BOTTOM MOUNT
SOCKET STRIPS
(2.54 mm) .100" PITCH • BSW SERIES
BSW
Mates:
TSW, MTSW, HTSW,
MTLW, TSM, EW, ZW,
HW, DW, PHT
BSW
NO. PINS
PER ROW
1
LEAD
STYLE
02 thru 36
– 04
Insulator Material:
Black Thermoplastic
Insulation Resistance:
5000 MΩ min
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Withstanding Voltage:
1000 VRMS @ 60 Hz
Insertion Depth:
(3.68 mm) .145" to
(6.35 mm) .250"
plus board thickness
– L
= Low
Insertion Force
ROW
OPTION
–S
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tail
–24
• Bottom mount socket
strips accept .025" SQ
terminals.
• Ideal for soldering and
plugging from the same
side of the board.
• For low profile
connections and high
temperature soldering.
PLATING
OPTION
= Standard
Lead
FEATURES
SPECIFICATIONS
= Single Row
– D
= Double Row
–G
= 20 µ" (0.51 µm)
Gold contact,
Gold Flash on tail
–T
= Matte Tin
(Not available with
Low Insertion Force)
1RRI3RV;
—S
ROW
OPTION
Z
–S
(4.31) .170
–D
(4.32) .170
—D
PROCESSING
Lead-Free Solderable:
Wave only
—S
—D
ALSO AVAILABLE
MOQ Required
Other Platings
APPLICATIONS
BSW
(SINGLE ROW)
BSW
(DOUBLE ROW)
COMPONENT
SIDE
EW
(SINGLE ROW)
PC
BOARD
SOLDER
SIDE
PC
BOARD
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224 (Rev 10JAN24)
TSW
(SINGLE ROW)
TSW
(DOUBLE ROW)
BSW
(SINGLE ROW)
samtec.com?BSW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“BSW-134-24-S-D-S”相匹配的价格&库存,您可以联系我们找货
