CES-119-02-S-D
CES-119-02-S-D
    SAMTEC(申泰)
    LOW PROFILE .025" SQUARE STRIPS
CES-119-02-S-D 数据手册
LOW PROFILE SOCKET STRIPS (2.54 mm) .100" PITCH • SLW/CES SERIES SLW Mates: TLW, TSW, MTLW, MTSW, HW, EW, ZW, HTSW, HMTSW, TSM SLW - 1 - NO. PINS PER ROW - 01 01 thru 50 CES –F Mates: TLW, TSW, MTLW, MTSW, HW, EW, ZW, DW, HTSW, PHT, HMTSW PROCESSING ROW OPTION –S = Gold flash on contact, Matte Tin on tail = Single Row –L = Double Row –D = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –G SPECIFICATIONS Insulator Material: Black G.F. Polyester Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ"(1.27 µm) Ni SLW Current Rating (SLW/TSW): 5.2 A per pin (2 pins powered) CES Current Rating (TSW/CES): 5.5 A per pin (2 pins powered) Voltage Rating: SLW: 406 VAC CES: 400 VAC Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: SLW: (2.16 mm) .085" to (2.92 mm) .115" CES: (2.62 mm) .103" to (4.06 mm) .160" Lead-Free Solderable: No, Lead Wave only - PLATING OPTION = 20 µ" (0.51 µm) Gold on contact, Gold flash on balance  ;1RRI3RVLWLRQV –T   = Matte Tin       —S CES -1 NO. PINS PER ROW - LEAD STYLE 01 thru 50 Specify LEAD STYLE from chart Lead-Free Solderable: No, Lead Wave only - —D - PLATING OPTION –L = 10 µ” (0.25 µm) Gold contact, Matte Tin on tail –T ROW OPTION –S = Single Row –D = Double Row - RA OPTION – RA = Right-angle version (Style –02 only Single Row only) = Matte Tin ALSO AVAILABLE MOQ Required (2.54) .100 X No. of Positions (3.05) .120 Other Platings (5.59) .220 LEAD STYLE A –01 (3.25) .128 –02 (5.66) .223 (5.08) .200 Note: Some lengths, styles and options are non-standard, non-returnable. A —S —D —RA samtec.com?SLW or samtec.com?CES Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
CES-119-02-S-D 价格&库存
很抱歉,暂时无法提供与“CES-119-02-S-D”相匹配的价格&库存,您可以联系我们找货
CES-119-02-S-D
  • 11+61.5500511+7.95530
