
03, 05, 07, 08,
10, 12, 13, 15,
17, 20, 25, 32, 36
MOQ Required
Other sizes
Other platings
Alignment Pins
Single Row
Locking Leads
Polarized
(Standard sizes)
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
(2.54) .100 x No. of Positions + (3.81) .150
(2.54) .100 x No. of Positions + (1.27) .050
PLATING
OPTION
(2.29)
.090
MIN
(2.54)
.100
D
–F
–L
BODY
HEIGHT
–“XXXX”
= Body Height
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
LEAD
STYLE
–T
–01
(16.00)
.630
(13.72)
.540
–02
(18.54)
.730
(16.26)
.640
–03
(21.08)
.830
(18.80)
.740
–04
(23.62)
.930
(21.34)
.840
–05
(26.16)
1.030
(23.88)
.940
–06
(28.70)
1.130
(26.42)
1.040
–07
(31.24)
1.230
(28.96)
1.140
–08
(33.78)
1.330
(31.50)
1.240
–09
(36.32)
1.430
(34.04)
1.340
= Matte Tin
(8.89)
.350
—D—RA
= Gold flash on post,
Matte Tin on tail
(9.27)
.365
Note:
Some lengths, styles and
options are non-standard,
non-returnable. ZSS is
non-standard, non-returnable.
–DV
= Double Row
Surface Mount
(lead style –01 only)
(HTSS only)
–T
[1RRI3RVLWLRQV
–01
–D
= Double Row
Through-hole
(lead style –01,
–02 & –03 only)
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
[1RRI3RVLWLRQV
T/H
(A)
ROW
OPTION
Matte Tin on tail
(Not available on -DV)
(Standard sizes)
LEAD
STYLE
BODY
HEIGHT
C
(OAL)
Note:
For added mechanical stability, Samtec recommends
mechanical board spacers be used in applications
with gold or selective gold plated connectors.
Contact ipg@samtec.com for more information.
MAX
C
BODY
(OAL) HEIGHT
samtec.com?TSS, samtec.com?HTSS or samtec.com?ZSS
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“HTSS-117-02-L-D”相匹配的价格&库存,您可以联系我们找货
