HW-10-08-G-D-250-SM-LC
    SAMTEC(申泰)
    CONN BRD STACK .100" 20POS
HW-10-08-G-D-250-SM-LC 数据手册
FLEXIBLE .025" SQ BOARD STACKERS (2.54 mm) .100" PITCH • HW SERIES HW Board Mates: SSW, SSQ, ESW, ESQ, CES, SLW, BSW, BCS, SSM, HLE, PHF Cable Mates: IDSS, IDSD HW - - NO. PINS PER ROW 01 thru 50 02 thru 36 (Surface mount) Insulator Material: HW-SM Top = Natural LCP HW-SM Bottom = Black LCP HW-TH = Natural LCP Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin - Specify LEAD STYLE from chart (Through-hole) SPECIFICATIONS LEAD STYLE LEAD STYLE OAL (TH) – 07 (10.92) .430 – 08 (13.46) .530 – 09 (18.54) .730 –10 (21.08) .830 –11 (23.62) .930 PROCESSING –12 (26.16) 1.030 –13 (31.24) 1.230 Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) –14 (36.32) 1.430 –15 (16.00) .630 –16 (11.30) .445 –17 (12.19) .480 –19 (33.78) 1.330 –20 (28.70) 1.130 PLATING OPTION –F = Gold flash on contact, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on contact area of longer tail, Matte Tin on tail –G = 10 µ" (0.25 µm) Gold on contact area of longer tail, Gold flash on balance - ROW OPTION - –S STACKER HEIGHT - –“XXX” = Single Row Leave blank for Throughhole = Stacker Height (in inches) –D = Double Row SM Throughhole = (5.08 mm) .200" Min. –T = Triple Row (Throughhole only) = Double Row .200" (5.08 mm) row space (Throughhole only) –T POST (0.00).000 MIN = Matte Tin OVERALL LENGTH (OAL) STACKER HEIGHT (2.54) .100 x No. of Positions (2.54) .100 LEAD STYLE OAL (SMT) – 08 (11.81) .465 – 09 (16.89) .665 –10 (19.43) .765 –11 (21.97) .865 –12 (24.51) .965 –15 (14.35) .565 –16 (9.65) .380 –17 (10.54) .415 –20 (27.05) 1.065 (4.95) .195 –D Other platings Locking Clip available with double row HW-SM (Manual placement required) This Series is non-standard, non-returnable. (2.54) .100 —S (5.08) .200 (7.49) .295 —D (2.54) .100 (2.54) .100 (2.54) .100 = HW-TH Tail Length (in inches) (1.40 mm) .055"min. Example: –250 = (6.35 mm) .250" = Locking Lead (Throughhole only) (Shortest dimension between the tail and the post is the end that will be crimped. Available on tails from (2.29 mm) .090" to (7.87 mm) .310" only.) Single row, 01 & 02 positions & –Q row not available –“XXX” = Polarized (Specify omitted pin position) –A = Alignment Pin (Metal or plastic at Samtec discretion) (Surface mount only) = Tape & Reel (4–27 pins per row only) (Not Available on Lead Styles 10, 11, 12 & 20) (Surface mount only) –FR (7.62) .300 —T or —Q* –Q* same as –T except middle row pins are removed Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. (2.54) .100 x No. of Positions (5.08) .200 MOQ Required –“XXX” –TR —S ALSO AVAILABLE OTHER OPTION –LL Surface mount = (6.35 mm) .250"Min. –Q - (2.54) .100 HW-TH = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (4–27 pins per row only) (Not Available on Lead Styles 10, 11, 12 & 20) (Surface mount only) HW—SM samtec.com?HW-TH or samtec.com?HW-SM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
- 物料型号:HW系列,包括HW-TH(Through-hole)和HW-SM(Surface mount)。 - 器件简介:文档描述了FLEX STACK,一种灵活的0.025英寸正方形板对板连接器堆叠器,具有不同的引脚分配和配置选项。 - 引脚分配:提供了不同引脚数量的配置,如01至50(通孔)和02至36(表面贴装)。 - 参数特性:包括不同的堆叠高度、引脚材料(磷青铜)、绝缘体材料(LCP)、镀层(金或锡覆盖50微米镍)以及操作温度范围(-55°C至+125°C金镀,-55°C至+105°C锡镀)。 - 功能详解:文档详细说明了不同的引脚样式、整体长度(OAL)、引脚长度等。 - 应用信息:建议在金或选择性金镀连接器的应用中使用机械板间隔器以增加机械稳定性。 - 封装信息:提供了不同引脚配置的详细尺寸和规格。
HW-10-08-G-D-250-SM-LC 价格&库存
很抱歉,暂时无法提供与“HW-10-08-G-D-250-SM-LC”相匹配的价格&库存,您可以联系我们找货
